Paper Jam Label stuck on roller - Computers & Internet
  • 106 Answers
Alcohol or Goof off or replace.
Posted on Jun 15, 2008
Manual feed won't grab paper
If the printer works good when it prints the envelopes/label one by one, I think it works normal (because the paper is not a standard paper).
Mar 06, 2014 | HP Office Equipment & Supplies
Kodak go aiosupport
1. It could be a problem with the paper sensor ( a micro switch).
2. The tray holding the paper may have a defective spring causing the paper to not contact the rollers.
In the case of a "paper jam", there may be a label or just a piece of paper with some adhesive stuck in the path of the paper inside.
If the printer has a bypass tray, run a thick piece of card stock through the printer. You might be able to use a flashlight to inspect the paper path to detect any foreign material causing the "jam sensor to come on".
Be sure to use check the printer through the control panel...open the printers and select the printer properties using the right-click of the mouse and cancel all pending print jobs....
Restart the computer.
See if that helps....
Jan 02, 2014 | Office Equipment & Supplies
The printer is saying there is a paper jam but there is no paper stuck any way in the machine.The resume button does not resolve the problem.
The paper jam may not be very visible and obvious. It may be somewhere after the rollers. Some paper may be stuck in some place in the paper path. Open up the printer and clean the insides with a soft cloth and a brush. That should remove all the bits of paper inside. OR the teeth on the roller sides may have some dirt stuck on them which does not allow the rollers to roll freely and hence is as bad as paper jam. The idea is that the rollers do not roll whether because of paper or some dirt on the roller teeth. They have to be cleaned.
Nov 17, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
QL-550 Label Stuck
Normally theres a lever you pull (the same one you use to manually pull the labels through), if you pull that, you should be able to blow the label out, or pull it through.
Apr 24, 2009 | Brother P-touch QL-550 Thermal Label...
Dell 944 carrier jam
THE CARRIER MAY HAVE A FINE PEACE OF PAPER STUCK IN THE FEEDER ROLLER OR IN THE ROLLER PANS, REMOVE EVERYTHING, GET A CAN OF AIR AND BLOW IT OUT GOOD AROUND WHERE THE PAPER FEED AND EXITS THE PRINTER, THE CARTRIDGE MAY MAYBE GETTING SNAGED ON THE PRINT HEAD ALSO. SHACK THE PRINTER UPSIDE DOWN TO GET ANY TYPE OF MATTERAIL IN THE MACHINE, IT CAN BE PAPER, PAPER CLIP, STAPLE, PENCIL, ERASER MATTERAIL,
INK BUILD UP ON THE ROLLERS, CHANGE THE TYPE OF PAPER YOU ARE USING, IT MIGHT BE CHEAP PAPER PRODUCTS, LABEL GUM STUCK INSIDE THE PRINTER HOUSING AND EVERY TIME YOU USE IT JAMS.
ROD
Feb 13, 2009 | Dell 944 All-In-One InkJet Printer
HP 3210 getting paper jam because label stuck on roller.
I ran heavy card stock through printer several times, it caught the label and pulled it out on the paper eventually.
Feb 04, 2009 | HP Photosmart 3210 All-In-One InkJet...
Label stuck on a roller?
Looks like label stuck on the toner cartridge. Easiest solution would be to replace toner cartridge or if you can slowly spin the OPC drum on toner cartridge till you find label NOTE: damage to the OPC drum with affect print quality as well as oil from fingers will affect PQ( print quality)
Jan 13, 2009 | HP LaserJet 5000n Printer
Label sheets won't feed, jam
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
good luck..
Dec 22, 2008 | Lexmark Z845 InkJet Printer
Paper jam, unable to remove paper that is stuck
how do you get to the roller because you need a special screwdriver to undo the screws in order to get to the roller
Oct 16, 2008 | Office Equipment & Supplies
Brother 4100e paper jam
Can be tricky people usally damage the fuser rollers removing this jam with pliers/tweezers, it has concertined and stuck after fuser rollers and before exit rollers it will be stuck on the switch best bet is to dismantle properly and remove fuser then dismantle fuser and remove jam, another thing to be concerned about is why did it, three seneraros, Damp paper going threw fuser dries and crincles(use fresh paper from sealed packet), fuser is worn(have fuser replaced), just a bad bit of paper (just have fuser jam removed. Fusrr runs on 240v, covers break easy
Oct 15, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Computers & Internet Logo
David Payne
David Payne
