Baxi solo WM 50/4 RS pilot light is lit, Boiler will heat water but not rads have you any ideas thanks sam
Double check that the programmer is calling for the boiler to fire, and also that the thermostat is turned up enough.... you will hear it click as you turn it up... if the radiators still dont get warm...
then In the airing cupboard there should be a pump on a three port valve that says A,B, and AB on the different pipe outlets... It seems that this is possibly stuck in one position.... Sometimes the servo motor on top of the three port valve (square metal box with wires going into it) goes weak and requires replacement, these are not expensive from a decent plumbing spares shop I.e Pts (plumbing trade supplies) and are a doddle to install, just isolate power to it, take square the top cover off the valve to reveal the innards and you will see it straight away... Like a round brass cylinder with a flat top... It should have two screws holding it in...
Hope this helps
Thanks
Steve
Posted on Oct 22, 2013
burty681
  • 56 Answers
SOURCE: i have an ideal mexico
its your gas valve that need replacing
Posted on Feb 01, 2011
  • 13 Answers
SOURCE: Vaillant boiler (VCW GB 221)
The movement of the diverter valve is critical on this appliance, and is located on rear right of the boiler, when hot water is turned on, theres are two microswitches, which must break (they both close in Central heating mode), if pump is running, it is recognising the hot water demand, check microswitches are breaking, if not, it tends to be a defective servo valve (located above the water valve), or a blocked/ restricted control line (small copper tubes which connect into the servo valve)
Posted on Mar 03, 2009
  • 1015 Answers
SOURCE: baxi solo pfl60 problem. the
One thing I would check is the flame sensor. Your boiler may not have this on it but I have seen them act like this before. If you have one I would replace it. Hope this is ofsome help. Thanks
Posted on Nov 26, 2010
burty681
  • 56 Answers
SOURCE: instructions on how to re
http://www.baxi.co.uk/products/bermuda-back-boiler-unit.htm?view=download , i hope that will help
Posted on Feb 16, 2011
walterkunesk
  • 683 Answers
SOURCE: I HAVE A BAXI LPG
does the gas valve have a thermocouple in it, probaly thin copper tube, let me know.
Posted on Feb 24, 2011
Have a Baxi solo boiler 340PF, have hot water but no heating, pilot light will not stay on. how do I fix it so I get heating please?
it might be the thermal coupler....it is a piece of wire that goes from the pilot to the thermostat. very inexpensive. .I am a 50 yr old woman, and I changed mine on my furnace twice..Home Depot or equivalent should be able to help. Google "thermal coupler"
Jan 22, 2013 | Water Heaters
Hiya. I have an old baxi boiler wm 38/RS . The pilot light is on but the boiler will not fire up . Can u help me
Rubbish!
Cleaning the jet is a job ONLY for a gas fitter as it involves disturbing both the case seals and the gas pipework. DON'T RISK YOUR SAFETY, besides which if the pilot wasn't powerful enough it would continually go out.
Check (if you're competant to do so) that there's 240vac across the gas valve solenoid connections. If so then the gas valve will need replacing by a GAS SAFE REGISTERED fitter.
FYV
Jan 18, 2013 | Combi Centre DX - Mango
WHY CAN I GET HOT WATER BUT THE RADIATORS WONT HEAT UP- BAXI SOLO 2PF SYSTEM?
check the pump see if this is working and the rads are open
Oct 05, 2012 | Heating & Cooling
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
I have a Baxi WM old boiler. Hot water only needed
there should be a switch which toggles between hot water only /// hot water + central heating /// & possible off on
Either on the boiler or on a separate timer control
Oct 19, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
Baxi 3 Solo Boiler will not ignite
it could just be the presure switch try bridging it out and see if burner lights
Sep 10, 2009 | M20 X-Treme Radar Detector
Baxi solo 2 30pf will not fire up.. please help!
first off ensure water is getting to boiler, next, No pilot = pressure switch. On my baxi solo 40 pf pressure switch is replaced 8-10 times a year cures your problems,,,,,,,, momentarily , and have had all your other parts,but with no effect to speak of,.......sorry............ solution = [ change boiler ].sounds like gas pressure or lack of water to system or **** boiler like mine .........good luck.
May 15, 2009 | Water Heaters
How to light pilot light on back boiler?
Hi. we have a baxi bermuda. I know that you need to hold in the silver button on the left while repeatedly pressing red/ignighter button until pilot is lit. Hold in the silver button for at least another 30 seconds.
Good luck, ours wont light anymore so was on here looking for advice.
Cheryl
May 07, 2009 | Kitchen Ranges
Baxi Boiler not firing, pilot light ok
first check the pilot is alight, it sounds like it is cause you can hear the boiler click. that click is the gas vale solenoid trying to open, if there is 240-230volts at gas valve when you here the click and pilot is alight the gas valve is broken. if you test for voltage look on the gas valve and see if its 240 or 24v obviously if it 24 v check for 24 volts, let me know
Nov 11, 2008 | Combi Centre DX - Mango
Boiler overheating
the problem there a relay stuck or thermostat bring on the pump & you can lower your high limit aquastat!! also the flow valves can bypass hot hot water risers time to put in a seperate water heater domestic coil are not energy efficient !!!! aquastat high limit set @ 180f deg low limit set @ 140f deg!!!
good luck!!! tim
Oct 08, 2008 | Water Heaters
Heating & Cooling Logo
164 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
