Need help I have a Panasonic DMR-ES35V dvd/vhs combo and everytime I press a button on the remote it says set 1. What do I do?
I have the same model, i pressed Function key(on remote), enter, using up and down arrow keys, select Setup, Remote control code, press 1,2 or 3, then enter. The code on the unit has been set. You must use the same code for the remote control by pressing enter and hold for about 2 seconds at the same time pressing corresponding 1,2 or 3 you selected for unit. This makes the unit and remote compatible with each other. you only change this code if you have other panasonic products that respond to this same remote control. hope that helps.
Posted on Nov 30, 2008
Panasonic Model No. DMR-ES35V DVD Recorder error message H02
check it out this link, maybe can help you https://www.ifixit.com/Guide/Repairing+a+Panasonic+SA-HT810V+with+the+H02-H07+error/2708
Try to clean reading head from vhs player with isopropilic alcohol, maybe is dirt and give this error.
Good luck !
Dec 03, 2017 | Panasonic Dmr-es35vs DVD Recorder / Vcr...
Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ47VK
http://www.retrevo.com/support/Panasonic-DMR-EZ47-DVD-Players-manual/id/2811ag420/t/2/
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DVD VHS combo DMR-EZ48V will not play region 1 dvd
This is happening because your DVD is NOT all region, you need to change the Code.
en.wikipedia.org/wiki/DVD_region_code -
www.dvdexploder.com/ -
www.dvdexploder.com/multihacks.htm
www.allformp3.com/dvd-copy.../dvd-region-code- free.htm -
www.dvd.reviewer.co.uk/info/multiregion/ -
Ok check those links out they will help you sort it.
Apr 01, 2010 | Panasonic DMR-ES40VS DVD Recorder/VCR
My panasonic remote won't work. the lcd on the dvd shows set 1 everytime I click on it
I have had this happen nore than once. If you press the 1 button and hold it down. At same time press and hold the enter button for 2 or more seconds. Your remote will now be set to the system. Some models have a device code of 2 or 3. If your not sure what your device code is start with #1 device code.
Oct 13, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
WHEN I TRY TO USE MY REMOTE CONTROL ON MY PANASONIC VCR/DVD COMBO MODEL #DMR ES35V, THE DISPLAY SHOWS U30 1 AND WON'T WORK THE VCR/DVD. CAN YOU HELP ME?
I called tech support and their answer was simple!
Error Code U30 1.......the fix, press and hold the number one (1) on your remote and at the same time press and hold the ENTER button for 10 seconds while pointing the remote at the units sensor.
Automatically, my unit returned to normal and all my buttons on my remote returned to operational mode!
So, it was confirmed by Vincent at Panasonics tech support, that error codes U30's are rare, but it's a system safety feature. If you were to come across an error U30 2, you would push and hold the number 2 while pressing and holding down the ENTER button....so on and so forth.
I hope this helps someone else out there!
Shelley
Oct 11, 2008 | Panasonic DMR-ES35VS
Panasonic dmr-es35v
Is the Remote Control sensor in direct fluorescent lamp light or other strong
sources of light?
Press unit POWER button down over 7 seconds. The POWER indicator goes
out. If the Power was On, the screen will also disappear. After 5 seconds, turn
Power On and operate unit normally. If the steps above do not restore normal
operation, disconnect then reconnect the AC plug and turn the power On.
If that does not work, Panasonic offers free tech support 6 days a week 1-800-211-7262 (pana).
Jul 29, 2008 | Panasonic DMR-ES35VS
IS MY DVD COMBO REGION FREE
Yes the Panasonic DMR-ES35V is a multi region player.
Jan 01, 2008 | Panasonic DVD-S35 DVD Player
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
Electro Med Services...
