Question about Ubi Soft Peter Jackson's King Kong for Windows
In windows vista the game king kong is not working and is saying that you dont have administrator privilege
Tip
Why some things dont work with vista or windows 7
The most common issue people have with these new OS systems,(windows 7/vista) is that they have a new form of security called 'administrator privileges'. Basically, your average user doesn't know about this, because most installation CD's or DVD's just auto-run when you insert them, and unfortunately, the computer most of the time does not prompt you to do anything special at all, and the software just installs. But underneath that installation, certain 'privileges' have been allocated to that installation, so here's the tip; Whenever installing new hardware or software, be sure to stop the auto-run feature, or close it down if it starts by itself, right click the disc or file where you are installing from, and select 'run as administrator'. If you are not the administrator, or do not have access to that privilege, then I suggest getting that access, or get the person who has it to give it to you! If you are installing from disc, go to Start>Computer and the disc should show there. Right click on it, select 'open' or 'explore', find the installation file (usually a .exe file) and go through the procedure above. Enjoy!
on Apr 16, 2010 | Computers & Internet
Why can i play hidden object adventure pack on my dell with Windows xp
Hi Jennifer,
When you say that you are unable to play , do you mean its not loading ? unable to install it? do you get a specific error message when you try to launch it ?
hidden object adventure pack:
  • System Requirements: Windows XP (Home & Pro) SP3, Windows Vista SP1, Windows 7 . , 800 MHz processor or greater. , 512MB RAM. , 237MB free hard drive space. , DirectX 7.0. Administrator privileges are required to properly install the program on Windows XP, Windows Vista , and Windows 7. Format: WIN XP,VISTA,WIN 7 Genre: ENTERTAINMENT Rating: E10+ Age: 8386390063
if your using windows XP , make sure that you have Windows XP (Home & Pro) SP3 and the rest of the specs mentioned above.
Thank you.
Dennis
Aug 03, 2014 | Video Game Consoles & Games
SAYS I NEED TO BE AN ADMISTRATOR BUT I AM
Deep Silver Wildlife Park 2: released in 2006.
Try these options.
Right click the launch Icon / Shortcut - Select Compatibility tab -
Under Privilege Level - Check the "Run this program as an administrator"
Click OK and try launch the game.
Failing that;
Run the game in Vista compatibility mode ( there should be 3 ) and see if that works.
Same method as above.
If not, try the XP modes.
Check the "Run this program....compatibility...." box and select a mode.
Hope this helps
Nov 30, 2013 | Deep Silver Wildlife Park 2
Hey. I have downloaded the game My Horse and Me 2 on my laptop and installed it normally. When I try to play the game, it says: ''Insufficient privileges: you must be administrator when you run this...
Reinstall it using administrator privileges and also make sure to unblock it before reinstalling by right clicking then chose the last option at the bottom of the pop up window which I believe its specifications another window will pop up look for the unblock option then click ok then right click on installation file again then click on run as administrator
hope this helps
Dec 02, 2017 | Atari MY HORSE & ME for Windows
My horse and me 2 administrator
I had a problem with a different game, I had to uninstall and reinstall the game by right clicking the install.exe file and clicking run as administrator to install it, then once installed right click game icon and set compatibility to windows xp and put a tick in run as administrator
Sep 16, 2013 | Atari Video Game Consoles & Games
Peter jackson kin kong error code 577
to install tha application, you must haeadministrator privileges on your computer.
Jul 11, 2011 | Ubi Soft Peter Jackson's King Kong for...
I put my game in the computer, but when i click "setup" it says that it requires administrative privileges to run it. But, in "my accounts", t says that i'm the only one to log in to my...
If it is in Windows, this happens frequently. You just right click the setup file and click 'run as administrator' and it should work.
As for a Mac, I'm not sure about that.
Dec 22, 2017 | Origin Diner Dash: Flo on the Go for...
Vista - football manager series
just right click on ur game icon and go to compatibility mode and enable the winows xp mode or enable the run as administrator mode... after that apply and click on ok.. and run ur game....
Feb 21, 2009 | Microsoft Windows Vista Home Premium with...
Partition commander 10 professional won't work on win vista
Is your vista account set up for administration or for limited use, if you are not a administrator on the account of the os then you wont have installation privileges.
Jan 22, 2009 | Avanquest Partition Commander 10 for PC,...
Ubi Soft Peter Jackson's King Kong for Windows Logo
114 people viewed this question
Top Ubi Soft Video Game Consoles & Games Experts
dante
Tom Chichester
MegaByteMe
MegaByteMe
Are you an Ubi Soft Video Game Console and Game Expert? Answer questions, earn points and help others
