I need to service my WA7584C SAMSUNG washing machine. How do I dismantle it and what do I need to clean?
    Problem Solver:
  • 10 Answers
Fix it
Posted on Nov 06, 2010
String stuck in washing machine
you need to unwind the string and any other blockage can be hard
sometime their is a need to dismantle and clean out all the bushes and bearings from threads hairs and also strings,
Mar 04, 2015 | Indesit & Philco Washing Machine Drive...
Looking for service manual for Bosch was28469gb
Drum is split tub, not even a qualified engineer likes doing this as it takes a couple of hours. If drum needs a clean out, run a couple of 90 degree cycles with a capful of baby sterilising fluid directly in the tub. Or you can purchase a drum cleaner from Bosch direct via their website (Accessories shop)
Apr 02, 2013 | Bosch Washing Machines
Front loader washing machine - samsung. My machine's door rubber is torn it needs to be replaced. Please assist me. 0795787578 Monica. Thank you
hi monica to fix it you will have to replace it take your model and serial number to your nearest appliance spare parts dealer to buy part i must warn you it is a mongrel job if you have never done one before better you left it to the experts if not give it a go but watch how you dismantle it so you can put it back together good luck
Apr 07, 2011 | Samsung Washing Machines
Get stains on clothes after been washed.. noticed on new white shirts
what kind of stains like rust color.if yes you need to call a service technician to clean the unit,not an ordinary cleaning we need to dismantle the unit to replace the oil seal and bearing if worn out,but some is just for cleaning,some unit also stains came from the liquid softener,try the cycle wash and put the heater is high level to melt some liquid softener,try for 3 time without cloth inside if this is ok after that cycle no need to call technician,do it every month as a maintainance
Dec 28, 2010 | Maytag Neptune MAH9700 Front Load Washer
When the washing machine is draining, the water backs up out of the hose unto the wall and the floor. I've tried Liquid Plumber twice down the washing machine drain to no avail.
You need to get a flexible drain cleaner and in sert in the outlet pipe that goes to the drain,or dismantle the waste pipe if possible, and clean it out that way.
Dec 04, 2010 | Washing Machines
Creda W100FW Front Load Washer. access to service drain plug?
Hi.
Remove lower rear cover of washer, locate pump, and remove large hose attached to it, remove and clean filter inside hose, check pump for possible blockage.
Please rate my solution.
Thanks.
Apr 19, 2009 | Creda W100FW Front Load Washer
SIEMENS XLM 1600 (WXLM166AGB) MACHINE WILL NOT TAKE IN SOFTENER FROM DETERGENT TRAY
If water is being dispensed from both sides of the detergent tray, dismantle washing machine and remove top plate of the detergent tray and clean thoroughly. Water overflows from both sides during the rinse cycle to add softener to the rinse. On our washing machine it was blocked. During the service it was changed but can be washed out to solve problem.
Aug 28, 2008 | Washing Machines
Error with 'Debris Filter' on Samsung WD-J1255 machine
remove pump and dismantled it,I don't think the rubber you found is off the machine,look for something caught in pump
Mar 21, 2008 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
