Question about Philips Televison & Video
A local repairman replaced fluids to clear up the picture. He left taking my repair manual with him and we've never seen him again, It worked great one day and when we went to turn it in the next time it flashed red F6. What ddoes this mean and how can I fix it?
    Brigadier General:
  • 8,909 Answers
There may have been some spillage of fluid from the tube lenses, that will cause odd problems. I should call the the repair guy back in the fix it for you and get your manual back!
Posted on Nov 06, 2010
FGHD2433F1
mellison,Has the repair man replaced the control board? It does sound as if it would be the board. Any more info would be great.
Joe Connolly
Nov 13, 2011 | Frigidaire Dishwashers
When I turn on the set, the right half of the screen is distorted. It flickers, different colors move from center to far right of screen, double images that appear as negitives and sometimes that half of...
Symptom shows problem with lcd panel (screen) however, t-con board that is part of lcd panel could be defective and cause of these symptoms.
T-Con board is located at top center of cld panel at rear and would be covered with metal shield. There are three type of t-con board utilized according to lcd panel and are available in shopjimmy.com
Please check what t- con board is similar with your tv board to order it. If you are not handy with electronics stuff repair then local tv repairman will help you to replace t-con board that might solve your tv picture problem.
Thanks.
Jan 29, 2011 | Samsung LN46A550 LCD TV
The TV Sony KDF-60WF655 turn on and the screen is all blue, can see the picture but not clear and thge picture keep scrolling from right to left
The reason your television has a blue screen and scrolls from right to left is simply because there is a problem with a board in the television.
The board is known as the t-con board and as soon as you get it replaced, your television will be in good condition again.
You can have a repairman replace it for you, or you can replace it yourself.
But to be on a more safer side, I will strongly advice you allow a repairman fix the problem for you.
Take care
Jul 15, 2010 | Televison & Video
I'm getting an error message "E27" on my bosch vision machine but can't fine it in the manual
I had to call the repairman. He said it was an overheated solenoid in the door lock. The "repair" is to let the washer cool for about 10 minutes (unplug it), then try again. If you're still getting the code, you'll probably need to call a repairman like I did. Though once he put it into diagnostic mode the code "cleared" and it works again. The final fix is to replace the lock.
Mar 23, 2010 | Bosch Washing Machines
Our 1991 RCA projection TV P52150CP started being hazy blue when first turned on then it gradually would become mostly normal screen. Today the whole screen is a blue haze. You can see the picture sort of...
Most likely it is the Blue CRT Driver Board or the Blue CRT failing. There is no quick way to varify unless you call a repairman out to see.
Hope this Helps,
Skyassoc
Jul 03, 2009 | RCA P52926 52" Rear Projection Television
Hitachi 46'' Rear Projection TV has distorted picture
Make sure no one pushed the front screens in a little. That will cause exactly what you have. I've seen cases like this where someone would move there set with one had pushing on the front screen and dis-lodging them creating that problem... Hope this helps.
Mar 08, 2009 | Hitachi 46UX50B 46" Rear Projection...
Kenmore Top Load Washer Model 110.92593210 wouldn't agitate, now
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!
Feb 23, 2009 | Kenmore 22422 Top Load Washer
Canon a60
This is due to iris problem ... the iris does not open .... so hence nothing is seen and nothing is recorded .... try lightly slapping the camera from the left side ...... if it works fine other wise show it to a repairman ...
Oct 20, 2008 | Canon PowerShot A60 Digital Camera
Distorted Picture
the hyper module is defective needs to be repaired or replaced.
Aug 03, 2008 | Televison & Video
Meaning of Green square icon on upper left corner
I have the same camera. The green square icon appears while the camera is saving the picture. From your description, I think you were using "Shot Confirmation", and this setting was cleared during the repairs. Have you tried going into the Setup mode (on the dial) and reselecting Shot Confirmation? (p. 143 in the manual)
Jan 17, 2007 | Nikon Coolpix 5400 Digital Camera
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
