Printer error msg: Print Cartridges missing or not detected. Was working fine yesterday. Blank in cartridge new, color cartridge has plenty of ink. I have turned it off and restarted both at the rpinter and at the power strip.
  • Anonymous Apr 29, 2009
    same as described
This printer is a C4200 All in One Series Printer/Scanner
Posted on Jun 14, 2008
Error message on printer:
Unplug from the wall, press power button three times, plug back in. After trying all other solutions, this one worked.
Aug 01, 2010 | HP Photosmart C4580 All-in-One InkJet...
Bought new ink, black not working
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 06, 2010 | Epson Stylus NX300 All-In-One InkJet...
Brand new Print cartriges not being detected...
If 350 & 351 are the original cartridge, you can ask to the cartridge seller for a guarantee. There is a chip inside the cartridge, sometimes the printer firmware failed to detect the chips. Or you can try to find, by Googling "C4272 Resetter Software" to download it.
Sep 06, 2009 | HP PhotoSmart C4180 All-in-One Color...
I am getting an error msg "U052" and I am using original canon ink cartridges and I cannot pring anything. . .
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
Aug 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
HP Officejet printer, says cartridges are missing or not detected
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr11
Aug 13, 2009 | HP Officejet 5610 All-In-One InkJet...
Having problems printing after changing ink cartridges.......scanner and copier work fine.....when send the command to print from the computer...it pulls the paper and sounds like it's printing but just...
PREM
Apr 06, 2009 | HP PSC 1210 All-In-One InkJet Printer
Dell A960 printing blank pages
I just sprayed windex on bottom of cartridge several times and wiped with paper towel until dark streak of black appeared. Then I dried off cartridge and replaced. It works now. Must have been clogged.
Nov 18, 2008 | Dell A960 All-In-One InkJet Printer
Printer reads RIGHT CARTRIDGE INCORRECT
If you have purchased the cartridges directly from dell , it will be covered under warranty for 2 years for hardware errors and you can call dell on 1800 624 9896 and get the cartridge replaced , even after the replacement of the cartridges if you have the similar issue then its an issue with the printer and needs to be replaced.
Jun 24, 2008 | Dell 922 All-In-One InkJet Printer
Dell All-in-one 924 error: "right cartridge is incorrect"
Hi ,
if you are getting the error msg 12203 , pperform the following steps,
remove both the cartridges from the printer and unplug the power adapter ( black box) from the back panel of the printer, clean the cartridges using a damp cloth .
initially put only the black cartridge and then turn on the system , it will give you the error msg right cartridge missing, you can ignore it and try copying a document .
remove the black cartridge and put the color one in, and then try printing.
during the printing with any of the cartridge inside the printer if it gives out the error msg 1203 then that cartridge has to be replaced...
Mar 05, 2008 | Dell 924 All-in-One InkJet Printer
HP Deskjet D2360 Printer
Cartridges have small electrical contacts. It sounds as though either the cartridge is faulty or it may have got stuck in the wrong place.
Firstly turn off the printer.
If you are using it with a computer via a usb connector, disconnect the lead from the printer.
Disconnect the power lead from the printer.
Lift the lid to gain access to the cartridges.
Ensure they move freely along the track from right to left.
Remove the cartridges and re-insert them one at a time.
Close the lid, reconnect the power lead and USB connector.
Switch the printer back on.
If you are using it with a PC, your computer should automatically detect it after a few seconds. If it doesn't then restart your PC.
If this does not clear the problem, try new cartridges. If it still does not work, the printer may have a control fault.
Hope it works, good luck!
Jan 22, 2008 | HP Deskjet D2360 InkJet Printer
936 people viewed this question
k24674
