SOLVE PARTIAL DIFFERENTIAL EQUATION- xP+yQ=3Z
2 Suggested Answers
  • 47 Answers
SOURCE: 2x -y +z -w =
You have to put the equations into matrix form first. To do this, each variable has one column in the first matrix and you fill in the co-efficients for the variables. The second matrix has one column and contains all the numbers.
{ 2 -1 1 -1} = Matrix A
{ 1 3 -2 0}
{ 3 -2 0 4}
{-1 -3 -3 -1}
{-1} = Matrix B
{-5}
{ 1}
{-6}
{x=-2} = A*(B^-1)
{y=-.2}
{z=3}
{w=1/6}
I used excel for all my calculation and a helpful tutorial can be found here. I hope this helps and have a nice day!
Posted on May 05, 2011
How to calculate differential equation on Casio fx-991es
You can calculate first derivatives of some functions at given points; you can calculate definite integrals over a given interval, but you cannot solve differential equations.
Aug 10, 2014 | Office Equipment & Supplies
Solve the following equation for a. a^2 + b^2 c^2
There is nothing to solve here.You just have an expression with two letters; you have no equation to solve because you need an = sign.
Sep 07, 2013 | Office Equipment & Supplies
How to solve quadratic equation in fx-100ms
See if it has an equation mode, and select quadratic equations. If it has a SOLVE feature, enter equation, provide a guess and solve.
Feb 26, 2013 | Casio Office Equipment & Supplies
Hey I am trying to use the DeSolve funtion on Texas TI-nspire cas. I insert: DeSolve(2x=0, x) and I get a error message. What am i doing wrong
deSolve( ) solves differential equations. The general syntax is deSolve(1stOR2ndOrderODE, Var, depVar). The first argument must be a first order or second order differential equation, the second argument is the independent variable, and the third is the dependent variable (the name of the function you are trying to obtain.)
Your command does not have a differential equation, and it does not have the dependent variable.
Sep 18, 2011 | Texas Instruments TI-89 Calculator
Examples of homogeneous differential equation
Hi janeth sabay,
Have a good day!!
Here is your needed example for Homogenous differential equation:
The equation 49e8abf8a1c5be91fadbf33a5405bdc3.gif is said to be homogeneous if P and Q are homogeneous functions of x and y of the same degree.
We can test to see whether this first order equation is homogeneous by substituting 21fe29cd49ecbd3abe2ae6373e89eab6.gif . If the result is in the form f(v)i.e. all the x's are canceled then the test is satisfied and the equation is Homogeneous.
Example 1:19c981882c1f9b05fadf586b56a931bc.gif(2)
There are no terms in x on the right hand side and the equation is Homogereous.Example 2:72f80f87eb510a9e0fd81c423b3faa55.gif(4)
So the original equation is not homogeneous.Methods Of Solution.
A solution can be found by putting y = vx on both sides of the equation:-
Example 3:
Putting y - vx
Since y is a function of x so is v
Separating the variables
Integrating
Substituting (12) in equation (10)
405d0e82aab0e4cb688a90b92a0dab77.gifI can suugest you also to visit this site for more examples http://www.codecogs.com/reference/maths/differential_equations/homogeneous_differential_equations.php
Sep 12, 2011 | Toys
2x -y +z -w = -1 x +3y -2z = -5 3x -2y +4w = 1 -x +y -3z -w = -6 solve for the variables w,x,y,z using matrix equation
{ 1 3 -2 0}
{ 3 -2 0 4}
{-1 -3 -3 -1}
{-1} = Matrix B
{-5}
{ 1}
{-6}
{x=-2} = A*(B^-1)
{y=-.2}
{z=3}
{w=1/6}
May 05, 2011 | Computers & Internet
How to input cos x=0.75?
I assume that if you want to input the equation it is with the intent to solve it. If that be the case then what follows will help you input and solve any equation (linear, quadratic, trig, etc.)
Make sure the calculator angle unit is the same as your problem requires (degree, radian, grad). Here are some screen capture to help you. Change the equation to yours. 21c8779.jpg4b6c1ea.jpg
To enter the equation in screen above, use the right arrow.
You have to enter an initial guess on line X=, a default value may be supplied by calculator: It depends on last value stored in X. Once a value is entered press the F6 key to SOLV
Press F1: Rept if you want to solve another equation.
Nov 13, 2010 | Casio FX-9860G Graphic Calculator
Sum to n terms of the series 1+5+12+22..........
You did not provide a general (n) term. However, I figured it to be something involving n^2. Hence the sum to n terms can be of the form: xn^3 + yn^2 + zn. Using the partial sums: 1, 6 (1+5), and 18 (1+5+12) we can build a linear equations system:
1= x + y +z (n=1)
6 = 8x + 4y +2z (n=2, n^2=4, n^3 = 8)
18 = 27x + 9y + 3z (n=3, n^=9, n^=27)
Solving for x,y,z we get x = 1/2, y= 1/2, z =0
Hence 1+5+12+22+..+ f(n^2)= 1/2(n^3+n^2)
Nov 04, 2010 | Refrigerators
7x-2y=1 y=3x
And your question is? If you just want to know how to solve this system, you only need to substitute one equation into the other and solve for the remaining unknown.
y=3x (equation 2), so plug it into equation 1
7x-2y=1
7x-2(3x)=1
7x-6x=1
x=1
from equation 2 then, you know y=3x=3
Oct 05, 2010 | Linear (HDMICAT5EXT) Repeater
How to use ti 89 with a problem like "-(3x+1)-(4x-7)=4-(3x+2)'
Just plug in one side of the equation and find the answer. Then plug in the other side and compare answers.
Feb 19, 2008 | Texas Instruments TI-89 Calculator
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
