Question about Samsung YP-U3 MP3 Player
The volume and up and down port can move - Samsung YP-U3 MP3 Player
    Problem Solver:
  • 12 Answers
Kkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk
Posted on Nov 06, 2010
Hi i have a lg ku990 phone the volume keeps on doing down and up when im talking on the phone
Possible that during the call that the hand pushes the volume levels to move down, secondly it is possible that there are errors, moisture or dirt, that triggers the volume control from the pads to move down/up.
Now open the phone and clean up the pads and the board, make use there is no moisture, if so use hair dryer to warm off.
Apr 08, 2011 | Health & Beauty
Have a uniden pc 68 elite it seems everything works the whene transmitting the needle moves a. but it has no volume it makes no noise i have tried a different mic i have put a new ext speaker on it and it...
Could be audio chip.
  • Insert external speak jack into pa port.
  • Turn volume down
  • Switch cb/pa switch to pa
  • speak into mic
if you are getting audio from speaker ......chip is fine.
Jan 04, 2011 | Uniden Bearcat Pro PC68Elite 40-Channels...
Plugged in to rear green port won't workwont
Make sure switch is on, try pluging it into an external MP3 player.
No sound would be coming from the speakers if nothing is playing on the computer also look at the computer volume as well as the speaker volume control.
Dec 19, 2009 | Dell A215 Computer Speakers
No Sound. We moved the computer and now no sound.
Try checking to see to make sure that the audio jacks are plugged into the right ports. Also, check to make sure that nothing is muted, and that volume is up ( I've actually went for sound without a day after moving my computer because I forgot I had muted and turned my volume all the way down the day before xD )
Anyway, I hope this helps, and let me know if it doesn't.
Oh, and one last thing, make sure that your speakers are set as the primary output devices. If you have 3rd party audio drivers, sometimes you have to set what audio output is going through.
Oct 17, 2009 | Samsung SyncMaster 172 W 17" LCD Monitor
COMPUTER PROBLEM
Make sure your mute is not on, your volume is turned up, your speakers are plugged into the correct port, and the sound drivers are installed for your sound device.
  • Turning the mute on and off and volume up
  1. Down by the clock there is something that looks like a little grey speaker. If you left-click does, is the Mute check box, checked?
  2. Make sure the volume bar is up. You should hear a "beep" sound when you click and move the slider up and down. This signifies the volume.
  • Speaker Port
  1. Check that the speakers of your PC are plugged into the correct port. On most motherboards and sound cards, the correct port for the front left and right speakers are usually color coded as a "light green".
  2. Ensure the speakers are plugged into this port.
  • Make sure the drivers for your sound device are installed
  1. Go to Start -> Control Panel
  2. Double-click on "System" (without quotes)
  3. Select the "Hardware" tab (without quotes)
  4. Click the "Device Manager" button (without quotes)
  5. If you see something that mentions sound device and it has a yellow question mark or yellow exclamation mark next to it, the drivers are not installed correctly or there are errors with the device.
  • If the above steps do not work
  1. If the above steps do not work, consider having your PC professional checked out as there are several other things that MAY be wrong with the PC and diagnosing these issues via the internet would be near impossible.
I hope this helps you resolve your problem.
Mar 06, 2009 | E-Machines eMachines Desktop PC
Volume Limit
Press settings.
Press Volume Limit.
Move the wheel around to desired position.
Press the center button.
If you don't want to set a combination, press done.
Jul 01, 2008 | Apple iPod nano
Just the screen lightened
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
May 04, 2008 | Creative Labs ZEN SLEEK MP3 Player
Ilo MP3 player locks up when plugged into MAC or PC
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
Mar 05, 2008 | iLO (2 GB) MP3 Player
Logitech X-540 5.1 speakers loudly crackle when volume moved up or down
mine does that, its complety ok. Just run them at highish volume for about 30 secs should fix them, its just static.
Feb 12, 2008 | Logitech Z-540 Speaker
AUX. Problem: sound cuts. and weird effects.
Disassembly Required Ok for whatever reason breaks on the printed circuit board have occured. Expose the contact points of the rca ports. resoldering these spots on the pc board will do the trick. 'HINT' resolder all contacts, there should be 3 or 4. As for the volume check for dirty residue below the surface of the switch face(s) and or increase tension spring found below switch face.
Sep 17, 2006 | JVC MX-K30 CD Shelf System
Samsung YP-U3 MP3 Player Logo
12 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
