Question about Sanyo DRW-1000 DVD Recorder VCR
I bought a telefunken dvd recorder and vcr combo and I have been trying to set it up to a set top box for ten hours now, some one please HELP ME!
snakehead
  • 1074 Answers
SOURCE: Sanyo DRW-1000 DVD Recorder / VCR Combo
if you have not plug out your set for a while then i recommend to do now leave it for about 2 days then plug it in back if it does the same problem,then have a tech look at your set.good luck
Posted on Jun 04, 2007
masya
  • 3 Answers
SOURCE: SANYO DRW-1000 DVD/VCR COMBO
you must use R-, RW- to record on this unit
Posted on Jan 12, 2008
konzzz
  • 255 Answers
SOURCE: VHS output is fuzzy
i think its the tracking adjustments.
Posted on May 28, 2009
SOURCE: Sanyo DRW-1000 DVD Recorder / VCR Combo remote control
I thank you for your interest in helping me. However, I just want to know where to get a replacement for the remote control for a DVD RECORDER VIDEO CASSETTE RECORDER COMBO, model DRW-1000. Then, I do not find necessary to pay for such information. Thanks, again, anyway for your help, sincerely,
Juan B. Pérez-Valverde
Posted on Jun 17, 2009
  • 41 Answers
SOURCE: sanyo dvd/vcr combo
Your universal remote would have seperate selection buttons for VCR and DVD. If you don't have a VCR button, use AUX. Try programming each function seperately - DVD code for your manufactirer on the DVD button and VCR code for your manufacturer on the VCR button.
Posted on Sep 12, 2009
I have DMEZ 47V DVD recorder/VCR combo and panasonic digital/ HD tv...when I set up to pre record the equipment seems to accept the information ok but when i try to playback all i get is ..."cannot...
The reason for this is simple; the built-in digital tuner does not support HD, only SD. You cannot fix it, at least not economically where the recorder combo is concerned. But you can obtain a separate HD set top box, and connect the outputs of it to the inputs of your combo if you really want to record HD channels. It's crude, but cheaper and easier in the long term, and it doesn't damage your machine.
Feb 17, 2011 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
Vcr/dvd combo recording problems
You can use a normal set top box, plugged into the AV inputs on the combo, you could even use a seperate VCR for this, as long as it's recieving the signal you want to record.
Apr 21, 2009 | Toshiba SD-V295
Linking DVD recorder to external set top box
The TEL0713-250 records fine from my Strong settop box, but only in 576 definition Higher definition sees either nothing or black and white. Check the outpur format of your STB
Apr 06, 2009 | Televison & Video
Philips MRV700VR DVD Recorder / VCR Combo
Crack the top open and look inside for any foreign matter. Usually the cause is debris in the IR path that detects start and end of tape or the loading mechanisim is faulty.
Sep 24, 2008 | Philips MRV700VR DVD Recorder/VCR
Can't switch from AV2 to AV1 with Samsung DVD-VR375 DVD Recorder / VCR Combo
To be able to select AV1, you have to first go into the setup menu and set the control set top box setting to OFF. I think you go to the menu >> setup >> features >> set top box control >> select OFF. Note that this has the side effect of erasing any previously stored timer settings.
Sep 05, 2008 | Samsung DVD-VR375 DVD Recorder/VCR
Dvd/vcr/recorder
sounds like it's not set up for more than a quick record...check the settings..
Mar 17, 2008 | RCA DRC8300N DVD Recorder/VCR
HELP! I can't figure out how to Connect my Sylvania DVD/VCR Combo to my older TV
Even if you do get it connected you cannot copy from vhs to dvd as you have bought a vcr recorder with dvd player, not a dvd recorder. You can only record to the vcr tape from a dvd, in the players controls.
Feb 08, 2007 | Sylvania (SRDD495) DVD Player/VCR
Televison & Video Logo
43 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
