Question about Efficient Networks SpeedStream 5200 Modem
Dynamic IP to Static IP
Hey! I followed to guide on portforward.com to onfigure my dynamic IP to a Static. When I type into the Command Pormpt " ipconfig/all " when it displayed under the correct netowrk, my IP adress it was 192.168.*.** So I chnaged that to my Static IP but made the number 1 different so say it was 6, I made it 7! Then When i needed to connect my website, in the configuring I set my IP to a External IP which i gave me on whatismyip.com.. Did I do this right? or was a suppossed to use the IP that I set which was 192.168.*.**? NOTE; My website did not work with the External IP yet it did witht he Static one I set but not for others..!
  • JellyPapers Jun 14, 2008
    I don't have a router. I just have a hub that I use to connect all my computers to the same network.
  • JellyPapers Jun 15, 2008
    yep A speedtream 5200
  • 2,794 Answers
Your dynamic IP is the one that you modem is connected to. The 192.168.*.* is just you local area network addresses.
What does you router have for IP address information?
Posted on Jun 14, 2008
  • 1 more comment
  • Tim Babcock
    Tim Babcock Jun 14, 2008
    Do you have a modem of some kind?
  • Tim Babcock
    Tim Babcock Jun 15, 2008
    Does that plug into your hub?
  • Tim Babcock
    You might by able to find out what the dynamic IP is by going to My Network Places, view network connections, move the mouse over to your network connection, press the right mouse button, press status.
    What does you default gateway setting say?
    The best way to find out your IP address for you modem though is to call your provider.
    As a network technician I would recommend hooking that system up to a router when you can. You will have better security on you network and with a built in firewall that most routers have you can feel at ease about getting hacked.
    Not to mention the fact that your network will go a lot faster since a hub has to repeat every data signal into every line of the hub to find where the data is supposed to go to and can cause data collisions to occur making your network run very slow.
    Good luck on that.
192.168.0.13
77.248.24.119 is the dns from the internet service provider
192.168.0.13 is the router address
Jul 07, 2015 | Computers & Internet
Change ip address
Type cmd in Start menu-Run. A little black window will open. Type: ipconfig/all and Enter. It'll list your IP among other info.
If you want to change it: Start menu->Control Panel
Type "adapter" int the search box. You'll have "Network and sharing Center". Click "View network connections". Select "Internet Protocol version 4 (TCP/IPv4)" and click Properties. There you can change your IP settings.
Jan 17, 2014 | Lenovo IdeaPad Computers & Internet
What is the ip address
IP address
noun Computers. a code that identifies a computer network or a particular computer or other device on a network, consisting of four numbers separated by periods. See also IP.
http://dictionary.reference.com/browse/IP+address
PS. Free points for newcomers or are you to lazy to google it?
Aug 23, 2013 | Comtrend CT-520 Router
What is ip address
Internet Protocol is also known as Ip address.Every users on internet have their own ip address.Users on internet identify by their ip address.Ip address provided by the internet service provider.There are two types of ip address static,dynamic ip address...
Static Ip address will not change forever ..Even if you reset the modem the static ip address won't change.Static Ip address also known as dedicated ip address..You can use for website..This ip is dedicated for your website only..
Dynamic Ip address :
Dynamic ip address will change whenever you reset the modem.A new ip address will assigned for your connection...You can use dynamic ip address for browsing and normal internet usage....you can use the site Ip-details.com check the ip address whether it is static or dynamic ip address
Jul 24, 2013 | Computers & Internet
Chaneg ip
There are two types of ip address available..One is static ip address it will not change forever...But another ip address is Dynamic ip address.It will change..If you need to change dynamic ip ,you can reset the modem it will assign new ip address for you...everytime you can reset the modem and get new ip address...It\'s possible only if you have dynamic ip...You can check whether your isp provided ip is static ip or dynamic ip by visiting the site IP-DETAILS.COM
Sep 15, 2012 | Computers & Internet
IP Address
To check your IP you need to Go To Start Rum and type cmd and enter
You will find a DOS screen poped up . you need to type Ipconfig . It list you your IP. You need to have a local admin to change your IP
Dec 20, 2008 | Computers & Internet
I want to create site to site vpn with sonicwall tz170+ 2003serv
Complete documentation is available on the below link
http://www.sonicwall.com/us/support/3134.html#heading_3139
Nov 17, 2008 | Sonicwall TZ 170 NFR (01-ssc-5564)...
Need to renew ip address for my emachine T3516
just right click on your local connection on the desktop by the clock and click on "repair". this should clear the cache and renew the IP addy and DNS for yur connection. OR
Follow these steps to quickly release and/or renew the Internet Protocol (IP) address of a computer running Windows XP, Windows 2000, or Windows NT. Here's How:
  1. Click the Start menu button on the Windows taskbar.
  2. Click Run... on this menu.
  3. If the computer is holding a current IP address, type 'cmd' (without the quotes) in the text box that appears. A command prompt window appears on the screen.
  4. Type 'ipconfig' (without the quotes) to view the status of the computer's IP address(es).
  5. If the computer is holding a current IP address, type 'ipconfig /release' to let go of the address.
  6. Type 'ipconfig /renew' to obtain a new IP address (whether or not the computer is holding a current address).
Tips:
  1. If it is not necessary to view the current IP addresses on a computer, simply type 'ipconfig /release' or 'ipconfig /renew' (without the quotes) in the text box that appears in Step 3.
  2. To bring a computer back onto the network after moving it to a different location, or experiencing an unexpected outage, first release, then renew the IP address. Computers on DHCP networks often (but not always) re-establish network connectivity automatically
Oct 28, 2008 | Gateway Computers & Internet
Dynamic IP address
Dynamic ipaddress - is temporary, the ip changes when you disconnect for example.
Normal, or static ip - It's the same address from day to day.
May 19, 2008 | Computers & Internet
Efficient Networks SpeedStream 5200 Modem Logo
455 people viewed this question
Top Efficient Networks Computers & Internet Experts
Vijay Damaraju
Vijay Damaraju
Level 1 Expert
Michael Galve
Michael Galve
Jax Planet
Jax Planet
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
