Hi, I was washing a load of laundry and the load got off balance. Before I could get to it, the washer stopped working. I have checked the fuses, they were fine...the outlet works fine. Nothing will work on the washer no matter if the lid is closed or not. I turn the washer knob to all different setting, I change the water temp, I change the load size...nothing will come on at all. There are no mechanical or electrical noises coming from the washer at all. Is there anything you can recommend for me on where to start looking? My machine is a Whirlpool, Imperial, Style: 907481, LA680P, LA6800XPN1, C60910520 (the last three numbers were from the metal stamp under the lid). Thank you!
5 Suggested Answers
Jimster
  • 240 Answers
SOURCE: Hot/Cold water knob will not work on washing machine
Does the water flow when you have it on warm or cold settings?  If on warm setting and water flow is cold, its probably the mixing valve.  This part isnt that expensive, and not that hard to replace.  Remove the two front console caps, remove the two console hold down screws then flip the console out and then over the top.  You will see two gold cabinet hold down clamps, pop them out, the lift the whole cabinet off the unit.   You will see the mixing valve right where the inlet hoses connect to the machine.  Let me know if you need further help.
Posted on Oct 17, 2007
SOURCE: Whirlpool Inglis IP44002 Top Loading Washer
What I tried was pushing the lid down and I could hear the machine trying to kick into a spin so then while pressing the lid down i rotated to cycle knob slightly ahead and the spinning started. So I geuss I need to fix the connection between the lid and the machine?!
Posted on Dec 21, 2007
SOURCE: Walking during the spin cycle
My GE front load washer model WCVH6800JBB have the same problem. I just purchased and installed it yesterday, 05/04/09. Just like everyone said... when it got to the spinning cycle it walked to the middle of my garage and all the connections in the back of the machine fell off. My husband checked the instruction... There are 4 nut bolts in the back of the machine near the rubber leg (level). You need to take them off and try to balance your machine again. My washer is running very smooth now. Good luck!
Posted on May 05, 2009
  • 119 Answers
SOURCE: WP Imperial 70 Stylmaster #907481 ...H2o won't
is it frozen
Posted on Feb 11, 2010
What does the error code UL mean?
UL means UnLevel. To fix , open door of washer, and redistribute the clothing/laundry in the machine, and press start. It should start spinning again. Sometimes , if you have a overly heavy load of laundry above will not work. What I have done is, put my weight on the machine (upper body laying on the top) until the machine has extracted enough water so the machine will be balanced.
Dec 10, 2015 | Washing Machines
Error code h6
hi friend
hi think ur proggremed chip has been damged so u have to chage it or a timer ckt has a probelm so chenge it
Apr 05, 2008 | Daewoo DW500M Top Load Washer
My husband purchased a Maytag Neptune front load washer model # MAH8700AWW about 5 years ago. The washer works great and we have never had any problems until recently. We just had pergo floors installed in...
you may need to put some anti vibration shock pads under the legs or some two sided tape to put on the feet to help secure it to the floor it may be slipping on the new floor surface
Feb 13, 2011 | Maytag Neptune MAH9700 Front Load Washer
When doing a load of laundry the washer will stop at the rinse cycle and not drain or spin out the excess water
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 03, 2011 | Frigidaire Affinity ATF6000F Front Load...
Washer spins than it gets off balance and shuts
Hi, Washing machines can become unbalanced when the wash load has too much weight in one area of the basket. A machine in good working order can handle most problems through its balancing mechanisms. However, when washing heavy single items such as comforters, the machine's tub can become so lopsided that it damages the washer.
Washing machines that get unbalanced can shake, make banging noises, and even more across the floor. When machines are secured in one place, they can vibrate and bang so much the entire house shakes and things fall off shelves. This is not good for the washer. Bolts can come loose, and parts can break.
When washing heavy items such as pillows or down coats, stay near the washer so you can correct any balance problems as they occur. Some washers have an automatic shut-off feature when they become too far off-balance. If yours does not, stop the spin cycle, open the lid, and redistribute the load. If this is a continuing problem, you may want to wash heavy items at a coin-operated laundry in a heavy-duty machine.
Take care
Jul 14, 2010 | Whirlpool Washing Machines
Fisher & paykel GWL11 washer won't rinse
sounds like you have two problems, the burning smell is probably the pump,out of balance is usually due to worn aout suspension rods
Oct 14, 2017 | Fisher and Paykel GWL11 Top Load Washer
Washer stopped after filling, small load
I would check and make sure the lid is not bent or bowed. If the middle part of the lid is too far down when closed, the machine thinks it's open and wont run an agitate or spin. If it is bent, just bend it back for a quick fix.
Dec 03, 2007 | Amana ALW880WH Top Load Washer
My washer shows UE code
UE code is an "unbalance error". Believe it or not, it is possible to unbalance a front load style washing machine. Usually caused by trying to wash smaller loads where the drum spins to try to distribute the weight evenly. With less laundry, you cannot distribute enough weight evenly around the drum and sometimes will cause an unbalanced load. If your problem is not a simple loading issue, it could be the balance sensor, loose wiring, or possibly the main control board. I hope this helps.
Apr 21, 2007 | LG WM-2077C Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
