Question about Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis no heat
My dryer is running fine, but it doesn't produce any heat. What is the matter with it?
  • 66 Answers
Would go for thermostat usally situated around heater this is the cheapest option if not then it will be the element unplug machine first good luck
Posted on Jun 14, 2008
Dryer doesn't shut off and doesn't get hot
Look at this video to help you fix the no heat issue.
Nov 14, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis MDE6400AY timer works but dryer doesn't come on
First thin I would try is to check your thermal fuse for continuity with a ohm meter with the wires removed from the fuse and the dryer unplugged. Its located on the tunnel that in cases the heating element.
Here is the part in case you find it bad.
Oct 31, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
My dryer is not heating up. The ignitor glows but the gas does not ignite. I took of the front lower panel and watched it. It doesn't ignite. The gas line is fine. What can it be?
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 21, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
My gas dryer stopped producing heat produce heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 28, 2010 | Maytag Atlantis MDE7400A Gas Dryer
Dryer produces heat, but clothes don't dry
Sounds like the vent has a lint build up inside of it. A moister sensor detects any lint build up and keeps the heat in check. The dryer will produce very little heat this was. Clean the entire venting tubing and it shall run better for you
Jul 08, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Tumbler turns, but no heat. gas line is open and looks good... what might be the problem?
Upon starting the dryer you should hear the clicking noise of the spark ignitor. If heard that is fine. Next remove all exhaust vent tubing and clean out thoroughly. The moister sensor detects any lint build up and will put the heat burner into a check mode untill the lint build up is removed. It was designed to prevent fires to start. If cleaned and still does not produce any heat replace that moister sensor
Jun 19, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag gas atlantis dryer. It starts but after a
I love the Maytag Atlantis!!! This sounds like your motor may be bad. It's NOT the element or it would not heat at all. Hope this helps!
Aug 13, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag atlantis gas dryer, will start, heat up but then no heat
Try running it with the vent disconnected and feel the air coming out of the dryer. It should have good flow. If it dries good, your pipe may be clogged.
Mar 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis electric dryer
Sounds like the moisture sensor has gone away. Not sure where it is located on this model, though.
Dec 01, 2007 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MAV6451 Top Load Washer Logo
52 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
