Question about Casio Parts Cash Register PC Desktop
My cash register is showing e-4 cannot off the machine from off position and i want initialize the cash register ,how to do it
  • 43 Answers
E-4 means different things on different casio models...need to know the model number to help you out further
Posted on Dec 05, 2010
I have a sams 45 cash register making a noise and showing an error cade Elo0000
The E00 code on your SAM4S cash register indicates a Sequence Error.
You can try an Initial Clear to reset the error:
1. Turn the power switch located on the right side of the register to the OFF position.
2. Turn the control lock to the P position.
3. Press and hold the key position where the SBTL key is located on the default keyboard layout.
4. While continuing to hold the SBTL key, turn the power switch to the ON position.
5. The message "INITIAL CLEAR OK!" prints when the initial clear is complete.
You may have to try the Initial Clear procedure a few times to clear the E00 error.
Jan 08, 2018 | Retail Supplies
Return Sharp XE-A102 cash register to factory settings
MASTER RESET
Master reset: Clears all the memory and initializes each preset parameter. The master reset should be performed by using the following procedure.
1. Turn off the power (Power OFF). (See Note 1.)
2. Remove the memory back up battery from ECR.
3. Turn the mode switch to any position other than Power OFF.
4. Turn on the power (Power ON). (See Note 2.) When the master rest is completed, the buzzer sounds three times.
5. Install the memory back up batteries back into the ECR. The master reset can also be accomplished in the following case. (See Note 3.)
Note 1) Power OFF: Means disconnecting the AC power supply to the machine. (Specifically, unplugging the machine.)
Note 2) Power ON: Means connecting the AC power to the machine. (Specifically, plugging in the machine.)
Note 3) In case a power failure occurs when the machine has no battery installed, the master reset operation is automatically performed after the power has been restored.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 05, 2016 | Sharp XE-A102 Cash Register
PEA is on the screen and no keys work
stuck splash screen Cash Registers & POS Equipment ...
www.fixya.com > Forum > Tags > stuck splash screen
Ask your stuck splash screen cash register and pos equipment questions. ... ...screen displays PE, machine stops working Register tape won't feed, turning it off then back on ... the register is stuck and is displaying PEA Perfom a master reset ... Screenstuck on x2/z2 turn the key and it stays on x2/z2 no matter key position.
delay stuck Cash Registers & POS Equipment Questions ...
www.fixya.com > Forum > Tags > delay stuck
Cash Registers & POS Equipment delay stuck questions and answers. Ask your delay stuck ... Also if that doesn't work and its a dual com, make sure its set to dial. coppy ... Ad ... the register is stuck and is displaying PEA Perfom a master reset ...Screen stuck on x2/z2 turn the key and it stays on x2/z2 no matter key position.
Hi There my SAM4S is showing PEA on the screen. All the ...
Nov 26, 2015 | Retail Supplies
I have a Royal 9155SC register. The display shows 0.00 and no key is working with continuous beeping. Please help.
Half Sysem Clear
a. Turn the key to the "PRG" position.
b. Unplug the cash register from the power source (pause
for 10 seconds) and replug the cash register.
c. Continue with normal operations.
Full System Clear
!!! THIS WILL ERASE ALL PROGRAMMING AND DATA!!!
a. Turn the key to the "PRG" Position.
b. Unplug the cash register from the power source and wait
at least 15 seconds.
c. While holding down the [CLEAR] key, replug the cash
register.
d. Re-program the cash register.
e. Continue with normal operations.
Oct 28, 2014 | Royal Office Equipment & Supplies
How do I load the IPL to a CASIO TE-2400?
that is the correct way . Maybe you need to activate sdcard option on the new machine it could be off
Apr 30, 2014 | Retail Supplies
Cash buttons don't work
Reset the machine (initial clear) reprogram again. good luck
Nov 06, 2013 | Casio TE-2400 Electronic Cash Register
What does i have to do when the register show e046 reg buffer full please finalize or nb
Hi.
It means the registration buffer is full. This is where the machine stores the products in the current sale. It means that the customer is purchasing so many items that it has filled the memory for the current sale. You need to do the sale in 2 parts if this happens. pay for the sale so far with a payment button e.g CASH CREDIT etc, then put the rest of their items into the next sale and pay for that.
If this problem happens often, then you need to open more memory which is not always easy as it is an initial dealer setting. see how you get on.
Mark
Jul 16, 2009 | Casio Parts Cash Register PC Desktop
Sharp electronic cash register XE-A203 - keeps printing receipt
I don't have this particular cash register, But I took a look at the manual and I recommend the following:
A. Turn the cash register off.
B. Unplug it.
C. Remove the batteries.
D. Wait at least five minutes.
E. Initialize the cash register. This procedure was copied from thwe manual:
In order to operate the cash register properly, you must initialize it before operating for the first time. Follow this
procedure.
1. Insert the manager (MA) key into the mode switch and turn it to the REG position.
2. Insert the plug of the AC power cord into the AC outlet. The buzzer will sound
three times.
IMPORTANT: This operation must be performed without batteries installed.
3.
The cash register has now been initialized. The register display will show
"0.00" and then “NO BATTERY”.
If the buzzer does not sound when the plug is inserted, the initialization has not been done
successfully. (This will occur when the voltage is high because you operated the cash register
before starting initialization.) Wait at least one minute after pulling out the plug and insert the plug
again.
F. Download trhe manual from here:
http://www.ormsson.is/skjol//skrifstofutaeki/xe-a203,213,303_manual.pdf
And proceed to program your sales tax (or VAT), departments, clerks, etc.
Jan 25, 2009 | Office Equipment & Supplies
Casio Parts Cash Register PC Desktop Logo
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
