Question about Haier XQG50-11 Front Load Washer / Dryer
My washing machine is HAIER It is washing OK, but
My washing machine is HAIER It is washing OK, but not rinsing. Instead it start to heat the water and produce some humming noise. My email: th40shrub@hotmail.co.uk
  • th40shrub Nov 08, 2010
    It appears as if machine is trying to rinse, water is enough, but draining is not being done.
    There is no access to pump. If I try to axe the panel, it will produce such a heavy noise, neighbours will throw me out of the street. What should I do?
  • Anonymous Mar 16, 2014
    Have had a problem with this washing macine not rinsing out! Help plz
    Genius:
  • 1,416 Answers
First of all put off the washing machine for some time then put it on after some time ,while because some time the problem can be from the power suppl
My washing machine is  HAIER It is washing OK, but - 1x1.gif Do you have enough water in the machine?
However,you may trying to add more water for the washer to complete it rinse
please note sometimes water is just not enough for the machine to complete rinse the soap from the cloth.
Hard to say as I know you have different types of washers in the word to day . It sounds like you might be putting too many items i.e cloth into washing machine or water shortage .
Can you select an extra rinse cycle? On my washer I have this option after adding more water for the washer to start afresh .
thanks for using fixya.
Posted on Nov 06, 2010
I have an haier washing machine that gets stuck at the rinse cycle. What could it be? Plus it makes loud grinding noise.
are u saying its putting water in the draining over an over? or not rinsing at all? if no water coming in check water inlet valve. if its draining over and over>? check ur drainage and water pump
Jun 15, 2015 | Haier Washing Machines
My washer will fill and wash but when it gets to the rinse and spin cycle than it just stops and wont draiain
gwt450aw mine was washing but was not spinning and was loud like many others have posted. Seems the electronic drive motor had washer type ring inside the middle of the motor that was wavey from heat guess if happens over time. The friction was over heating the motor till it would stop working. Took that part off works fine. Once you've inside you can tell there is no need for it. Given the position of the motor. FYI the drive motor is under 10 year warranty from haier with proof of purchase for the date.
/uploads/images/6_9_2014_9_24_19_pm.jpg
Feb 04, 2014 | Haier GWT450AW Washer
Haier HLP21E Top Load washer keeps beeping & blinking after water intake. It will rinse out the water when 'rinse' pressed. However it does not 'spin' but instead all three orange lights start blinking &...
No spin with alarm means the unit is out of balance.
The troubleshooting manual reads:
"The safety switch acts. The
spinning cannot work (The
WASH, RINSE and SPIN
indicator flash and alarm goes
off every 10 seconds). If
trouble cannot be solved after
alarming, it will alarm again
every few minutes."
To solve this the load must be balanced:
Make sure to level the machine on a solid floor. Also you may have to redistribute the clothing in the tub for even weight distribution.
Sep 28, 2013 | Haier HLP21E Top Load Washer
Machine won't run on wash and rinse but motor will start and drain the water out
What you hear is the drain pump, remove back panel to see the problem
Mar 31, 2013 | Haier XQJ50-31 Top Load Washer
Washer will fill and drain but won't wash and rinse
Check for a modular unit in the machine that controls the wash action of the machine. If it has malfuctioned there will be no power for the motor. Check with the spares departtment if your machine has this unit
Mar 02, 2013 | Haier HLP21E Top Load Washer
My Haier HW-C1460TVE-U washing m/c keeps giving (CLrF) ERROR Code
Anyway, my machine shows an error code "clrf". I just spoke to someone at Comet, and apparently this means there is too much foam in the machine. The machine will then refill with water and try to rinse it out, but if after that the machine still has too much foam in, then it will stop the cycle. Hence why my clothes are still wet (although I'd not realised they weren't rinsed properly either!).
I have not been using excessive amounts of washing powder, and usually use powder tablets or the liquid tablet sort, so they are a set amount and I don't do anything daft like stick 6 tablets in! I find it ridiculous that this would cause a problem with the washing machine, as I've used them perfectly fine with other washing machines.
Anyway, the advice from Comet was to keep trying different washing powders until i find one that foams less.
Jan 07, 2010 | Haier Washing Machines
Open Questions:
See all Haier XQG50-11 Front Load Washer / Dryer Questions
Haier XQG50-11 Front Load Washer / Dryer Logo
87 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
