Question about Nintendo Super NES Console
SNES doesn't display?
I recently found my super nintendo, and figured I'd hook it up and play. So I found everything for it, plugged it into the wall and used the rf switch to plug it into the antenna/cable port on my TV. Mind you, I didn't have it plugged into a antenna/cable connection, so the antenna out doesn't have anything plugged into it. I hooked it all up and turned on the TV and lo and behold - nothing happened. Just a black screen, making no sounds or even attempts to work. The red light on the console came in just fine. So I take out the game, put in another. Nothing. I tried all the games I own and got a grand total of no success.
is there something I did wrong here?
  • 1 more comment
  • BlueBMW Jun 21, 2008
    I had a perfectly good working SNES that I hadn't played for at least 3 months. I reconnected it up and whenever i turn it on, the red light comes on, and my tv flickers for a split second and shows a blank screen. Doesn't matter if I use the multi out or if i use RF, same blank black screen. I cant figure out what would make a system suddenly not work. I've tried cleaning the system contacts and every game contact. Different games, different TVs, different video cables. Always just a black screen that flicks when you switch the system on or off (telling me its getting some sort of signal)
  • Anonymous Jan 03, 2009
    I had my SNES in storage for a few months and when I decided to play the screen on the tv was black. All of the connections are correct and I have cleaned the system several times and all the cartridges as well. I am wondering if its the 62-pin port.?
  • gary697 Feb 24, 2009
    Does anyone know if this was the cure for this fault do you know the board reference for the CIC chip
The CIC chip, also known as lock out chip, may have gone bad. Here is a quote from a site I found.
"Every SNES control deck has a regional lockout chip (known as a CIC), as does every original SNES game cartridge. Before a game is loaded, the console will attempt to communicate with the CIC chip on the game cartridge. If the CIC chip doesn't respond or does not correspond with the consoles CIC, the console won't load the game. In most cases, a black screen is displayed."
http://www.chronicgames.net/articles/snes-museum.aspx
Yea basically I am having the same prob with my system and I am trying to fix it. Ill let ya know if i figure it out
Posted on Jun 30, 2008
  • tquick Oct 26, 2010
    You can acutally disable the lock outs chips some how Iv am doing that on All of my consoles.
Snes red horizontal lines
When hooking a super Nintendo or an NES system or a sega genesis system to a digital tv you need av cables for it to work then instead of using an rf switch
Sep 30, 2012 | Nintendo Super NES Console
Snes doesn't read games
Well it sounds like the console it's self needs to be cleaned out then 4.5 mm bit screw driver to open her up lukue games sell those 4.5 mm game bit tool compressed air to clean it out and it should work
Sep 29, 2012 | Nintendo Super NES Console
I get audio for my SNES through the AV cables but get no video. They are refurbished cables purchased from Nintendo. What else could be wrong? Do HDTV's not read SNES very well?
Well you could try this plan hooking up a DVD player or a VCR machine to the HDTV and then plug the super nintendo console into the VCR or the DVD player then. It might work after this. 4 stars if this suggestion works.
Jan 20, 2011 | Nintendo Super NES Console
SNES games are tinted green on TV
Well you could try and fix it then.
Apr 23, 2010 | Nintendo Super NES Console
It wont turn on
I never had a SNES, But I had a Super Nintendo Box.
Contact nintendo, www.nintendo.com
If you were to call Nintendo,they can't do nothing about this. It's too old.
Mar 06, 2010 | Nintendo Super NES Console
Nintendo not working with flat screen tv
The RCA red/white/yellow output of the SNES will plug into any similar input on your TV. If you're missing that cable, do a search on 'super nintendo cable' and you can buy one.
If your TV has only HDMI and no component inputs, then Belkin makes an adapter for that.
You old zapper gun won't work on a LCD screen because the refresh rate of the TV is too fast,so no Duckhunt for you.
Oct 22, 2009 | Televison & Video
Hi i just bought a super nes system it came with RF switch power unit which i have connected to the appropriate connections, i have an LG TV with an golden eye and don't seem to be able to tune the...
Make sure everything's connected in the correct sockets. Turn the SNES on, change to one of the Analogue channels (one of the channels which you control with the TV remote) and start scanning for a signal. The RF cable has to be connected to the analogue port (where a TV aerial would plug in to get analogue channels) and the SNES needs to be switched on.
The alternative is to get a SCART-compatible cable that works with a Gamecube or an N64 and use it with the SNES, as Nintendo had the foresight to add an EXT port which'll let you play the SNES on an AV channel.
Jul 09, 2009 | Nintendo Super NES Console
Extensively tested but unresponsive SNES controllers
Well it could be the controllers but its probably that one of the wires have gone bad in the super nintendo. Maybe try replacing. Just and idea though.
Mar 24, 2009 | Nintendo Super NES Console
Snes screen jumps on certain tv
Okay, what I would try is hooking up the snes using the n64 cable. right next to the rf slot in the back of the super nintendo is a slot thats the same video output as the n64 you can plug in the rca cables from it and see if they work
Feb 27, 2009 | Nintendo Super NES Console
My Super Nintendo has a Coax output. My tv only takes component cables. What can I do so that everything will work?
Easy!! Im a game collector and i still have a SNES. The solution is simple
If you have a digital box then that means that a cable goes to the box and from the box a cable goes to your Tv. What you should do is unscrew that cable that goes to your Tv and you will screw the SNES coax cable notice that the SNES cable has and input coax cable entrance aswell so you can screw the Tv cable back in to it so you wont miss watching your fav channels after you finish playing awesome classic games on the SNES
Dec 07, 2008 | Video Game Consoles & Games
Nintendo Super NES Console Logo
1,000 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
