Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Printer will not turn on
Inline power light is on but printer will not turn on when on/off button is pressed
  • Anonymous Jun 22, 2008
    printer does not show power on and cannot start if i press the on/off button
Call the Kodak support, they will replace the printer free of charge
Posted on Jun 17, 2008
How can i fix error 5200 on my canon pixma ip2770
You can try the following 1. Turn off printer, cable power still plug in,
2. Press Resume Button don't release
3. Press Power Button don't release and than release Resume Buttons
4. Press Resume Button 6X
5. Turn off printer cable power still plug in
6. Turn on printer again, now this printer ready to use.
Or try
1. The printer is turned off and plugged the power cord.
2. Press Resume button 2 seconds
then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
3. Then release the RESUME button, but do not release the POWER button.
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow GREEN.
7. And the computer will detect new hardware, just ignore ...
8. Press the POWER button, then the printer will die.
9. Press the POWER button again then the printer will flash and ... IP2770 Printer is ready to use
Jul 27, 2011 | Canon Office Equipment & Supplies
All 3 lights are flashing. I have tried everything the manual asked me to do
You may need to restart the printer.
1. Press the power button to turn off the printer.
2. Press the power button to turn on the printer.
Proceed to step 3 if the lights are still flashing.
3. Press the power button to turn off the printer.
4. Disconnect the printer from the power supply.
5. Reconnect the printer to the power supply.
6. Press the power button to turn the printer
Aug 14, 2010 | HP DeskJet 940c InkJet Printer
Number code E27
* Connected Printer to a Power source, Turn off the printer if printer on
* With the Printer power off, press the Power button while press and hold Stop/Reset button.
* When the Power led is light, press Stop/Reset button two times while pressing and holding the Power button.
* When releasing the Power button and the Stop/Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
* When the on/off lights in green, press the Stop/Reset button 4 times to reset the printer. (Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange).
* press on button to comform reset....
.* off the printer and turn on again...the printer will back to normal....
Apr 16, 2010 | Canon PIXMA MP150 All-In-One InkJet...
5 yellow blinlking lights. Power on/off doesn't clear the lights. Won't print. TIA...
Canon IP3000 INK counter reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Can try it may work all the best of luck
Feb 15, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Orange and green lights blinking
Hello try to press the power button to turn off the printer, then press the power button to restart the printer.
If the lights continue to flash,press the power button to turn off the printer,disconnect the printer from the power source,reconnect the printer to the power source and finally press the power button to turn on the printer.
Good luck
Jan 15, 2010 | HP DeskJet 5550 InkJet Printer
All 4 lights are on. I cannot even get it to print a test page
Follow the instructions below to solve this problem.
  1. Turn off the printer power switch.
  2. Take out the DIMM (Dual Inline Memory Module) from your priner, if you have a DIMM installed.
  3. Wait a few seconds and turn the printer back on.
  4. Try to print again.
    If the error still remains, press the Go and the Job Cancel button together to check the error status referring the LED indications below.
  5. After checking the error status, report it to your dealer or Brother Customer Service.
Oct 23, 2009 | Brother HL 5140 Laser Printer
Epson CX6400. No display. no power. does the printer have an inline fuse?
1.) Unplug all cable connections ( power cable and usb cable ).
2.) Check if there's any obstructions inside the printer.
3.) While the printer is off and unplugged., press and hold the on button for 10 sec.., release after 10 sec. and connect power cable.
4.) Turn on the power.
Apr 06, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Flashing lights
Canon IP 2000 / reset
1. Turn off printer
Aug 26, 2008 | Canon PIXMA iP2000 InkJet Printer
Brother laserjet 5170dn
If you see the service call indication above, follow the steps below:
1 Take out the DIMM (Dual Inline Memory Module) from your printer, if you have a DIMM installed.
2 Turn off the power switch, wait a few seconds, and then turn it back on and try to print again.
If you cannot clear the error and see the same service call indication after turning the printer back on,
call your dealer or a Brother authorized service representative.
When you press the Go and the Job Cancel buttons together, the LEDs will light up with one of the
combinations shown in Table 1. See Table 1: LED indications while pressing Go and Job Cancel on page
3-6 to identify the error.
Something has failed that the printer can't recover from.
Apr 18, 2008 | Brother HL 5170DN Laser Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
