Question about Garden
My fs55r wont start - got carb kit, new filter and sparkplur what next?
    President:
  • 1,545 Answers
You need to make sure it is getting a nice strong spark. The electronic solid state ignition control module (coil) controls this and the contact legs on it have to be gapped about .010-.012" from the magnets on the flywheel. This goes on under the front engine cover. First, check for a nice blue spark. If it is weak or yellow, the coil needs adjustment. They fail rarely. A standard business card is about the proper thickness to produce the "air-gap" needed to create a a good spark.Also, make sure the plug has the correct gap on it.
If you have to check the coil, the front engine cover will have to be removed and moved forward to access it.Underneath the cover is the starter/recoil unit and under that is the flywheel and the coil. The coil will be attatched to the engine cylinder with a couple Torx screws about size T-15 or T-20.
Posted on Nov 09, 2010
How do I start a hard to start FS55R weed trimmer?
Start with fresh fuel, fuel filter and spark plug. Then adjust your carb low and high to 1 full turn out on each. Start and see if it stumbles on acceleration, if it does turn the low side out a 1/4 turn. This will get you going in the right direction. There are several other things that could be wrong, but this is the simple start.
Oct 06, 2014 | Garden
Fuel system diagram
ever give it a tuneup this decade or last 60k miles.????????????
get the FSM. buy one , used.on fleabay, and be ready next time.
or
go to alldata.com login and read it.
also at mitchels.
what engine size.
is car a CARB. (yes)
on all cars, carb or EFI , starting is same (basics)
example. (classical)
does it crank robustly, yes,
Does engine have 150PSI WOT compression, times 4. (yes)
does it have, spark on all 4 cylinders and is it timed right. (strobe it for time to spec)
answer, yes, (examples) and is timed right.
now we land on fueling
in this case its a carb.
the first test is , is the fuel at the top mark for for float level.
yes, good, no , pump bad. or filter clogged.
ok next.
is the choke on,, but not 100% if 100 % it floods,
is it ok? the choke plate.?
yes.
ok i got every thing it takes to start and its not flooding.
so what is wrong, easy, the carb is TOAST , get a new one.
oops, nobody sells them. its too old a car. in most cases.
but in my cause, i rebuild them.
i restore old cars and motorcycles, (stock)
so can do it. some take 3 used junk carbs to get one working.
and a kit. i find the carb kit first.
then boil it out (Berrymens) then kit it and tune it like the FSM directs.
there did it all end to end.
most 28yo carbs are useless and long gone.
(cept after im done)
i put in butterfly shaft bushing, and kit them.
if they are corroded to dust the hit the trash.
Jan 01, 2014 | 1985 Toyota Pickup
I rebuilt my 6o5o nikki carb on my snapper leaf blower and it wont start any ideas on how to fix this
Have you tried spraying carb cleaner or straight fuel in carb and try to start. this will show if it is a fuel issue. You also may have to adjust the carb if it has a high and low or idle screw. Also could be the kill switch. How about the fuel lines are they connected correctly and is the fuel filter connected correctly.
Nov 09, 2013 | Garden
Klx250 wont run it has spark new battery and cleaned carby but wont fire up will occasionaly start and run fine
Remove the filter or filter connection to the back side of the carb and spray it with starter fluid. If it starts when you do that each time, the carbs still have a problem and need to be cleaned out again or adjusted correctly.
Jan 17, 2013 | 2005 kawasaki KLX 250
Problem start bike. Push a starter and only clik , bike wont start. Suzuki 250gc 2004
Sounds like a bad battery. Try charging overnight with a 1 or 2 amp charger.
If this doesn't help then go to the dealer and ask for the stock plugs for your bike. Check for spark on each of the new plugs then install the plugs.
Remove the carbs , dissemble it and clean the varnish out. Remove the petcock, ( gas valve ),water trap and clean it out. Next let one cup of gas flow into a container. Any water or rust in the bottom of the container? If any rust was in the water trap or the container then purchase an inline fuel filter to eliminate the rust getting into the carb.
If cleaning the carb yourself does not do the trick then take it to the dealer and have them clean it and install a carb kit. This should eliminate the carb as a problem. Get a new air filter and install it.
Now you have spark, gas and air. If it still will not start it is likely that you need new crank seals. On a bike that old you may well need new crank bearings as well.
Mar 21, 2009 | 2002 Suzuki GZ 250 Marauder
1995 honda cbr f3 wont start
I would think about investing in a carb re-build kit.
Dec 22, 2008 | 1998 Honda CBR 600 F(3)W
Craftsman riding mower floods after a few seconds
FYI...just thought I'd give a little back...
had exactly the same mower/plow w/ same issue !
mine is an older L-head from pre-1998...used....
19.5hp 3 screw type diaphram fuel pump carb...
the pic's and how to assemble... I will send if,
you email me... Instructions do not come from
B&S when you buy there part # 694056... = 10$
carb rebuild kit...they want to sell the manual too !!!
sku# 0 24847 26246 9 ...shame on them !
they are selling manual # 27xxxx for 20$...
to tell you what to do ! ....%$#-THEM !!!
I made a pdf...with before and after pic's of
how to rebuild this carb...it's quite unique in fuel pump design and simplified governor operation...
running well this 19.5 twin - fan cooled...is like a 25HP !
the carb kit from B&S is generic...w/extra parts...
I have pic's of the actual ones used/needed for this
carb... Main jet is mis-labeled...it's a bowl vent !
There are no jet's to adjust on this carb...
only adjust is idle speed post the governor linkage !
also shown functioning in my .pdf...
hit my mail ..... driscoll_at_pzdi_"dot"_com
or visit www _ pzdi _ com
248-390-3541
Nov 08, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
244 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
