Question about Philips MCD908/37 System
I have a Philips MCD908 book self system with a tube pre-amp. It has worked ok for two years but lately I get a loud buzzing coming from both speakers after warm up. This happens when I select the AUX and DVD functions. The only new equipment is a hard drive but that is located on the floor behind the entertainment center (wood) while the system is housed in the entertainment center. I did add a new power strip to get me an extra power outlet for the hard drive but the hard drive is turned off most of the time. Any suggestions?
SOURCE: Philips HTS3450 System Problem buzzing/clicking sound on startup. Now nothing.
I had the same problem except my volume would just decrease after a few minutes of being on like someone was pressing the volume down buttton. If I walked over to the subwoofer and gave it a knock on the top the volume would instantly come back on where I had it set before. I took WheatService's advice and replaced the 470uF/25Vcapacitors and everything is working great now. I am very pleased. BTW, the parts at radio shack were like $3.00. I needed a desoldering tool, which I would recommend for this job...the one with the suction ball. I also needed some more soldering wire for a total repair cost of about $17. If you have all the tools the capacitors will cost you $3.00. Philips wanted to send me a replacement unit for $100.00 and I'm sure the local repair shop would have been the same if not more. Thanks again, WheatService!
Posted on Aug 12, 2008
SFroese
  • 141 Answers
SOURCE: No audio is coming through my speakers
If the receiver is actually powering up but you are getting no sound, there are few basic things to check.
Check the audio connections on the back (speakers AND inputs) to make sure they are tight at both ends and undamaged. Go into the setup screen for the DVD player and make sure the audio settings are set for PCM output and that you are using a digital or optical audio cable. Then make sure you have the correct function selected on the receiver to match the inputs. If the receiver has a speaker test function, use it to see if there is any output from the speakers. Finally, make sure the volume is turned up and the mute button is off.
Otherwise, the amplifier may be faulty
Posted on Sep 07, 2008
easyq
  • 144 Answers
SOURCE: Philips Home Theatre System - no sound or power light on sub woof
reset the device to factory settings, it is written in your manual how to do this. If that doesnot work, unplug the powersocket for about 30minutes, it will cause an internal reset which might solve it.
Edgar
Posted on Jan 29, 2009
SOURCE: Just bought a Philips home theatre system HTS3544 low sound?
You may also need to change the speaker set up. Go to DISC setting (one of the top selections on the remote) make sure you have no Disc in the DVD player. When in this mode press setup on the remote. On this menu you will have a option to adjust the speaker volume.
I had to increase my speaker volumes to get better sound. This setting is not accessible if you try to do the set up in other than DISC setting. Be sure to check the SURROUND setting. The SURROUND button on the remote will toggle between stereo and surround as stated in a previous post.
ST
Posted on Mar 27, 2009
SOURCE: cracking popping type sound coming from front and center speaker
if u are trying to connect the audio of ur tv as input to flow out from the home theater; this is a common thing; u need to replace the audio cable that connects the tv to 3565 with a good quality cable
Posted on May 13, 2009
No sound from the left channel of my technics sl-b35 turntable
First of all remove the wires to the cartridge. With the amp on, touch each of the wires to the cartridge with your finger. one at a time. On one you should hear a loud buzz on the left and on another a loud buzz on the right.
If you get no loud buzz on the left. There is something wrong with either the connections between the deck, or the pre-amp of the amplifier. This will not effect any other function on the amp such as tape or cd.
If you do get a loud buzz on the left, check the cartridge connection or replace the cartridge.
Apr 07, 2017 | Technics Audio Players & Recorders
Sony stacking system LBTd505, the sound from the record deck suddenly went very faint. The cd and radio sections are fine. I have tried a new stylus, but no difference. Any ideas?
You have two options. First a faulty cartridge. Or a faulty pre-amp in the main amp.
You can find out if the cartridge (and amp) are playing up. By removing the connectors on the cartridge.
Then with the volume turned up to about half, with your finger, touch each one of the wires one at a time. It will not harm you at all. But you should hear a loud buzz on one wire on the right and a loud buzz on the left on another wire.
The two other wires will either produce a crackle, or a tiny buzz, or nothing at all.
If you do hear a loud buzz on two wires. The cartridge is faulty and needs replacing.
