Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Mower switch SO the switch reading  from upper right reading clockwise should be Black black red white?
    Champion:
  • 313 Answers
Give me your fax #
Posted on Jun 16, 2008
  • 2 more comments
  • mr aicnelav Jun 16, 2008
    i can't attach the parts diagram. but i can fax it for you.just give me the fax #
    looking at the switch top actuator on to top side.
    1.first top terminal on your left side is for white wire
    2.second lower terminal your right side is black wire from motor.
    3.third lower terminal on your left side is red from motor
    4.fourth lowest terminal in your right side is black wire to the
    power cord to plug etc.
  • mr aicnelav Jun 18, 2008
    sorry can email the attachment for the diagram, pc won't allow me.
  • mr aicnelav Sep 19, 2008
    connection diagram for most B&D mower
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
I need to wire my DJ-20 Jointer back to 230 and I don't have schematic Suggestions?
Assuming you have a standard dual-voltage single-phase motor, your wire colors should be:
T1 - Blue
T2 - White
T3 - Orange
T4 - Yellow
T5 - Black
T8 - Red
For 220V wiring, you want:
Line 1 (to Black wire from switch):
Blue
Black
Line 2 (to White wire from switch):
Yellow
Tied together with a wire tie:
Red
Orange
White
This should make it so the shaft spins counter-clockwise. If you need it to spin the other direction, switch the red and black wire from the motor.
Jun 23, 2010 | Delta X5 Dj20 8" Precision Jointer
In replacing push button switch INDAK 681064-01N I forgot to record the wiring sequence, please help
If you look at the switch with the pushbutton on the top, the white wire from the cord to the motor attaches to the upper left terminal, the red wire from the cord to the motor attaches to the lower left terminal (just below where the white wire attaches), the black wire from the cord to the motor attaches to the upper right terminal and the short black wire going to one of the two pins that plug into the extension cord attaches to the lower right terminal (just below the where the black wire to the motor cord attaches).
Jul 11, 2009 | Black & Decker 19" Electric Lawnhog...
Switch diagram needed
Funny, I came here because I just opened up the switch case on my MM875. Hold the switch so the terminals are on top. Call the black switch (the part you push in to power up the mower) north. The north post gets white (metal connector). The west post gets red (plastic connector). The east post gets the black that comes from the mower's motor (plastic connector). The south post gets the black that comes from the outlet (metal connector)
(Black Plastic Switch)
White (Metal)
Red (Plastic) Black (Plastic--from motor))
Black (Metal--from outlet)
May 22, 2009 | Black & Decker 19" Electric Lawnhog...
Need wire schematic for starter switch
I am holding the switch part (INDAK 681064) with the black pushbutton switch to the right.
The two wires on the top are Red then White. The two wires on the bottom are both black.
Apr 10, 2009 | Black & Decker 19" Electric Lawnhog...
Switch connection
position the switch terminal facing you & the black round lever facing up postion.now all left side terminal are for red & white.
next step all right side terminal are for 2 black wire. doesn't matter the red & white are top or buttom as long as its in the left side only.
Aug 25, 2008 | Black & Decker 19" Electric Lawnhog...
Black&decker 19"electric switch
the black actuator that moves on & off facing up. looking at the switch terminal facing u. ok. all left side terminal for white & red. all right side terminal are for 2 black wire. if you have fax machine i can send u the wiring. dennisv53@yahoo.com
Jul 16, 2008 | Black & Decker 19" Electric Lawnhog...
Black and Decker MM525 hard wiring diagram
the connection the are not right. top left side is for white wire.buttom left side is for red wire. top right side is connected to black wire from motor. buttom right side is for is going to the
extension terminal. good luck
Jun 02, 2008 | Black & Decker 19" Electric Lawnhog...
WIRING DIAGRAM? FOR BLACK AND DECKER ELECTRIC LAWN MOWER
the pic says the connection are not right.all left side connection are for brake which is the red & white wire. all right side connection are two black wire.
Feb 06, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
137 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
