Question about Nintendo DS Lite Console
DS top screen
Hi the reason i came to you was for my ds screen
my top ds screen wont work after i did this thing on youtube http://youtube.com/watch?v=FH16gO3Ry4A&mode=related&search=
so after an hour the screen shuts down and doesnt come on only till i press L and up please i need help!
  • 1 more comment
  • eric Korey
    eric Korey Jun 15, 2008
    hi the reason i came to you was for my ds screen
    my top ds screen wont work after i did this thing on youtube http://youtube.com/watch?v=FH16gO3Ry4A&a...=
  • Niels Boehme May 11, 2010
    Been away a while...
    It is possible that some water may have migrated underneath some of the other parts. I don't know how much you used, but thin water films under electronic chips can take a long time to dry. The results of the water are unpredictable but never good. You may have to disassemble and blow it dry.
    What is the state of it now?
    What liquid did you use?
I used water
Posted on Jun 18, 2008
My ds lite wont power on how can i fix it?
One of you're screens is broken or the F2 fuse has blown.
Check youtube for a video on "how to check my DS lite F2 fuses" there are several available that give step by step guidance on how to do this.
Having checked these (and replaced blown ones) and you're screens are still not working then it is a screen that has blown.
If the bottom screen flashes for a split second when you turn it on then it is you're TOP screen that has blown and needs to be replaced. If it doen't flash then it is you're bottom screen that is broken and needs to be replaced.
Sep 10, 2009 | Nintendo DS Lite Console
DS Lite
The green light is blinking, no red lights or anything else? The fuse is good as well correct?
Thanks,
Lee
Jul 19, 2008 | Nintendo DS Lite Console
Top screen is non readable nintendo ds
Hi you have done one of two things to your ds.
1) you have somehow unstuck the top plastic protection screen that covers the lcd screen and re-stuck it but have got fingerprints etc on it, hence the blur.
2) The more obvious thing is you dropped the de or gave it a bang and the ribbon feeding from the top screen to the lower screen through the left hand hinge is damaged or it has become slightly unclipped where it meets the motherboard.
Either way you will need to take the DS apart to solve. It can be tricky so if you are not confident bring it to a repair shop, it is an easy fix and wont cost the earth to fix.
If it is still under warranty send it back to Nintendo to fix.
May 16, 2009 | Nintendo DS Lite Console
DS lite screen
Hahahahaha that is how it works but if you go to the little DS at the bottom of the touch screen and tap it there will be a fixer manual use it and when you are done the system will shut off and just turn it on again and also the touch screen is the most important thing on your ds so keep it scratchless and clean! On some games the top screen is an important thing and somtimes it doesnt show anything
Mar 02, 2009 | Nintendo DS Lite Console
Hi erm can you buy a new screen for ds
just google "new top screen for nintendo ds lite" many options will come up.the screens are somewhat hard to replace.email me if you need help
Feb 23, 2009 | Nintendo DS Lite Console
DS lite Top screen got wet this morning
Go into the ds and dry off the top screen it does work.
Jan 28, 2009 | Nintendo DS Lite Console
Turns on and lights up but no images on top screen
The DS top screen has two components, which are the LCD display, and the backlight. If the LCD display has gone bad but the backlight still works and the connecter is seated properly, the DS will still power on and the lower screen will be normal, and the top screen will light, but it won’t display anything.
You didn’t mention if your DS is the original DS or the DS Lite. Replacement top screens for the DS Lite are cheap on eBay, but installing the screen is a bit complex. The screen for the original DS is a different part and they are more expensive and hard to find.
I’ve never worked on an original DS, so I can only tell you about installing the top screen on a DS Lite.
First, the DS Lite has to be just about completely disassembled. You have to completely remove the top and bottom cases, pull out the microphone and wi-fi cables, and release the connecter for the top screen, which is located on the main board in the lower case. You’ll need the tri-wing screwdriver. You can leave the bottom screen/touch screen assembly attached to the main board, but be careful not to pull or tear the flex cables. Check YouTube for videos on disassembling the DS Lite.
Here’s the deal breaker for most people: The speakers are soldered to the flex cable of the top screen. I’ve never seen a replacement sold with speakers. You’ll have to unsolder your speaker wires from the old screen cable and reconnect them to the new one. If you can’t solder, you could take the screens to a local tv/electronics repair shop and pay to have it done. I got this information for you from http://wiinewz.com/forums/nds-general-discussion/72805-ds-top-screen-white-blank.html this appears to be a common problem I hope this helps
Dec 01, 2008 | Nintendo DS Lite Console
Onceturned on, the green light goes on, the touch screen flashes white, then it all turns off.
You might only have a loosen screen ribbon cable.
If not careful while taking out the top screen ribbon you can damage it causing blank screens and finally the DS wont work.
The solution to a broken top screen ribbon is to replace the whole screen in DS lite or buy the ribbon cable in the DS fat and replace.
If the broken top screen ribbon is caused by broken hinge then you should replace the shell also to avoid other broken screen.
May 22, 2008 | Nintendo DS Lite Console
DS Powering On
Hi, if the bottom screen briefly comes on with a white screen. There is a issue with the top screen, it is either the top screen itself or if there is damage to the hinge it will more than likely be the cheaper option the ribbon cable that threads though the hinge to the top screens PCB board.
Mar 16, 2008 | Nintendo DS Console
Conection?
Here is a guide to dismantle an original Nintendo2.gif DS:
How to dismantle a Nintendo DS.
If yours is the NDS Lite, just find this video2.gif in youtube: "Disassembling Nintendo DS2.gif Lite"
And after opening it you can do your work. Make sure the flexible cables connecting the top screen part of your DS are well in place and not broken. Your problem may be only a loosen cable but in case the cable is broken you gonna need a replacement. Be careful not to damage the screen or other sensitive electronic parts on your device and you will be on your way.
Good Luck...
Dec 01, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
126 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
