Question about LG Televison & Video
My picture on a LG A51QGT420X arcade monitor is diagonal
How to replace a arcade Big Buck Hunter Pro TV?
If your game has a CRT monitor you will have to stay with a CRT. You can get a great picture from an LCD or LED unit but the guns won't work.
May 07, 2014 | Video Game Consoles & Games
How can I fix my glitchy Tron arcade machine?
it sounds like your vertical or horivontal sync is going out what i would do is take the old monitor out and i would buy a arcade rgb cga ega yup to vga hd video converter you can usually find them on ebay for 40 dollars or so then all you will need is a flat screen that will except a vga connection you tube can show you how to install these items into your game i have done several and you would be surprised how easy they are installed and if you get a used monitor you can save a lot of money also
Jan 19, 2013 | Video Game Consoles & Games
Can you use an xbox arcade on flatron LG L1810T? If so which setting does it have to be on as the tv is not recognising the xbox at all
HI,
Your LG LCD monitor has a white DVI connector for connecting the signal cable.
You would reqire either an HDMI to DVI(male connector cable for the xbox) so that you can hook the hdmi cable to the xbox and other end to your monitor.
The cable would look something like this
http://hardware.teamxbox.com/reviews/xbox-360/40/Xbox-360-VGA-HD-AV-Cable/p1/
Thanks
proton
Jun 06, 2010 | LG Flatron L1810T 18.1" LCD Monitor
The monitor works just fine when I turn it on and displays the picture perfectly, however, after 15 to 20 minutes the picture comes off and the screen displays a series of diagonal lines. Why does this...
It sounds more like a monitor hardware problem than anything else being wrong, but the definitive answer would be to try it on another PC.
If it does the same you know it's the monitor; if not investigate your PC.
Mar 25, 2010 | Gateway FPD1760 17" LCD Monitor
The sound loads, but no picture at all. I have an original 1981 cocktail Galaga game.
HI Kristen,
IF you can "play" the game blind, that shows the game board is working fine.
The issue can be in the monitor. That can be many reasons there is no picture .Check all plugs and connectors. Make sure the back of the CT is plugged in. Power to the monitor is present. Do you have amanual for the arcade? You should be able to find one online.
Do you see the picture tube lit up, not on the screen, but in the back of the neck of the tube? (Orange glow from the filament)
I"d suggest that you seek out a qualified service person for the game, if you are not familiar with working on electronics.
There are fuses in the cabinet power supply I believe, check those. Could be something as simple as the fuse going to the monitor.
Nice machine, hope you get it going.
Mar 07, 2010 | Namco Ms. Pacman Galaga Cocktail Video...
What is happening when I turn on my monitor ?
try to align the display, Keep away the Speekers and other gadgets with Magnate at least 3 ft from the display unit.
Jul 02, 2009 | LG Flatron L1750S 17" LCD Monitor
No picture but sound and controls work
your monitor high voltage circuit has failed troubleshoot it as any tv
May 22, 2009 | Arcade Ms Pac Man / Galaga Cocktail Table...
Nintendo sharp xm1801-n arcade monitor doesnt work,replaced the capacitors
the flyback has died and or the rgb coil around the tube is burned up. no repair for either as no parts are available anymore
Mar 31, 2008 | ViewSonic VX910 19" LCD Monitor
DIAGONAL LINES LG PLASMA
Find out the board number, contact LG Zenith company tell them your problem.This way it lets you know wheather or not you want to fix it ask them how much is board.www.LG zenith.com. Good Luck. ThankYou for using FixYa. Have a NIce Day.
Feb 08, 2008 | Televison & Video
Televison & Video Logo
Computer Repairing
Computer Repairing
