Question about Hotpoint WMA40 Front Load Washer
When the wash cycle reaches spin, the programme stops. Tripped out circiut breaker. Leaves clothes wet.
  • pepperrell Nov 09, 2010
    I managed to access the waste pipe and cleaned it thoroughly. There was alot of debris. Unfortunately, the programme doesn't seem to work at all now. Where do I locate the pressure switch?
  • Hotpoint Master
  • 19,396 Answers
Hi.
The appliance will not advance to spin until the drain part of the cycle is complete. This problem is commonly caused by faults affecting the drain part of the cycle.
Check drain hose at the back of the appliance.
Access the hose connected to drain pump by removing the fascia trim at the base of the appliance, on the front side. There you will find access to drain pump, rotate and remove the cap; be prepared to collect a good amount of water in there. Open and remove eventual blockage.
Operations are often illustrated in the user manual.
Disconnect power first.
If that does not fix the problem, then parts that must be tested and eventually replaced are pressure switch and door latch.
The pressure switch is the device that detects water level. The pressure switch detects water level and send an impuls to central control unit to advance cycle to spin when there is no more water.
If the pressure switch is malfunctioning, then the machine does not advance to spin.
The pressure switch is difficult to test (you need to read impedance with tub full and empty, or to read volts when cycling. The pressure switch is not an expensive part. It is tested summarily by blowing in the hose attached to the switch and cleaning it. If that does not work, then the switch gets replaced.
The door latch is double checked by timer control before advancing to spin. A defective door latch mechanism or switch may prevent the appliance from advancing to the spin part of the cycle.
Additionally, if the machine trips out circuit breaker whenever the spin part of the cycle is reached, then there may be a short in wiring to motor, a faulty motor control unit, a faulty central control unit, or even a defective motor.
In that case the repair is more complicate, and the technician will need to test all the parts listed above.
At user level, all that can be done is inspecting wiring and looking for burnt spots in wiring to central control unit, or for evident faults that can be seen checking the parts (eg.melting components or wires).
Regards.
Ginko.
Posted on Nov 06, 2010
Whirlpool front load washer (W-WFC7500VW1) was ran through the clean cycle. After this was preformed, the washer will not spin the clothes the dry. The washer will spin but never reaches the 'higher' spin...
I suggest going on the Whirlpool manufacturers website and check their forums for a similar problem. It could very well be something very easy to fix.
Jan 08, 2015 | Whirlpool Washing Machines
Zwp1121p Spinning but clothes still we5 through
Is the spin cycle reaching full spin speed or is it not spinning as fast as it should? If it isn't reaching full speed it could be caused by an uneven load (as this will stop some machines from spinning properly). Towels and items which get very heavy when wet can cause this.
Oct 27, 2013 | Zanussi Washing Machines
I own a Kenmore washer Model 110.22722100. The last couple of weeks, it leaves the clothes wet. It drains like it is supposed to and spins. What is causing this to happen?
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Here is the part you will need.
Nov 28, 2010 | Kenmore Washing Machines
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Spin cycle leaves clothes very wet
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Feb 09, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Front load washer
Only possibilty is that the is still a blockage in the filter area, sump hose or you are using the delicate spin programme. Regards Advisor
Sep 01, 2007 | GE WBVH6240F Front Load Washer
Hotpoint WMA40 Front Load Washer Logo
54 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
