I had samsung sp61l2hx which is not working . when switch it on it just show the lamp lisht on and after it switch off. the lamp trys to turn on but it shut down . tell me how to fix. thankyou
You need a new bulb :-) Yours is blown.
Posted on Jan 26, 2011
Unplugged tv for storm, plugged it back in now it trys to turn on but won't
plug in a bed side light and see is it working and if it is not then the storm has damaged the tramsformer supplying your house
Aug 08, 2012 | Samsung Hlr5667w 56-inch Dlp Hd Tv
Samsung hl 6167w unit comes on no piture then shuts off
If the TV turns off then trys to come back on a few times then nothing, I suspect the lamp is not firing. The lamp part number is either on the left or right side of the TV on an orange and white sticker that says "Lamp code" Once you have the lamp code do a google search for that number for the lowest cost lamp. Be careful as some are lust the bulb itself and not the complete lamp assembly. I hope this helps : )
Jul 29, 2011 | Samsung HLN617W 61" Rear Projection HDTV
Replaced lamp, but TV continues to shuts down a few minutes after starting. I replaced the lamp and it still has the same problem. What else can it be? After about 4 or 5 trys, the TV seems to work okay.
Tv have alots of clicking noises too to get tv turn on?The Ballast board is having problems.The Ballast board job it to ignite the projection lamp.
Feb 18, 2011 | Samsung HL-S5687W 56" HDTV
My turn signals and brake lights have stopped working. I have checked the fuses and they are all fine. I have a 1996 Buick Regal.
assuming the wiring is ok , both those circuits go throught the signal lisht switch, so srart there
Nov 22, 2010 | 1993 Chevrolet S-10 Blazer
My samsung 46 in. hdtv will not power up when plugged in standby light is lit turn on then it flashes lamp led it after theen goes back to standby mode repeats this process three times then all three...
Have you Check the Lamp Fan is it still running while Lamp trys to light?Ballast board is what powers Lamp on ,but if the Lamp Fan is defective Lamp will not light.
Sep 10, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
HI FOLKS, I HAVE A SAMSUNG HL-P5063W DLP TV THAT WON'T TURN ON. WHEN I PLUG IT INTO TO WALL I GET THE SOLID RED STANDBY/TEMP MESSAGE ON FRONT ON/OFF BUTTON. THEN WHEN I TURN IT ON, THE STANDBY/TEMP MESSAGE...
Bad Lamp Call FOX 1-800-227-5369 Lamp number is
BP96-00608A or BP96-00826A $109.00 Mats Electronics is another company for Lamps 1-800-628-1118 or Find one on E-Bay
Nov 30, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
I have a samsung hlm 507wx and the bulb ticks and trys to start up multiple times and when the bulb finally turns on the screen works fine for about 10 seconds then the tv turns off and flashes the 3 leds...
Replace Lamp Look online Encompass Parts for Lamp# or Call 1-800-638-3328 also ck Lamp Fan if it stops running Lamp will shut Off and another thing Ballast Board is what turns Lamp on.
Nov 18, 2009 | Samsung HLM507W 50" Rear Projection HDTV
Hlp5063w 50'' projected samsung lamp won't come back on ?
It could be the lamp but don't overlook the lamp door interlock switch. If the lamp door is not aligned properly, you may have intermittent shutdown or no start conditions. You can temporarily cross the interlock switch to confirm that this is the cause.
michtech
Feb 17, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
I have a Samsung rear projection TV, model no SP61L2HX. When switched on and waiting for the lamp to warm up it switches off. Then it turns on again and keeps on repeating this cycle.
    According to the symptom this problem called hicking.And in this situation various components could be shorted.
   The main cause is power supply,Check the unit may be there could be capacitor leakage.Safty resistor could be open.
  If you can do it by yourself and expert then ok.But if you have no earlier experience then plz contact any expert nearby.
  Thanks for using fixya.
Dec 15, 2008 | Televison & Video
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
