Question about KitchenAid KEMC308 Electric Double Oven
KitchenAid KEMC308KSS02 Microwave Error
Hi Reg501. I had the same problem with my microwave door spring as mentioned above and I replaced them. I got the oven back together and in place but now it won't turn cook! When I enter a time it displays "DOOR". It has power, obviously. The door is closed and held tight. The light doesn't come on now when the door is open.
How do I fix this? I am comfortable (and safe) working with electric power. Thanks in advance,
WeaselDog
  • aliscott Sep 25, 2008
    One catch on RHS of MW had spring backwards, I was able to pull it forwards to it's normal position, but now the Microwave control panel indicates DOOR when I try and do anything. (also the light inside the microwave does not come on now), e.g. opening the door used to bring on the light, I think.
    I can hear the microswitches clicking on and off as the door closes and opens so I am guessing thay are OK.
    - Do you think the fuses would have blown?
  • urogynman Mar 30, 2009
    Suddenly I am unable to use the microwave. The time will be displayed and when i hit the start button a "DOOR" message is shown and the microwave will not start despite the door being firmly shut. The oven will still work.
The micorwave oven light does not work and when I push start, the word DOOR shows on the screen and beeps 3 times. The oven will not start.
Posted on May 02, 2009
The clue was that the light in the microwave did not turn on when the door was opened and any attempt to use oven resulted in DOOR error message, even though door was firmly shut and even after both latches were both reset to the normal positions.
In my case the fuse inside the microwave compartment had blown (due to the RHS door switch activating the monitor protection?)
Anyhow the fix was to:
0. Isolate power to the oven
1. 'reset' the door latch, by pulling it forward using a hooked tool
2. remove enough of the Top and RHS metal paneling to be able to access the fuse holder inside the microwave electronics bay (at the right side /back of the microwave oven ). Almost directly below the cartridge fuse in the top control panel bay). I was able to squeeze a hand in between the top bay and the microwave bay to reach the fuse.
3. replacing the fuse using Radio Shack Catalog #: 270-1041 $2.99 for 4 ceramic fuses 20A 250V (was in stock at my local RS :-)
4. reassemble panels/metalwork, restore power and test
Posted on Sep 25, 2008
  • 413 Answers
One or both of the door mechanisms are not engaging properly.
Check the door and make sure the door switch latches are working properly or are not broken. There will be one on each side.
Also, one or both of the the door switch mechanism in the oven may have sprung backwards. Look through the latch openings (you should see a hook that will catch the hole in the door catch) to see if the latch has sprung backward. If so, you will have to take the unit apart to reset the mechanism. Taking this unit apart to gain access to the door mechanism is quite challenging.
If this has happened, it may also cause fuse(s) to blow. While you have the unit apart, check the fuses. There will be a 15A large cartridge fuse behind the control panel and a smaller 20 A fuse inside the unit where the MW power components are located.
Let me know how things go or if you need additional assistance.
Regards,
reg501
Posted on Jun 15, 2008
  • 1 more comment
  • TPOSCH Aug 07, 2010
    How do you access the fuse behind the control panel?
  • TPOSCH Aug 08, 2010
    Found this EXTREMELY useful repair manual, detailing how to take this baby apart and access and fix everything. Scroll down a little and you'll see a link to a pdf file. Once I replaced the fuse behind the control panel, SUCCESS!
    http://applianceguru.com/view_topic.php?...
  • R0BERTVAUGHA Jan 11, 2011
    I HAVE HAD THE MW OUT ON THE COUNTER, THE CONTROL PANEL APART, AND REPLACED THE 20A FUSE, WHERE IS THE 15 AMP FUSE LOCATED? I KEEP HEARING BEHIND THE CONTROL PANEL, NOT ON THIS ONE!!
    Problem Solver:
  • 5 Answers
I replaced the fuse as above and the "door" problem persisted. I then replaced the switches on the door latches on both sides and it still does the same thing. What next? How do you get into the control panel to check the 15A fuse?
Posted on Aug 07, 2010
Why is there a flashing probe display w/beeping?
Usually this is a problem related to the meat probe jack or the wiring to it. If not the cause, next in line is the control board, part number: 8302346. We can rebuild this board for you. See:
http://www.fixyourboard.com/boards/8302346.html for details and
Fix your board Repair control boards for home appliances for a shipping form.
Sep 08, 2015 | KitchenAid 30" Microwave Combination Wall...
I have a kitchenaid convection oven with microwave F6 EO code
Your tring to fix an appliance that's 10 yrs. Old ! Replace is your answer
May 14, 2012 | GE JKP85 Electric Double Oven
Multiple replacement of Microwave door springs
KitchenAid Architect Series KEBC107KSS Electric Single Oven problem error F1E7
Sep 15, 2009 | KitchenAid KEBC107 Electric Single Oven
Displaying DOOR
there is two fuses a 15 amp and a 20 amp fuse on the left hand side of the microwave one or both have blown
Jul 08, 2008 | KitchenAid Architect Series KEMC308KSS...
KEMC308KBL01
send me am e mail at b4829@yahoo.com with the model number
May 31, 2008 | KitchenAid Architect Series KEMC308KSS...
KEMC308 Microwave oven door
Had the same problem and bought the part online. It's not difficult to replace, simply hold the door by the handle as you loosen the 2 screws. Put the face of the door on the floor and remove 2 screws holding the plastic insert. You will have to remove the front vent panel (2 Screws) just below the microwave door.Then you might have to move the oven vent over to get to the final 2 screws on the bottom of the plastic panel. Once you have the palstic panel off the springs are exposed, simply look at how it is placed in the holder before you remove the damaged one. Replace and then re-assemle the door.
May 23, 2008 | KitchenAid KEMC308 Electric Double Oven
Kitchenaid Microwave torsion spring replacement
I just replaced torsion spring 4452396 on my microwave. We heard a "pop" and then the door got heavy. here are a couple things I learned...THE HARD WAY!
We had the stainless steel front to the door and needed spring 4452396, not 4451008. The stainless steel door is heavier so therefore a stiffer spring. I'm not sure i could justify the 4x cost in the part...but that's just the way it is. It's a bit of a pain to repair the thing..so it's worth it to get the correct spring. You don't wan to be doing this every couple of of months!
You have to remove the front panel of the door to access the springs. there are 2 of them...they cross each other in an "x" pattern on the lower part of the door. We had to pull the unit out a bit to get the spring in the hole for correct position. No need to remove the door etc. If you need help with this...email me.
My mistake was when I was trying to figure out how to gain access to the springs I assumed you did from the inside of the door. I removed the two black things you see on the lower right/left of the door (screw on the bottom of them) then proceeded to remove the two recessed screws on the inside top corners of the door. Well next thing i know.....CRASH! the whole front of the door fell off and shattered! Come to find out those screws and brackets on the bottom hold the face of the door on. The glass is intergrated into the color panel of the door..so it's one piece! 150.00 later and a new piece of glass/panel i learned a hard lesson.
Let me know if you need help...it's fairly easy to do now that I look back on it. dave dlacki@gmail.com
May 14, 2008 | KitchenAid Architect Series KEMC308KSS...
Microwave door
before you do you may want to check the warranty.
some parts have a 10 year warranty
http://products.construction.com/portal/server.pt/gateway/PTARGS_0_2_493_204_249_43/http%3B/205.142.52.224/swts_content_files/15315/211253.pdf
Aug 23, 2007 | KitchenAid KEHC379 Electric Double Oven
KitchenAid KEMC308 Electric Double Oven Logo
1,021 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
