Question about Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum
Troubleshooting for Bissell proheat
Hello I hava a Bissell pro heat 12 amp -it is not shooting out the soap?!!!!
Any suggestions never did this before??!!! :)
unfortunately, i stored this with solution in the soap dispenser (ugh, not on purpose, mind you!) and now, yes, it is clogged up. The soap holder is fine, but it is apparently clogged on the inside.
The red spinner does not spin, and actually stopped spinning the last time I used it (has been awhile, like a year.)
Mulitple stage problem? Or did my stupidity just clog it up?
If so, how to unclog?
  • morphet Jul 06, 2008
    when I pull the trigger on the handle no water or solution sprays out onto the carpet and the fiow indicator does not rotate but the smart mix bottle seems to fill up. I have checked the filter in the flow indicator, it was OK. I checked the pump belt and rotation of shaft all OK and working, I have filled the water tank and smart mix bottle with clean hot water and tried running machine but to no avail
  • 1,673 Answers
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just re-fasten it down.
Posted on Jun 17, 2008
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ... > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Water and soap coming out wheel area
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
Apr 10, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell pro heat advantage 12 amp
You can download the instruction manual at the web site.
Jun 29, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell power shoot carpet cleaner
It sounds like the heater may be plugged. This is a problem for an experienced technician. The heater is located in the handle and they are prone to plugging at the tubing connections. The heater is heating soap and water solution and this can cause the soap to coagulate and plug the lines. It must be addressed carefully to avoid damaging the heater.
Mar 23, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
ad small pad to end of handle plunger.. the plunger is not reaching valve inside unit
Oct 20, 2007 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum Logo
1,375 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
