Question about Epson RX595 Photo All-In-One Printer
USB plug in Epson Printer RX595
I've had this printer about 7 months now and it has had an intermittent problem since day one.  It would occasionally, when turned on, put a multi plug icon on the taskbar and the printer would not function. Checking for the driver, it would state none was installed.  Checking in Windows device manager it would state " Unknown Device " .Turning off the printer and turning it on would not work and only when turning off the computer for the night and rebooting the next day then trying the printer again would it start to function again. Even rebooting when the problem occurred would not work. I uninstalled the driver and went to the Epson web site for the most current driver and installed.  There was no change.  I've put up with this and finally this past week contacted Epson looking for a solution.  Their advice, replace the driver.  I was kind of reluctant and held off for a few days thinking it might make things worse as the installed driver is the most current.  Yesterday I took their advice and now the printer does not work at all. My operating system is Windows XP Pro.  The RX595 is USB direct connect with no hub.  I purchased a new USB cable, no change.  I disconnected all USB devices on my computer and tried printer, no change.  I changed all devices USB inputs and everything works no matter where it is plugged in with the exception of the Epson RX595. I read that XP  creates a virtual port named "USB printing support",for USB Printers  whenever you switch on the printer. now what  might be happening is that whenever I switch on the printer, XP creates the virtual port again and can't find the drivers for it to work with. I can't come up with a solution.  Any consideration and advice you can offer would be much appreciated. I thank you. frdf
  • Anonymous Feb 03, 2009
    Printer would not print- states computer cannot find printer
  • Epson Master
  • 1,879 Answers
Assuming you properly installed the "printer driver".
disconnect the printer.
check Printer & Faxes for printer icon(s) - delete print queue(s) and the printer icon(s).
open device manager and go to Universal Serial Bus Controllers section.
now we check for connectivity: (treat the printer and scanner as separate devices)
connect the printer, USB Printing support must show up (also check Imaging Devices and the scanner must also show up)
IF USB Printing support shows, windows will create a printer icon in the Printers & Faxes, right click choose properties and print a test page.
ELSE, it's the printer and request for a replacement if it is still within 1 year from the date of purchase
Posted on Feb 26, 2009
Epson workforce 840 all-in-one. Driver installation fails.
Check the compatibility of the driver with the OS version:Windows 8 (32 or 64 bits), Windows 7 (32 bits or 64 bits) , Vista (32 b, 64 b), XP (32 bits , 64 bits). You should try to use the software that shipped with the printer. When installing, choose local printer (USB), or Network (Ethernet cable, or Wireless).
Oct 31, 2013 | Epson RX595 Photo All-In-One Printer
EPSON R545 waste ink saturated
You need to reset your printer. Goolgle search for "indoreset for rx595" and download it. That is the program you need to use to reset the waste ink pad counter back to zero.
Jul 20, 2010 | Epson Office Equipment & Supplies
What must i do to install my epson rx595 printer to my computer
My computers CD loader is " KAPUT ". Is there a way to load my printer [ Epson RX595 ] over the internet ?
May 19, 2010 | Epson RX595 Photo All-In-One Printer
Windows 7 is not recognizing me Epson RX595
The following steps may help:
  1. Remove all the drivers and software installed for this printer.
  2. Restart your computer.
  3. Click here to go to the driver download page. Download the driver for Win 7 and install.
  4. Connect the printer to your PC, the installation will continue.
  5. After installation, you should be able to use your printer.
Nov 03, 2009 | Epson RX595 Photo All-In-One Printer
Epson RX595 prints "wet" on non epson paper
the reaction of the photo chemicals that are on the paper cannot be guaranteed by the printer manufacturer as they have no knowledge of its composition.
3rd party photo paper manufacturers have better compatibility results.
epson for epson, kodak for kodak, hp for hp
Apr 09, 2009 | Epson RX595 Photo All-In-One Printer
Epson 595 COMMUNICATION ERROR message
HI
Check the USB cable if connected properly from the backl of printer and from back of computer. check under device manager under universal serial bus controller connection problem.
Hope this helps
Nov 15, 2008 | Epson RX595 Photo All-In-One Printer
The epson printer driver dealing with cd printing is not installed
# Select Print from the File menu.
If you see the message The Epson Printer Driver dealing with CD printing is not installed, click OK.
# Click Tray, select Tray 2, then click OK.
Note: If Tray 2 is not selected, the CD design will print in the wrong position.
# Click Manual Print.
# Make sure Epson Stylus Photo R(your model) is selected.
# Under Paper, select the following settings:
* Source: Manual
* Size: A4
# Click Properties.
# Select CD/DVD or CD/DVD Premium Surface for the Media Type setting.
# Click OK, then click OK again to print.
Oct 18, 2008 | Epson RX595 Photo All-In-One Printer
Epson RX595 Photo All-In-One Printer Logo
313 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
