Question about Microsoft Xbox 360 Console
Fourth player light on console flashing red, not working.
    Sergeant:
  • 389 Answers
I CAN FIX IT! There are links that show you how to repair this issue yourself (but they are not very clear and every thing is very fragile inside the XBOX 360) or you can contact me via reply on here and we can discuss the issue further as I recently repaired my XBOX 360 with the same issues and it works better than when was brand new. It is a heat sync problem that has to be repaired by someone with indepth electronics knowledge.
Posted on Nov 12, 2010
Testimonial: "thank you i will be in contact "
  • Stormi  Paulk
    Stormi Paulk Nov 18, 2010
    YQW and I actually located all the links where I got my repair parts if you need them for your xbox...
  • Wickedwisdom Nov 19, 2010
    4 Red lights means your av cables, check to make sure the AV cable's are connected. If they are, unplug the Xbox's power. Unplug the AV Cables from the Xbox and the TV. Reconnect them all back. If still nothing, try using a different AV cable.
My xbox360 will not turn on and my battery pack is red, what are my options?
no doubt the battery pack has failed . we can not assist you in buying a new one
Feb 03, 2017 | Microsoft Xbox Video Game Consoles & Games
Tip
XBox360 error codes (Three Red Lights of Death, Red Ring of Death, X-Clamp)
Hi.
XBox 360 error codes are displayed with flashing lights in the ring of bi-color LEDs located around the start button, like in the picture below:
They are often called lights of death. The technical name from Microsoft is Light codes.
LEDs located around the start button can be green or red. When they get red it means that there is a problem.
When the XBox is operating normally The leds will be green. The number of green segments indicates the number of controllers connected to the Xbox.
Here a working Xbox with one and four controllers connected to the console:
If the lights are red instead of green, then there is a problem. Here the four common error codes:
A: The code in picture A, with only one red segment on and flashing on the fourth quadrant, means that there had been an hardware failure. The internal component failing is often not specified.
The light code is accompained by an error message on display, telling a numeric code that can better address the cause of the fault. The best thing to do is contacting Microsoft to find out the reason for the code. Depending on the code you may also be asked to perform a secondary error code retrieval procedure.
In the Example above E74 means that there is an hardware fault on video connections or GPU.
B: If the first and fourth quadrant LEDs are on, that means that there had been overheating. Internal fans, CPU and board must be tested.
C: General hardware failure. This means that the console detected an internal failure, but no error code is displayed on screen. Call Microsoft to get instructions on detecting secondary code or sending the console for repair.This error code is commonly called Three Lights of Death.
D: The last error means that there is a problem with the AV connection to the monitor or TV. The code is not displayed if you use HDMI connection, in that case you get an on-screen error code. Test using different cables. If that does not fix the problem, this error means that the XBox Gpu is fried. This error code is commonly called Red Ring of Death or RROD.
In the near future I plan to publish a new article explaining how to troubleshoot secondary error codes. In the meanwhile, if you need more support, you can ask a question to our experts or contact Microsoft.
Regards.
on Apr 08, 2010 | Microsoft Xbox 360 Console
I have a red light on the fourth player spot
Remove all the cables (composite/component, power, you know, anything that plugs into the console) and let it sit for a minute or so. Plug everything back in. If it still doesn't work, remove the hard drive and attempt to start the xbox. If it works, the problem is with your hard drive. If it doesn't work, the problem is with the xbox itself. Regardless, you'll have to contact xbox customer support to fix either of these problems.
Aug 23, 2011 | Microsoft Xbox 360 Console
I have a prblem with my xbox 360
This is a sign that your 360 is overheating. I would try to get some air going through it to let get rid of the heat. Check the vent holes around the 360 to be sure nothing is blocking it. Be sure it is off any carpet or that nothing loose is under it(paper,plastics).
If it continues it may be that the fan is becoming loose. How old is the 360 you have??
Jun 04, 2010 | Microsoft Xbox 360 Console
How do i get my red eye fixed
First make sure how many lights are red, red ring of death with light up the player 1,3,and 4 slots. If all 4 are glowing try an av cable (sometimes rrd will look like all 4 are lit but look carefully and often the fourth slot is only reflected light). next log onto http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair and enter your console information. If the rrd warranty is still active, they will repair it for free (rrd is warranteed far beyond the normal console warranty, so be sure to try this before opening your console).
Mar 01, 2010 | Microsoft Xbox 360 Console
I have an xbox360 and it has a red light in the fourth player slot
E68 error message? If so, turn off system, take off hard drive, put hard drive back on, turn system back on.
Feb 19, 2010 | Microsoft Xbox 360 Pro System Console
One red light
this is a video error. Your creen should say E74. I can't stress this enough you shold do the x-clamp fix
Jul 11, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
143 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
