Hi
there,
My name is Mike. A couple times a day I go looking around
to give some pointers to our clients (you).
Look at it your
question from our point of view, it basically says sometimes there is a startup problem. Nothing about the problem, what may precipitate it, any details. We
need a little more info.
More is better:
If you are
serious about getting an answer, include/confirm Make,
Model of the product that's misbehaving and what type of product it is.
Describe
your problem
clearly, concisely and with as much detail as possible. Include recent
events, is it new, used, has it ever worked, do people mess with it,
etc. Anything that will help describe the problem.
For
future reference:
Often, a
problem can be the result of a seemingly unrelated event. It is always a
good idea to include a recent history.
Additional information
such as what steps have already been taken, has the product ever worked,
is it new, etc. can have a bearing on
providing the best solution for your particular circumstances.
Remember,
you are a key participant in this process. We are not there,
you are. We depend on you to be our eyes and ears. We can only
respond to what you provide us. Without you, all our talent is
worthless. How's that for an ego build?
What you get out of the
experience depends on what you put in to it. So help us help
you.
It would be also be advantageous in your case to repost
your problem so that it is correctly categorized and starts over at the
top of the queue. This way it can be directed to someone with expertise
in the area you need.
Best
regards
Mike
If running XP
A log-on loop on your Windows XP computer is a difficult situation where the computer never completes its boot cycle, restarting intermittently ad nauseam.
This issue indicates a major problem with the boot functionality of your XP system.
Restore the computer to working order by utilizing the repair and restoration utility on your XP system disk.
Insert the XP disk into the computer.
Restart the computer.
Press any key when prompted to boot from the disk.
Press "Enter" at the first screen and "F8" at the license terms.
Highlight the drive containing XP and press "R," repairing the operating system boot files and removing the log-on loop.
or
Windows XP sometimes has a glitch when you are logging in to your user account in order to boot the operating system.
The glitch logs you in and then logs you off the account.
This problem is usually caused by one of the programs that load during the computer's start-up.
Fixing this issue is a matter of ensuring that whatever program is causing the problem doesn't start up as soon as you start your computer.
or
Power on the computer and allow it to get to the user logon page normally.
There is no need to start up the computer in "safe mode."
Click the user who is having the issue and type in the user's password if one is set up.
Press and hold the "shift" button on your computer keyboard as soon as you see the tool bar load up at the bottom of the screen but before any other program has a chance to do so.
This stops any "Startup" program from running and logging you off.
Right-click the "Start" button on the bottom left of your screen.
Select "Explore" from the menu that appears.
Double-click "Programs" from the list on the left side of the window that pops up.
Double-click "Startup."
Select all the files inside the "Startup" folder by dragging a box over them.
Right-click anywhere on the selected files.
Select "Delete" to delete those files.
Note that deleting the programs from the "Startup" folder does not delete them from your computer.
All this does is make it so that these programs no longer start as your computer is starting so that any error in the running of the programs doesn't interfere with logging in to your account.
Hope this helps
or
or
Hope this helps
or
or
Hope this helps