If you hear a slight buzz on them or weak sound. There is either a bad connection between the deck and amp. Or the pre-amp inside the deck which is only used by the record deck so will not effect any other function, is faulty.
You can remove the record deck connections to the amp and again with the amp on half full, touch the inputs with your finger. If you are not hearing a loud hum or buzz, the pre-amp is faulty. If you do the connectors are faulty.
Jun 11, 2016 | Sony Audio Players & Recorders
Sound not coming out loudly
You could have either a cartridge problem or a pre-amp problem.
To check. Remove all the wires to the cartridge. With the deck connected to the amp and powered up, set the volume at normal for what you would listen to it. Now with your finger touch each wire one at a time (it will not hurt you). You should hear a loud buzz on two of the wires, one on each channel.
If you do not hear a buzz or its weak, then either the connections between the deck and amp are faulty, or there is something wrong with the pre-amp for the magnetic cartridge inside your amp. If you have only recently connected the deck to your amp, it might be that your amp has no built in pre-amp, and you will need to purchase one. The internal pre-amp for the deck failure will not affect any other part of the amp.
If you do hear a loud buzz, check either the cartridge connections or replace the cartridge.
May 25, 2016 | Audio Players & Recorders
No sound through the built in speakers. Turntable turns fine and I can hear the record play but it does not transfer to the speakers. New needle makes no difference
Remove the 4 wires to the cartridge. With the system on. Put your finger on each of the wires separately. On two of the wires you should hear a buzz (one on each channel) on the others very little or perhaps a faint buzz.
If you hear the loud buzz(s) the amp inside the deck is working and you have either a faulty cartridge or have not connected the two wires right.
If you don't hear any buzz, the amp inside the unit is faulty. If the amp has other functions that do work (such as radio) then it is the pre-amp for the cartridge that has gone. As this will not affect the other functions.
Feb 01, 2016 | Audio Players & Recorders
My Al 300 jvc no sound coming from turntable to speaker cassette radio working OK
Unplug the red and white leads. With the amp turned on to full volume, touch the sockets the leads plug into with your finger. If you hear a big buzz. The amp is OK. If you don't the cartridge pre-amp inside your amp has failed. It will not effect any other parts of the system, cassette, radio, etc.
If you do hear a buzz. Then the cartridge is faulty.
Dec 21, 2015 | JVC Audio Players & Recorders
Amplifier or preamp problem? Sound has become faint.
Unplug the leads from the cartridge. With your amp on. With your finger touch the left and right wires one at a time. If the amp produces a buzz which is loud, then it's good. Just hold say the right wire for some time. If the buzz stays loud, then it's the cartridge that is faulty. Or if not... If the amp has other things connected to it such as a CD and that plays OK then, it could be the pre-amp for the magnetic cartridge. This is generally a single IC which will need to be replaced.
Oct 10, 2013 | Crosley Audio Players & Recorders
My Marshall MG50 DFX Has an awful buzzing sound that comes out of it after startup.
I would check C22 and C24 the main smoothing capacitors. They can fall out at worst or just have bad solder at best.
Mar 20, 2017 | Music
Volume problem MCD908
Check its power amplifier circuit for the fault.
Apr 16, 2012 | Philips MCD908/37 System
Marshall MG100 MG DFX. Full speaker noise with all volume knobs turned to zero and on all settings. When the amp is switched on there is a horrible loud buzz/growl that can only be left on for a split...
well theres only 3 sections of the amp the problem can be in. Pre-amp, Power amp, or speaker. First Unhook the speaker. If you can turn on the amp after that and hear your guitar through the headphone jack this means your pre-amp is ok. at that point you can just take a voltmeter across the 2 terminals of the speaker to see if oyu have 4, 8, or 16 ohms. that'll prove the speakr is good. I'd also try to connect and disconnect the pedal a few times to see if the normals in the jack on the amp are just being stupid. if all this concludes no success, you sir have a power problem.
Aug 31, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
Amp volume drop with flabby bass sound.
1) can happen if the speaker is dying - voice coil defective or magnet needs recharging. happens sometimes with low quality speakers.
2) faulty pre-amp section can reduce overall gain resulting in lower output volume.
3) for old amps dry solders in pre-amp & power amp section can have the same effect.
4) faulty coupling and filter capacitors can severely effect frequency response too.
Mar 13, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Philips MCD908/37 System Logo
117 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
