Question about Kenmore Oasis HE 27082 Top Load Washer
Shut off after start then read F1 - Kenmore Oasis HE 27082 Top Load Washer
  • 1,557 Answers
F-1 is an internal sub board electronics fault it will need to be looked at by a lic tech the main pcb may need replacing . i dont normaly recommend this but try plugging it in and turn on then off several times in slite cases it can reset the pcb
best of luck to you
Posted on Nov 06, 2010
Bois on d h215
Are you trying to enter (get into) BIOS?
This is for another model of Lenovo on the Lenovo.com website, but it will likely still work:
How to enter IdeaCentre Q700 BIOS setting screen
To start the Setup Utility program, do the following:
1. If your computer is already on when you start this procedure, shut
down the operating system and turn off the computer.
2. Press and hold the F1 key then turn on the computer. When you hear
multiple beeps, release the F1 key.
To start the Setup Utility program, do the following:1. If your computer is already on when you start this procedure, shut down the operating system and turn off the computer.2. Press and hold the F1 key then turn on the computer. When you hear multiple beeps, release the F1 key.
Aug 29, 2014 | Lenovo IdeaCentre H215 PC Desktop
Our Fridigaire range oven will not shut off. In
F1 is a bad oven control. (clock).
It must be replaced.
Unplug the range.
Remove the screws from the rear panel.
Remove the wires from the (clock).
Replace the EOC (clock) with a new control and bake me some cookies.
Feb 02, 2010 | Frigidaire Ovens
My compaq presario v5000 a 5240NR was working fine
Fn+F1 Decreases the display brightness. Fn+F2 Increases the display brightness
Oct 01, 2009 | HP Compaq Presario V5000T Notebook
When you turn on the oven, display reads CLN or F1.
that means the oven either needs cleaned or that the oven is stuck in cleaning mode i suggest unplugging it for a few hours or clean the oven
Sep 30, 2009 | Amana Kitchen Ranges
Create a barcode for F1 and F2 using Labelview
If you have created your barcodes as "F1" and "F2" you will have to create two Advanced Data Formatting rules with the LS2208 Product Reference Guide. This link will take you to the manual. Print only the barcodes you need from the list below then scan them in the order they are listed:
Begin New Rule
Specific String at Start
F (from the Alpha-numeric section of manual)
1 (from the Alpha-numeric section of manual)
End of message (from the Alpha-numeric section of manual)
Send F1 Key
Save Rule
Begin New Rule
F
End of Message
Send F2
Save Rule
That should do it!
May 06, 2009 | Symbol LS2208 Handheld
Virus...need to reboot
hi.. shut down ur system. re start again. hen ur computer restarts keep pressing F1 key. it will auotomatically guide u to the re boot process... the F1 key is also called as boot menu key..
pls rate me
Jan 21, 2009 | Averatec 1000 Notebook
F1 display and alarm will not shut off
hi there,
can you tell me the model # on your stove please?
Sep 13, 2008 | Maytag CWG3100A Gas Single Oven
Beeping, flashing, oven door locked, display shows F-1
F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) BUT you also need to check the Oven Temperature Sensors The Oven Temperature Sensors should read room temperature, 70°F, the resistance is 1000-1200 ohms. make sure you pull off the wires to measure the sensor's resistance and it reads open it is bad. and you will have to replace it too. hope this helps.
Sep 05, 2007 | Jenn-Air SCE30600 Slide-In Electric...
My display window reads e1 and f1 and we can't get anything to work
tholt, for the model posted F1 E1 is a eeprom error in the board. Try pressing and holding cancel/off key for 5 seconds. If that doesn't work unplug or disconnect the power for 1 minute. Plug it back in, if the error comes back it probably is a bad control board. Most common cause of control failures is caused by corrosion on the connectors. I would seat and reseat all the connectors to the board, including the keypad ribbon. Give this a shot and post back, Catriver.
Apr 20, 2007 | Whirlpool SF380LEPS Gas Kitchen Range
Kenmore Oasis HE 27082 Top Load Washer Logo
27 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
