Toshiba satellite L500-1R0, fn hotkey is not functioning to on the wireless of the system. please help with the software i can download to to use it on my system wireless on.
    Sniper:
  • 51 Answers
Hi, have you tried the front wlan switch? It is located at the front of your laptop and usually will resolve the problem. If it is already on, then turn your switch off and then on. Also double check the function key to make sure that it is on. If it still doesnt work, you will need to start checking other things such as drivers, and if the drivers are there, then it could be a wlan card failure. To check the drivers, click on Start>>right-click on Computer>>left-click on Manage. On the left, click on Device Manager, and under the heading of Network Adaptors, see if there is anything corresponding to your wlan adaptor. If there is nothing like this, then your card seems to have failed. Otherwise, a yellow exclamation mark indicates a driver problem. In this case of a driver problem, right click on it, and then click on uninstall. Restart your computer and see if the wlan works. Failing all of that, it would point to a wlan card failure. Hope this information helps
Posted on Nov 06, 2010
Can't get the wireless to come on
Exterior Wireless Switch
Step 1
Position the laptop so that you're facing the screen and the keyboard is in front of you.
Step 2
Check the front edge of the laptop's casing.
Step 3
Identify the wireless indicator light labeled with a wireless antenna icon. The "On/Off" switch to the left of the indicator light is the wireless switch.
Step 4
Move the switch to the "Off" position to deactivate the wireless adapter or move it to the "On" position if you want to power on the wireless adapter.
On-Screen Wireless Switch
Step 1
Press and hold down the "Fn" function key on the computer's keyboard to display the laptop's hotkey card icons on the screen.
Step 2
Click the "Wireless" icon on the screen or press the corresponding hotkey button on the keyboard, typically the "F8" key on a Toshiba laptop.
Step 3
Click the "Wireless On" or "Wireless Off" icon in the options list below the hotkey card icon to activate or deactivate all wireless connections. If your laptop has Wi-Fi and Bluetooth connections, you can also choose to activate or deactivate these services separately.
if have drives problem you can download using this link
http://www.toshibadirect.com/td/b2c/retail-product.jsp?poid=452315
Sep 13, 2013 | Toshiba Satellite L505DS5983 Notebook
I use TOSHIBA Satellite M200 notebook and have problems : 1. FN key did not work I can use only FN+F10 and FN+F11, other FN+key didn't work. 2. All hotkey buttons (locate next...
Hi
There is software utility missing from your laptop
you can download it from TOSHIBA Satellite M200 website under ( keyboard utility )
Please tell us your results
Good Luck
May 13, 2011 | Toshiba Satellite P105-S921 Notebook
How to switch on wireless
On your Laptop, there's no dedicated key/button for wireless as other Toshiba Satellite. There's a hotkey function. Press Fn+F8 (simultaneously) to activate the wireless and press the same keys to deactivate.
When you look at the F8 key, you'll see the wireless symbol (something like tower).
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Oct 05, 2010 | Toshiba Satellite L655S5078 Notebook PC
Toshiba A305 hotkey
Try re installing your operating system (genuine windows xp or vista suggested)
If the problem still persists contact me at
Deepuunni1985@gmail.com
Jul 10, 2009 | Toshiba Satellite A305-S6863 Laptop
Looking for wireless on switch on laptop
Right Side, underneath your volume control. If it is switched on and still cant access the internet wireless give this a try.
Use Control Panel's Add or Remove Programs utility to uninstall the Toshiba Hotkey Utility, and then reinstall it.
This program is called E-Key Utility on the Toshiba Satellite M30X/M35X Recovery and Applications/Drivers DVD. It's called Toshiba E-Key Utility for Windows XP on the Toshiba Support website.
Unistalling the Toshiba Hotkey Utility:
  1. Click Start.
  2. Click Control Panel.
  3. Double-click Add or Remove Programs.
  4. Select TOSHIBA Hotkey Utility.
  5. Click Change/Remove.
  6. Click OK to confirm that you wish to completely remove the selected application and its features. The InstallShield Wizard will begin the removal process.
  7. Click Finish to exit the InstallShield Wizard.
Re-installing the Toshiba Hotkey Utility using the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD that shipped with the computer:
  1. Insert the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD into the CD/DVD drive and close the tray. The setup program on the DVD should start automatically.
  2. When the Toshiba Recovery and Applications CD window appears, verify that "Install applications and drivers" is the selected install type, and click Next.
  3. Select E-key Utility from the list, and click Install.
  4. When the WinZip Self-Extractor window appears, click OK.
  5. Click Unzip.
  6. Click OK to acknowledge that the files were successfully unzipped.
  7. When the InstallShield window appears, click Next and follow the prompts to complete the installation.
  8. When the installation is complete, click Exit and then OK to close the Toshiba Recovery and Applications CD window.
  9. Remove the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD from the optical drive and close the tray.
Reinstalling the Toshiba Hotkey Utility using the file downloaded from the Toshiba Support website:
  1. Download the Toshiba E-key Utility for Windows XP from the Toshiba Support website, and save it to your computer. See also the bulletin Obtaining downloads and support docs from the Toshiba Support website.
  2. Navigate to where you saved the file and double-click it.
  3. Click Run.
  5. Click Unzip.
Feb 21, 2009 | Toshiba Satellite M35X-S111 Notebook
Hotkeys
Go to:
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modItemList.jsp?BV_SessionID=%40%40%40%401047994115.1225656652%40%40%40%40&BV_EngineID=cccgadefijdhhdecgfkceghdgngdgnn.0&ModelDLOS=null&ModelDLCat=null&BV_SessionID=%40%40%40%401047994115.1225656652%40%40%40%40&BV_EngineID=cccgadefijdhhdecgfkceghdgngdgnn.0&ListType=Model&ct=DL&moid=882862&rpn=PSM40U&OrderBy=D&PublicStartIndex=25&PrivateStartIndex=0&PublicCutOff=&PrivateCutOff=&AddOldPublicItems=false&AddOldPrivateItems=undefined&all_docs=false#PublicList
and get the HotKeys Utility there. It should solve it.
Oct 31, 2008 | Toshiba Satellite M45-S331 Notebook
Brightness
You have a blue key that says FN (stands for function) on the bottom left side of your keyboard, next to control and shift. The brightness and dimming hotkey is usually on the arrow keys or up on your f row, f1-f12 and you'll see like a sun and half sun in blue, same as the function key. While holding that function key tap keys you found and it'll brighten and darken. If it doesn't, you may need hotkey software installed, a new LCD (backlight may have failed) or inverter which powers the LCD.
Oct 26, 2008 | Toshiba Satellite A25-S207 Notebook
FN key not working in Toshiba Satellite
Hey,
Try to install these utilies:
Toshiba Common Module
Toshiba Hotkey Utilities
Toshiba Touch Pad ON/Off Utilitiy
Toshiba Utilities.
... in the same order and reboot between them.
One guy posted it on some Forum.All credits to him :)
Hope it helps.
Dec 03, 2007 | Computers & Internet
Computers & Internet Logo
465 people viewed this question
David Payne
David Payne
