Question about SK Paslode Sk312 Framing Nailer O`ring Parts Kit
Paslode framing gun will only fire a nail when in upright position
  • MARK SMITH Nov 06, 2010
    Thanks. Just the job.
    President:
  • SK Master
  • 1,388 Answers
Problems with safety foot/ trigger will prevent gun from firing. Simple test, to discover issue. Remove nails for safety, remove trigger and dry fire gun by directly pressing trigger pin in various positions. If gun fires as needed, examine safety foot /trigger for parts needing adjustment / replacement. Second test, remove nails and disconnect air. Move gun from upright position to upside down and listen for movement of parts within gun. If you hear or feel parts moving inside of gun, orings are too loose. Parts inside of gun should not move and be well lubed with silicone paste (sold at lowes in the plumbing dept. used for faucet orings). Good luck.
Posted on Nov 06, 2010
Paslode framing nailer: compressor powered, hisses but will not shoot nails, appears to be in the sliding mechanizism that touches the wood first before it will shoot, help
I've used paslode for years and whenever there was a "hiss" of air and no fire- it was o-rings- When were the o-rings changed last? And how do you know they are in 'good shape'? You can't tell by just looking at them. If that isn't the problem then I can't help. Just as an aside- do you oil the gun (down the air intake nipple) every time you use it? Lack of oil will wear out o-rings fast. Sorry if this isn't overly helpfull but most gun problems are o-ring or seal related unless you've worn out or damaged a mechanical part.
Feb 10, 2013 | Air Tools & Compressors
Jammed
Make sure that you are using the correct angle nails and head type,,,some use clipped head , others full head,,,others offset full head
Feb 09, 2013 | SK Paslode Sk312 Framing Nailer O`ring...
Paslode nail gun 325 black not firing
Any time these guns become intermittent or stop firing but the fan still runs, the first the to check is the expiration date on the gas cartridges. The do expire and this will make the gun work inconsistently or not at all.
Dec 08, 2009 | RTO PasLode 900420 Impulse Framing Nailer
My finish nail guns, 16 ga won't fire.
There is a little plastic piece inside above the trigger...usually this breaks. It touches a microswitch when the cylinder is closed all the way, allowing the nail to fire.
Oct 04, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Nail comes out another hole
are you using the right nails and are they inserted properly if this is an angle gun? Also look for a jammed nail that might be causing this. look at the magazine bolts to make sure they are tight. You can go to Paslode.com for the owners manual and troubleshooting guide.
Sep 10, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode 350 wont fire
Probably needs cleaning. You`ll need two new o`rings.
Aug 19, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode air framer not sinking some nails
Your air pressure is dropping everytime you fire. It sound like your compressor is not cutting back in untill it to low. Not giving your tool enough continuess pressure. Your compressor cut in pressure should be around 90-100psi no less. and your max. pressure no more then 120psi. (Make sure your regulator is set at 110psi)
good luck...!
Aug 11, 2009 | RTO Paslode #650027 2500CT Placement Nail
Nail gun
have you activated the fuel cell by pressing the black nozzle down onto the cylinder?
Jul 27, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode nail gun not firing
Yes you need to oil driver blade piston.
You need to check for spark. With no nail or gas in it. Take of main cylinder(4bolts on top, 2 bolts on nose. And then put in battery. And then push upper switch(behind roller at top) and the fan will come on. And then pull the trigger. You should have spark.
Thanks,
Jeff
May 16, 2009 | RTO PasLode 900420 Impulse Framing Nailer
SK Paslode Sk312 Framing Nailer O`ring Parts Kit Logo
227 people viewed this question
Top SK Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a SK Air Tool and Compressor Expert? Answer questions, earn points and help others
