Question about Friedrich P-12 Air Conditioner
Keeps shutting off
Ac keeps shutting off, because waterpan is full. The pump isn't working. Brandnew  (just bought it)
  • rdarling Jun 15, 2008
    yes, the unit has a drain hose that is properly installed
  • usbus May 11, 2010
    Are you allowing for proper drainage for the ac?
    Scholar:
  • 54 Answers
Be sure all packing materials are removed, any straps or cardboard that prevent movement/damage in shipping will prevent operation.
Posted on Jun 15, 2008
Plugged in, NOT Charging!
If new then it's defective. Return that bad boy.
Feb 14, 2015 | Computers & Internet
1994 ford ranger 2.3 fuel pump has burned out after 2 weeks, Why?
how full do you keep the tank..electric pumps will cavitate when the tank is less than 1/4 full..they use the liquid tokeep cool..also have you put on a new filter? if not do so.. theclogged filter will make the pump work harder..
Jan 15, 2014 | Ford Cars & Trucks
Ford F250 Super duty V10 AC stopped working and now I hear a noise when I turn fan on
The a/c noise is either the clutch going bad and slipping which is very common on the V10. When its slips its not pumping, a clutch kit can be bought at any parts house for around $45-$50.00. About 30 minutes to put on. The other is a pump bearing going bad, which isn't a quick fix and needs the whole pump replaced, if that's the case always replace a new dryer when replacing the pump,, I would put money on the clutch...
Mar 25, 2013 | 2003 Ford F250 Super Duty Crew Cab
It keeps saying memory card is full. Bought a new memory card and put in and it still says the card is full.
Are you sure that isn't "internal" memory card is full message?
Sometimes, when "internal memory card is full" there is no more space in the camera's internal memory. Your camera has 16 MB of internal memory. The number of pictures you can store depends on the picture size setting you have selected on your camera. Keep in mind that the camera always uses internal memory, even if a card is installed (auto default).
If really, the problem is in the "SD memory card", I suggest make some backup all files and reformat the SD. Try formatting it in the camera, there should be a process in your owners manual for doing this; donw formatted SD in your computer, isn't good.
Hope helps.
Apr 28, 2011 | Kodak EasyShare One Digital Camera
Little Giant Condensate pump runs for 1 sec when res not full
Is there a check valve in the pumps discharge fitting? If there is it may be stuck open or broken allowing some of the water to return to the reservoir once the pump shuts off which then may lead to the brief cycle between full cycles.
If there is not one, install one to keep any water from backing back into the reservoir and that should stop the short runs.
Aug 06, 2009 | Plumbing
Friedrich P-12 Air Conditioner Logo
172 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
