Question about Dell Inspiron 1150 Notebook
MY INSPIRON 1150 WONT POWER UP BY MAINS OR BATTERY NO LIGHTS COME ON. CHANGED MAINS AC STILL NO JOY.
    Brigadier General:
  • 8,909 Answers
If there are no light or actions I would guess that the mother board is not getting any power. Unfortunately, power is from the mother board and without the notebook in front of me all I can suggest is to strip the notebook down and check the fuseable links, replacing any that have failed.
The most common cause is incorrect polarity of an ac adaptor if it is not just "one of those things".
Hope this helps.
Posted on Nov 06, 2010
Dell inspiron 1150 wont power up the power light flashes green and batery light flashes orange but the fans or any thing else wont work
You may have a burnt board or the input pin is bad, try wiggling the pin while it is plugged in to see if you can at least get the fans to start you obviously have a short of power in the power button area. You may want to try replacing the power button board for your model this may offer you a solution. If you take it in they can test it with a meter to make sure that this is the problem before a board issue is determined. It is difficult to diagnose this kind of things without the machine in front of me. My advice is to take it in and have the power investigated.
Just because the lighting on the battery is going and showing signs of life does not mean the power button is not bad or not getting the proper power to start the computer. It seems to me that the power button board is bad. Or the input cord pin may be shorted out and only supplying power to the mains but not the power button circuitry. Just a good guess!......John
May 11, 2012 | Dell Inspiron 1150 Notebook
Inspiron 1150 lights up but no display at startup
disconnect all power cable, battery, then press the power botton for 1min. try reset the RAM, then connect power cable and battery and press fn & power button if still it doesn't have any display then you need to change the m/b
Dec 18, 2009 | Dell Inspiron 1150 Notebook
New power adapter and new battery, wont charge through power chord, dell inspiron 1150
If ac adapter and battery have been replaced (Dell Branded AC adapter is required) then the only thing left is motherboard.
Oct 28, 2009 | Dell Inspiron 1150 Notebook
Have an inspiron notebook 1150... hasnt been used in a while. Computer will not power on. Charging plug indicator shows it is working, but none of the lights on the front are illuminated. No power at all....
Try pulling the battery and powering it on - could be that. In response to your master reset button question - the answer is no, there is not one for this laptop. It also could be an issue w/ the connector between the power cable and the laptop - also, make sure you're using the proper AC adapter provided by dell when you purchased the laptop.
Hope this helps - good luck!
Sep 17, 2009 | Dell Inspiron 1150 Notebook
1150 dell inspiron. Laptop won't power up. If
This seems an issue with inverter board need to checked by an expert.
thanks
Jul 27, 2009 | Dell Inspiron 1150 Notebook
No lights when power button pressed. acadapter shows power
Try a different outlet....
if that doesn't work, then...
Your Battery Might be damaged. (partially charging any type of rechargable battery/pack can substantially shorten the lifespan of said battery.) I would take your laptop to a repair shop or store and have the battery tested as well as the AC adapter.
Apr 20, 2009 | Dell Inspiron 1150 Notebook
My dell insprion 1150 do not boot
BEFORE YOU REMOVE ANY DEVICES FROM YOUR COMPUTER REMOVE THE BATTERY AND AC ADAPTER.Pull the battery out and try using the ac only,if this works use a toothbrush and clean the contacts on the battery and the computer itself.You can also remove the memory and the cd rom plus the hard drive.see if it will power up with all these out.Last option with all these removed press and hold the power button down for twenty seconds.
Good luck
Apr 15, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Feb 01, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1300 wont work from the AC adapter
Is the laptop working without the battery, directly on AC. Have you tried using another charger or battery to see if its charging.
Jan 28, 2009 | Dell Inspiron 1300 Notebook
Dell inspiron 1150 won't turn on
Remove the battery the memory the ac adapter,the hard drive, the cd rom.Press and hold the power button down for twenty seconds.try again if no go you will have to replace the systemboard.
Good luck
Jan 13, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell Inspiron 1150 Notebook Logo
69 people viewed this question
Clive
Clive
Alun Cox
