Question about Clarke Power Products Clarke 130EN Mig 110 Volt
My welder pops bad when trying to weld and poorly
  • 92 Answers
Increase Voltage.
Posted on Nov 29, 2011
  • Ron Jones
    Ron Jones Nov 29, 2011
    I assume that your on about spatter ? this usually indicates low voltage, increase the voltage on your set.
Stick welding fillets in steel: I have a lot of trouble with one side not tying in.
Not enough amps from the welder. Poor ground from the work piece to the welder.
Feb 24, 2015 | Welding Tools
Century wire feed welder
Sounds like you need to learn to weld
or Metal is way rusty or bad Ground or Amperage too high
Nov 16, 2013 | Welding Tools
Wire feed is sticking when I try to weld. If I increase friction it only jams the wire. I have never cleaned of replaced the liner. Is this my problem? I don't use this welder that much.
Cleanliness is important when it comes to Mig welding. Any rust, dirt, dust, oil is liable to be deposited in the whip liner. If it's just a dirty liner you can try cleaning it with a solvent that doesn't leave an oil deposit (electric motor cleaner, brake cleaner, that sort of thing) compressed air and flexing of the whip.
Make sure your whip hasn't been crimped, if it has then no amount of cleaning will restore it to operation.. a new liner is the only reasonable answer.
It's possible that a bad tip can cause feed issues. Miller type tips are the worst, in my experience, sometimes you just get a tip that will weld to the wire when the current passes between them. I've worked in shops where I might go through three tips in five minutes and then hit one that would last all afternoon. If the wire sticks and you can hold the gun up and rotate your wrist and you feel a 'pop' and the wire jumps out of the tip then just change the tip out. Excessive roller pressure with a tip that's sticking to the wire can really make trouble for you. Nozzle dip is your friend sometimes with tip sticking issues.
Copper clad wire is not particularly friendly to liners, the copper is liable to flake off in the liner. I use bare wire, I bag the wire in a plastic bag on the feeder and I wrap a scratcher pad on the wire just before it goes into the feeder and I find that I have few feed issues. Wire that has even a trace of rust should be discarded as it will both fill your liner with rust and give poor quality welds.
lp
Oct 11, 2010 | Hobart Handler 140 Mig Welder
Wire speed or heat problems
can you adjust your voltage settings? you may be welding on material that is thicker than what your machine is designed for. your ground clamp may be loose or dirty.
it should sound more like bacon frying than popcorn.
Apr 11, 2010 | Clarke Power Products Clarke 130EN...
Was welding and welder quit acking wire feed and gas still work i have a century pro wire welder model 170gs
Check earth wire has not become dislodged,
Pop the cover and check for burnt terminals, often overheating of the transformer can cook a terminal, easily cleaned up and replaced.
Mar 31, 2010 | Welding Tools
My welder no longer produces high quality welds
You could have a poor ground clamp connection. Check that. also increasing the gas flow will cause turbulence at the weld, this can have a negative effect on weld quality.
Check your connections, check your liner, actually, replace it if you haven't recently.
Feb 15, 2010 | Lincoln Electric LE 83180 Century...
Clarke Power Products Clarke 130EN Mig 110 Volt Logo
145 people viewed this question
Top Clarke Power Products Welding Tools Experts
 Kenneth
Kenneth
Wade Mobley
Wade Mobley
Are you a Clarke Power Products Welding Tool Expert? Answer questions, earn points and help others
