check your speaker or output of computer speaker input pin which plugin your computer just out and touch with hand hearing noise from your speaker if yes then see in computer sound mixure
hi I read your problem. your problem is that you don't hear any sound from your speaker when you connect to your pc and you also say your setting are correct. but again you check your setting in my way
Go to control panel
than go in your sound option
than check your speaker wire pin is connected properly if not than connect it properly
is your computer show your speaker are connected properly
than there is a option to test or check your speaker means it when you click your left speaker create sound than right
if you hear sound means it is correct or your hear only one side than check your volume option
if you don't hear any sound it means your speaker is dead.And also connect nearby computer shop.
To confirm that ur speaker is dead try to speak in the loud speaker mode. If u happen to hear them in loud speaker mode but not in the normal speaker mode then its confirmed that u need to replace ur speaker unit.
Hello Shemon
Well, there is 2 option here, 1) your sound speakers are not connected corretly or in the right slots on the sound card.
2) your sound card, (internal or external) you have to use the mixer on software to put the right channels for the music you heard. try configuring in control panel, in multimedia devices, the speakers. for 5.1 system, or 2 way speakers or 3
try again
