I bought a Huawei Wireless gateway Router model E960 through Safaricom Kenya.The router has been functional for close to one year but later on It could not work in my cyber cafe.I tried connecting to many other computers but it could only connect with a high speed computer of 2.6 Ghz .When I connect to a computer it normally prompts me for a pass word which I enter thereafter,it will show that the device is not connected or unavailable then it does not show any network.What could be the problem?
Dionnow
  • 61 Answers
SOURCE: speedstream 6520 wireless gateway not working
I deal with these routers on a daily basis w/ Frontier. Likley the radio is getting hott and its starting to burn out.. Put your hand on the radio, see if its running rather hott. If it is, unplugg it for an hour. If your a frontier customer, call tech support, get it replaced!
Posted on Dec 31, 2007
  • 16 Answers
SOURCE: Hg520s Huawei wireless router
Make sure you LAN settings is looking at your Wireless Adapter for WAN source, your computer might be looking up to the Wired Adapter for source, with not much info that's all i can suggest.
Create a new connections and make sure Wireless Adapter is selected.
Hope this helps
Enjoy
Posted on Apr 30, 2008
Teis
  • 340 Answers
SOURCE: di-524 dlink; wireless laptop connects but no internet or network
Your wireless card is dead, replace.
Posted on Nov 23, 2008
  • 8 Answers
SOURCE: I use 2wire 1701 HG Gateway for 3 computers. I
Hello hopefully ican hel solve your issue i have a 2wire modem myself ans have found that 2wire products are very picky. To answer your question for 2wire products when you try to connect wirelessly it wants you to type in the wep key which is the serial number of the product otherwise you are unable to connect. Now as far as losing your password if you are able to get into the 2wire product via browser so you can bring up the main software page you can try to see if you can get too any info that relates to resetting your info like username and password. Otherwise do a search for your product and search forums and you will most likely find someone that has had to recover there info and they will tell you how they do it. Good luck
Posted on Mar 08, 2009
  • 25 Answers
SOURCE: DIR 615 router. Host computer can not find network.
you have to share file and create a home network.
How will u proceed?
with ur old computer (which using xp )
1.rigth clic on "Computer" icon then left clic on properties> clic on Computer Name tab>modify
so put the name of your network.
At the end it will ask u to restart ur computer
2. open control Panel>Network wizard
go on with network wizard. At the end it will ask u to restart ur computer. then clic yes
This help u to share files with all computer on the network (specified during network wizard )
Posted on Nov 17, 2009
Password lost
i forget my huawei wireless ruoters password
Dec 24, 2013 | Huawei E960 Wireless WIFI Router Hsdpa...
Tip
How to fix Huawei B933/B200 3g gateway router when internet connection is lost
Huawei 3g gateway wireless router model B933 and B200 are among the most accepted wireless broadband router in Asia.
on Jun 09, 2010 | Computers & Internet
My wireless modem is e960
If there is a reset hole at the back insert a small paperclip into the hole and hold it for 30 seconds.
If not try this from a command prompt
First enter the command erase mtd5 (Enter), then reboot (Enter), which will reset the router to its factory default state.
Nov 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Wireless set up problem - no gateway ip or limited connectivity
Connect using Lan Cable
be sure to enable java on your Browser.
Use ONLY IE: some router refuse other browser.
SET your PC on a static IP address on SAME subnet as your router (but of course different IP).
If subnet concept is NOT clear to just just ask here.
When connected with router (on Lan Cable) check every setting (WPA-PSK) TKIP key, Broadcast / Channel etc.
You can also disable every WLAN protection and restore it later.
Activate WLAN connection WHEN you are STILL connected.
Last but not least: SET your DNS IP address = your gateway IP (router)
Feb 07, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Set up wireless internet access using HG1701 2wire router
Check with this tip
Detail on this Wlan Router
"Connect power cord to router.
Wall Plate -> Router (using phone cord).
Router -> PC (using network cable).
  1. Power on router, when the lights settle, start the PC.
  2. Start IE in PC, type 192.168.1.254 in the address bar and press enter.
  3. Start configuring using the Telco's suplied info, namely PPPoE username and password. All other function works by default.
  4. The WEP key is the 10 digit number underneath the router (not the 12 digits S/N number).
Jan 18, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
How to install wireless router (huawei quidway wa1003a)
if you can connect to the internet when you connect the pc to whe lan port , then your internet connection is ok and all you need to set is the wireless settings in the router.
connect the pc to the router with a cable .
then , Start-> Run-> type cmd-> ok-> type ipconfig-> enter-> look on the default gateway address -> type the numbers of the default gateway in the address line in your internet explorer-> there you should check , enable and or change the wireless settings.
Mar 02, 2008 | Computers & Internet
Computers & Internet Logo
107 people viewed this question
David Payne
David Payne
