Question about SMC (SMCWBR14-G2) Router
Where is reset button located, please. - SMC (SMCWBR14-G2) Router
  • 124 Answers
The reset button is at the backside of the box ( near to the wireless antenna).
That tiny black button more over looks like a black dot.
Best Regards
Posted on Nov 06, 2010
Testimonial: "Oh! Thanks, please. It has solved my problem."
How can I reset my Polaroid Tablet?
In the event that the tablet freezes or does not function properly, press the RESET button located on the bottom panel.
Follow the link to see the diagram of where to find the switch, it is in the bottom left corner of this web page. Zoom to maximum (200%) to clearly display the picture showing the location of the reset button.
The button is tiny, you will need to use a paper clip or the tip of a stylus to press the RESET button.
Data stored on the tablet will not be affected by using the RESET button.
The location of the reset button is the same on all models.
May 24, 2014 | Polaroid 4.3" Internet Tablet
Where is the reset button?
it is located next to the eject switch
Dec 26, 2012 | Panasonic NV-DS38 Mini DV Digital...
What if I can't remember the name and pass word I gave it
Please see below.
Hope this helps!
Reseting the router to the factory defaults will delete any changes you have made to the router, including any security settings. This should be used as a last resort.
Reset Button dir-628-300x300-256x256.jpg The steps involved in reseting the router is simply pressing a button located on the router. The image below (courtesy of D-Link) shows where the button is located.
D-Link DIR-628 Reset Button Location
To reset your router, use the following steps:
  1. Press the reset button for 10 seconds. You can use a small object, such as a paper clip to hold down the button.
  2. Do not power off the unit while the router is being reset.
    The unit should now reboot. Wait about 30 seconds before logging into your router.
  3. Open up your Web browser and enter in the address bar.
  4. For the login, enter admin as the ID and leave the password blank.
Apr 18, 2011 | D-Link DIR-615 Wireless Router
Cant log on to router
If you have forgotten your router's password, please follow the instructions below to resolve your issue.
The router can be set to factory default by pressing the Reset button of the router and resetting through the router's web-based setup page. Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. Any settings on the router will be erased and the router's IP address will become "," the username is still blank, and the password will be "admin."
To perform a hardware reset on your Linksys router follow the steps below.
Resetting the Router Using the Reset Button
Step 1:
Take note of the current settings of the device before resetting.
Step 2:
Press the Reset button of the router for 30 seconds.
3798-001.png Figure 1: Location of the Reset button of a Linksys BEFW11S4 router.
NOTE: If your router does not look like this, refer to the other images below:
4030-022.png Figure 2: Location of the Reset button of a Linksys WRT54GX router.
4030-024.png Figure 3: Location of the Reset button of a Linksys WRT54GC router.
NOTE: If the image of your router is different from the ones shown above, please consult your router documentation.
Step 3:
If the normal reset does not work, unplug then plug back the router's power adapter while pressing the Reset button.
To reset the router via its web-based setup page, follow the steps below.
Resetting the Router Using the Web-Based Setup Page
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using Mac to access the router's web-based setup page, click here.
Step 2:
When the router's web-based setup page appears, click Administration then Factory Defaults.
4008-003.png NOTE: If the screen on your router's web-based setup page looks different, click here.
Step 3:
Look for Restore Factory Defaults and select Yes.
4008-005.png Step 4:
Click 4268-009.png.
Nov 11, 2010 | D-Link DI 514 Wireless Router (DI-514)
How do I reset the "Change Oil" light on a 2000 Pontiac Grand Am?
Hello tiffinkie: My name is Roger an I will help you. First open the passenger door and locate the fuse panel located in the end of the dash cover. Remove the cover turn the key on. Do not start the motor. Push the reset button located at the top of the instrument fuse panel.The CHANGE OIL light will start to flash.Press and hold the RESET button again. The reset is complete when you hear the chimes sound and the CHANGE OIL light goes out. Should you need further help please just ask. Please rate your answer. This way I know it was helpful. Thank You for using Fix Ya. Roger
Jun 18, 2010 | 2000 Pontiac Grand Am GT
How do I reset this unit back to factory default settings?
Dear Friend,
There is a small reset button on your device. press that button with the help of some pointed device. Normally this button is located at the back of the router for exact location refer your router's manual.
Please rate the answer.....
Jun 16, 2010 | Computers & Internet
I have a proform crosswalk calibre complete treadmill and the incline is not working. I know when it happened before I pressed the reset button and it worked - but I can't remember where the reset button...
Plug in the power cord . Next, locate the reset/off circuit breaker on the treadmill frame near the power cord. Switch the circuit breaker to the reset position
May 06, 2010 | Exercise & Fitness
Megellan Maestro 4210 gps slow to find current location
I recommend you to reset it . Resetting should solve this problem .
Here is how to reset your Maestro :
1:Locate the button marked "Reset" on the left, right or bottom of the unit.
2:Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
3:If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
Apr 14, 2010 | Magellan Maestro 4210 GPS Receiver
My screen shows lines and when I take a picture
Please reset the Camera and check if that helps.
To reset the Camera, just press the RESET button using a sharp-pointed object. The Reset button is located inside the jack cover. Please make sure that the Camera is turned ON while pressing the RESET button.
If the issue still persists, power reset the Camera and check if that helps.
To power reset the Camera, please remove the Battery Pack from the Camera and then press the POWER button for 15 seconds.
Then, reinsert the Battery Pack after 1 minute, then turn ON and check if that helps.
Thank You!
Apr 09, 2010 | Sony Cyber-Shot DSC-P32 Digital Camera
How do i reset my router
To hard reset the router:
- locate the factory reset button located on the back of the router, between the antenna and the ethernet jack
- with the power on, press and hold the button
- the power light should turn off, then after about 10 seconds, it should turn back on
- release the button and wait about 1 minute for the router to reset
You can also soft reset the router by logging into the administration panel and selecting "Erase" under the "Settings Backup" menu.
Sep 13, 2009 | NetGear WGR614 Wireless Router
SMC (SMCWBR14-G2) Router Logo
240 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
