Question about Samsung SP50L6HX 50" DLP HDTV
Hi I have just replaced my lamp and my samsung sp50l6hx tv still keeps going on standby, i switch on the lamp comes on then after 1 or 2 seconds it turns back to standby. could you help thanks
  • Samsung Master
  • 5,138 Answers
Check the Lamp Fan if it stops running when Lamp Lights then Fan is defective.
Samsung Parts.com 1-800-627-4368 If Fan is OK then this meabs you have Good Lamp and Good Ballast board then the problem will be in the DMD moduel.
Posted on Nov 06, 2010
BALLAST PART No FOR A SAMSUNG SP50L6HX PLEASE HELP
Google that model number with ballast or lamp ballast to locate the part and its number. Usually the color wheel will not operate if ballast is not working---Lamp comes on and stays on the Ballast is good.
Nov 06, 2012 | Samsung SP50L6HX 50" DLP HDTV
My tv is only clicking, no picture or sound, why?
The tv projection lamp inside the tv now it is 1 1/2 or 2 years already,tv in used 4 or 5 hrs everyday?Yes,than the tv projection lamp life have ended,require replacement too.The clickings sounds,it is the board that call the Ballast board it is dead too,the clicking sound mean the Ballast board continueing tried to ignite the tv projection lamp.
Jun 14, 2011 | Samsung SP50L6HX 50" DLP HDTV
It keeps going on to standbye every 5 seconds and it changes but it dont stay onmore then 10 seconds what could be causing this
Lamp will be the problem if it has never been replaced.
Mats Electronics sells Lamps 1-800-628-1118
Feb 15, 2011 | Samsung SP50L6HX 50" DLP HDTV
Samsung 50" r p tv switches off
Replace your Lamp BP96-01073A Fox has them $109.00 1-800-227-5369
Dec 29, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung 50" rear projection tv switches off after a few seconds
probably need to replace the Ballast and Power Supply Board. If lamp has not been replaced, I would replace that too. can call 1-800-samsung for nearest service center.
Samsung SP50L6HX, I replaced the Lamp but still nothing.
Hi, Samsung haves a known issue with the ballast, once you make a replacement of the lamp, sometimes its harder to ignite a new lamp that has 100% of gas inside than igniting a old lamp that has maybe 60% or 50% of gas inside. Just in order to ignite the lamp, the ballast needs to send some High Pulses of Voltage, as high as 15 kV (that is the constant clicking sound that you are hearing). In order to resolve this you need to change the Ballast Board. I tried to look for your ballast with your TV Model # at samsungparts.com , but nothing showed up. You will need to find out which ballast part # you have in order to find it online. To locate the ballast part # please check the end of this video, you only need to take the lower back cover of TV off. http://www.youtube.com/watch?v=0jr_9A5Xd2Q
Here is a link of a ballast I found http://www.discount-merchant.com/SAMSUNG-9137-008-08905-Lamp-Ballast-Driver-p/1138231.htm?Click=49915
Dec 24, 2009 | Samsung SP50L6HX 50" DLP HDTV
I have a samsung sp50l6hx which was stuck on stanby flashing lamp timer we have replaced the lamp and have a new ballast board and still nothing is working please help
Go Back make sure you have everything connected I made that mistake and did not have on Ballast Board where that Small 4pin connector goes was not in right had to take a tiny flat head screw driver straighten pins then pushed connector back on TV is working Fine Now! Also CK on left side I had another plugin connector that was not connected back also.
Dec 03, 2009 | Samsung SP50L6HX 50" DLP HDTV
Samsung sp50l6hx stays on stand by will not come on please help !
could be the lamp, ballast, cooling fan or the power supply. can call 1-800-samsung for nearest service center.
Nov 25, 2009 | Samsung SP50L6HX 50" DLP HDTV
No picture, display reads- green lamp, timer, standby, temp samsung 50" dlp
hi your tele light tube has expired or your light which is located at the rear of television
Oct 22, 2009 | Samsung SP50L6HX 50" DLP HDTV
Samsung SP50L6HX 50" DLP HDTV Logo
244 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
