Question about Sharp Microwave Ovens
Change the bulb on a sharp R 450 D microwave - Sharp Microwave Ovens
    Brigadier General:
  • 8,909 Answers
Remove mains power, remove the case from the microwave and the lamp is near the door catches above the transformer.
Remove the lamp and fit a new one.
Hope that helps.
Posted on Nov 06, 2010
  • 1 more comment
  • ken7164 Nov 07, 2010
    The lamp is covered by a metel cover and the globe does not fit through the hole in the top of it. It looks as if the entire cover needs to be removed and could be a bit of a mission. The oven needs a service anyway and the LED display is also faulty. Perhaps I should just take it to the service guys and get ripped off.
  • specialistel Nov 07, 2010
    The lamp is fixed to the metal cover and is a special fitting. As you say the display is faulty as well, the replacement display labour should easily cover the cost of the labour involved replacing the lamp.
    Hopefully you will go to a recognized repairer, in that way the cost is regulated by Sharp.
    Hope that helps.
    Will take it to Sharp but it is still a rip off.
HOW DO i CHANGE THE BULB IN MY SHARP R-651ZM MICROWAVE OVEN
Changing the light bulb on your Sharp carousel microwave will allow you to have needed light inside the oven. Microwaves are not designed for consumers to change the light bulb due to manufacturer liability, but it can be done. Following the proper steps will ensure a successful installation. Step 1 Unplug the Sharp carousel microwave from the electrical outlet.
Step 2 Locate the screws around the outer cover of the Sharp carousel microwave and unscrew all the screws.
Step 3 Lift off the covering.
Step 4 Locate the bulb and unscrew. Screw in your new bulb.
Step 5 Replace the cover and screw back tightly. Once done, test your new bulb.
Oct 10, 2017 | Sharp Microwave Ovens
How to change R-430cs light bulb
You have to take off the cover off the microwave and you would see an plastic cover on top off the bulb.One screw should be holding the cover, take it off and you should be ready to change the bulb.
Sep 05, 2014 | Sharp R-430CS Microwave Oven
How do I find a replacement light for my sharp r-320fw microwave
Sharp Carousel Microwave / Light bulb replacement: http://youtu.be/36RE1bG0aVk
Check out this video, it may help you. Looks like they're a common bulb.
Sep 03, 2014 | Sharp Microwave Ovens
How do I replace the light bulb in a Sharp R-308KK microwave?
Google the model number with "how to change bulb" and there are some with video instructions on You Tube the Google searches should also bring up.
Nov 07, 2012 | Sharp R-308KK / R-308KW 1100 Watts...
How do i change light bulb in sharp carousel R-320HQ microwave oven?
open cover and
change bulb
before open it turn off woven at last 30 minutes
Jan 30, 2011 | Sharp R-320HQ Microwave Oven
How do I change the light bulb on my sharp R-530BS
You have to remove the shell. Screws are in the back and may require special tool (torx, security). Be certain to remove power and be very careful as the shell will have many sharp edges. The bulb is along the right side (as you face the oven opening). It is a specialty bulb you will have to order from an appliance parts house (or try e-bay).
Apr 15, 2010 | Sharp R-530BS Microwave Oven
I have a Sharp model R-1610 Microwave. The work/night light does not work. I"ve changed the bulbs.
Does it operate with a membrane-type touchpad?
These things seem to be problematic as the microwave ages.
They are usually replaceable, and the cost is not great. I just installed a new touchpad on an LG, and it cost $25.00 plus shipping.
Oct 12, 2009 | Sharp R-1610 Microwave Oven
Hi our Sahrp Carousel microwave LCD panle display is not working
You have to replace the control board. Sharp has had problems with the display boards for awhile. There is no bulb or fuse you can change.
Mar 15, 2009 | Sharp Microwave Ovens
Sharp MICROWAVE CONVECTION R-8465
I fixed it by reading how to fix another model. What you do is take the cover off, the bulb is on top. Make sure that you unplug it before starting.
Jan 12, 2008 | Sharp R-320H Microwave Oven
Where is the light bulb in an old Sharp Carousel Microwave?
Microwave_svc's site is awesome! I was able to get all the help I needed for a similar Sharp Carousel microwave. My bulb was simply loose in the socket base causing intermittent bulb lighting. Microwave_svc's helpful links got me to the service manual and, along with a nice set of "tamper-proof" screw compatible TORX bits I bought at HarborFreight, I was easily able to get cover off, remove bulb socket, tighten bulb, re-install bulb socket, button unit back up, and, voila, the light now works without intermittent blinking. FIXYA!!!!
Many thanks to guru microwave_svc!!!!!!!
Nov 21, 2007 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
56 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
