Question about Whirlpool Washing Machines
THE F13 CODE IS SHOWN AND THE MACHINE DOOR WOULD NOT OPEN UP
  • 77 Answers
F13 is a door lock issue. Firstly push the door hard towards the frame and then pull imediately back towards you it may take several attempts but the door will open, it may seem harsh to do this but i have done it a few times and it works. This should reset your door lock if the problem persists then replace the actual pin that is on the door (should have 2 screws holding it in place) that enters the cabinet. Not the door lock that is inside the cabinet.
Hope this helps
Posted on Nov 06, 2010
Error code F13 showing on whirlpool ghw9300pw2, please help
Controller fails to detect door lock triac correctly This error code is displayed if the main control unit fails to detect the door lock triac correctly. Also, if the controller cannot unlock the door after 240 seconds after the cycle is completed then this error will be shown.
If displayed switch the washing machine off completely, recommend disconnecting it from the mains supply for a few seconds. Switch it back on and the controller will attempt to unlock the door once more but, if it fails to do so in the same 240 seconds the error code will be displayed once more.
  • Check all wiring and connectors between the main controller and the door lock
  • Check main control unit, probably requires to be replaced
Mar 09, 2015 | Whirlpool Washing Machines
F13 error code
Try unplugging the machine for a few hours to rest the code on the board.
Oct 14, 2013 | Neff W5340X0 Washer
Give code F13 and red "Service" indication at the end off programm and the door will not open. Solution push the "reset" button for at least 3 seconds give the same result. The door...
*Check mechanical linkage from dispenser motor to the top of the dispenser.
*Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
*Check Dispenser Motor.
Jun 04, 2011 | Washing Machines
F13 and door not opening washing stuck ith cage .
Hi
F13 is a door lock error which means that the door lock is bad and should be replaced. To unlock the door you can leave it unplugged for around 10 minutes and the door will unlock. Hope this helps...please post back for further assistance.
Daniel
May 10, 2011 | Whirlpool AWOE8748 Front Load Washer
My mum's AWOE8748 shows F13 it is only just over 1 year old how can I fix it.
Hi. The F13 error code indicates a problem with the doorlock mechanism.
Whirlpool have identified issues with some models and door lock errors so it may be adviseable for you to contact whirlpool customer services.
The error can lead to the door jamming shut.
First of all open the door, if you can, and check that the lock latch on the door is level with the door lock hole on the front panel of the machine. Sometimes you can accidently lean on the door when putting in or taking out the washing sending the lever and hole out of alignment. You can put pressure on the door to align it either way if not level. If you need more help then repost.
What area are you in?
Jan 25, 2011 | Whirlpool AWOE8748 Front Load Washer
AWOE9558 Whirlpool Washing machine is displaying a F13 code! Please Help! It wont open the door or finish the wash, what do I do? Thank you
F13 is usually a dispenser circuit error, which means the dispenser motor is not able to move to its proper position.
This maybe because the dispenser motor has failed or the mechanical link from the dispenser to the motor is broken or the wiring to the dispenser motor has become detached.
Try pushing the dispenser door closed more and see if that has any effect otherwise i think you will need a repair man.
Nov 30, 2010 | Whirlpool GHW9400 Front Load Washer
I have a whirlpool 6th sense washing machine with a warning light coming up and F13 on it.This machine is only 6 months old
f13 is a problem with the door lock, I have the same machine and it takes 4 minutes for the door latch to open and if it dont in the 4 minutes F13 comes up and the machine will go off and not start again.
Sep 30, 2010 | Washing Machines
Whirlpool washing machine showing f13 code so turned off now got no power and door wont open ?
did you ever get a solution for this from anyone. I have exactly the same problem? F-13 code, no power, door won't open
Sep 22, 2010 | Washing Machines
My AWOE8748 had a fault code F13. It has now switched itself completely off.
F13 indicates "Dispenser Circuit Error" in your washer.If the dispenser motor is not able to be driven to it's proper position this error code appears.Check mechanical linkage from dispenser motor to the top of the dispenser. The wire harness connections to the dispenser motor and Central Control Unit (CCU) would have been faulty so check for those.Also do a final check on dispenser motor.
Thank you !!
Jun 20, 2010 | Whirlpool AWOE8748 Front Load Washer
Washing Machines Logo
210 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
