My CD player is not working. tried lens cleaning many times but quite unsuccessful. need a service outlet
    Problem Solver:
  • 12 Answers
Kkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk.
Posted on Nov 06, 2010
My cd player is sayin disc error everytime i put a disc in it
Hi and welcome to FixYa, I am kelly
First try using a cleaning system CD to make sure the laser window is clean and to see if it will snap out of the current symptom.. You will get this error when either infra red eye of the laser quits, the ribbon from the laser head to the electronic PCB fails or the PCB itself fails. Most of the time it is either the Laser or the ribbon that fails. The bottom line is this: "Unless cleaning it makes it work.... your going to be shopping for a new CD player because the cost to repair it is nearly equal to the total replacement cost."
Thanks for choosing FixYa,
Kelly
Mar 02, 2011 | Chrysler Concorde Cars & Trucks
MY cd is not working it shows disc error
hi,check first if your CD format is compatible with your player such as audio CD,mp3,VCD,DVD.etc.
If the CD plays on your player before then that is a lens issue this probably needs cleaning and if cleaning dont work then it's time to replace the lens of the player..and replacing the lens requires skills and proper tools I would suggest to bring your player to a qualified service personnel thanks and good good luck!
Dec 24, 2010 | Samsung HT-TZ312 Theater System
My 5 Disk CD player doesn't work. It wont read any kind of CD. The radio and Tape Decks still work though. How can I fix the CD player.
Hello Alison hi, we need to check two parts to see which is the problem section why your player wont read.
  1. Does your CD spins normally, check your player if the cd spins normally, if you can see the disk spinning, take note of the spin, is it to slow? An abnormal disk spin has problems with its spindle motor assembly.
  2. Does your CD spins and then slow down to a stops, did not read the disk. This is caused by two things, FIRST: your CD player lens needs cleaning, you can buy a CD lens cleaner and use it to clean the lens, SECOND: The lens has degraded or worn out due to use and time, this needs a replacement lens assembly.
This things are way beyond a normal user, I suggest you send it for service. Sorry, there are no user serviceable parts here.
Aug 19, 2010 | RCA RS1285 CD Shelf System
My girls princess disney cd player keeps saying that there is no cd in the player. I have no idea what's wrong with it.
the laser lens is most likely dirty, buy a cleaning disk, or use a microfiber cloth or eyeglasses cleaning cloth and gently wipe the lens in one direction to clean it. the lens will look like a small round clear piece of glass near the motor that spins the cd, if this doesnt work, then the laser has quit working
Jan 14, 2010 | Disney Princess Portable CD Player...
5 disc cd changer CC4000 will not read
All players need cleaned from time totime. Do NOT try to clean it with anything other than a CD / DVD lens cleaner. They are available almost everywhere that sellsBlank media. It will clean the lens without scratching or smearing it.
Dec 06, 2009 | Marantz CC-4000 5-Disc CD Changer
When Making A CD To Play On My technics SL-PD8 It
If thhis happens quite often , and does not depend on the media, then it is usually a dirty lens problem. The lens is dirty or scratched and sometimes cannot read CD TOC (table of content).
If this happens only on reocrded CDs , try changing the media used. For example if you used +R, try with -R.
If this happens on all media, then try cleaning the lens with a lens cleaner CD or blowing some canned air on the lens.
See: CD and DVD Lens Cleaner...
May 02, 2009 | Technics SL-PD8 5-Disc CD Changer
CD Playerr not working properly.
hi, have you tried to clean the lens of the unit?
chris
Feb 14, 2009 | Eclipse Premium 34230 Car Audio Amplifier
Tried unsuccessfully to remedy disc problem, most do not play It does not recognize disc are there (NO DISC) message is dis- played. Could it need some sort of cleaner as acetone? RCA Mod # 9345, 3 disc...
That means that the lens must be cleaned or replaced.
If you use acetone on the lens, you will damage it.
First tru cleaning the lens by using a lens cleaner cd a couple of times.
If that does not work, you need to use Isopropyl Alcohol directly on the lens.
If not even Isopropyl Alcohol worked, then you need to have the lens pickup replaced.
Dec 20, 2008 | Televison & Video
Disc reading
hi there
long reading time for cds or dvds only means that there might be dust or residues hindering your cd lens to accurately read the data of the cd/dvd. what you can do is try to clean the lens with a cd cleaner.always check the cd/dvd that you insert are clean and fre of dust . if this still wont work and the player still have the long time to read the cd/dvds, my advise is to bring this to a service center and have this checked out.
hope this helps.
Feb 05, 2008 | Samsung HTQ45 System
Every CD is skipping
If the cleaning cd does not work, try unplugging the player, taking the back cover off and manually cleaning the lens with cotton wool or cotton buds. If there is a stubborn smear on the lens, try methylated spirits on the cotton wool. Please note the following: Don't lose any screws You may need to take additional pieces of metal or plastic off to get at the lens; do not lose these or the screws that hold them and make sure they go back in the right order DO NOT TOUCH THE LENS WITH YOUR HANDS OR ANYTHING NOT CONSISTING OF COTTON WOOL OR METHYLATED SPIRITS! The lens will be quite fragile-do not apply excessive pressure Ensure everything goes back together the way it was, minus dust and dirt. hope this helps. stoodleysnow P.S. You can get methylated spirits at a local hardware or diy shop, or occasionally art shop.
Aug 30, 2006 | Teac PD-H300 CD Player
14 people viewed this question
 Grubhead
Grubhead
