Question about Storagetek L80 DLT Tape Drive
My Storegtek L80 can't recognize all of its tape drives
It contains 4 drives connected by Fibre Channel interface (which contains 2 SCSI ports to connect library and drives)
Every thing was nice until a problem happened in one drive and the medium changer (robot) so the responsible tech. replaced them than the problems began
I tried to connect the library and drives with the fiber router scsi ports by different ways of external scsi cables and every time some drives appears and some of them disappear also some times one drive take the World Wide Name of the medium changer (and add another alias with the same WWN of mc) so mc doesn't appear
Now and after many trials I can use only 2 drives with the mc
All of my external scsi cables were tested ok
If I tried to use the external scsi cable topology for connecting drives and library (which found in the L80 manual and it is my previous topology before problems) only 2 drives recognized and the mc not recognized (and one of the 2 recognized drives had the name WWN of mc)
Is it cabling topology issue? Or Fibre Channel interface issue or what?
And what is the concept of connecting more than drive and mc with Fibre Channel interface scsi ports by using external scsi cables?
We also are having very similar issues. They are not identical, but they are close. The StorageTek is connected thru JNI HBA fiber cards to (and we have tried two different systems) Windows 2000 Server(s) with Legato Networker 7.3.2.
The system has been solid for 5 years running. And an issue with one backup pool developed into the entire system not recognizing the changer robot and the inability to see all four drives consistently. The Sun technician had everything so screwed up after leaving that we brought up our DR test server and configured it with legato and the HBA's. We get so far, but we never see the library changer at all in Windows. We only see differing numbers of drives. Legato Networker will see the Jukebox changer/ but Windows doesn't. We had to manually insert the tapes and kick off jobs to just to get a backup. This is really getting serious now as it has been almost two weeks since we have been able to schedule and run all of our backup routines. Did you ever get your's corrected?
  • 2,794 Answers
That thing required a SCSI terminator pack doesn't it.
If so, is it working properly.
I've had those things go out on me before leaving me to pull my hair out many times.
Posted on Jun 14, 2008
No tape is seen in my adr onstream drive cartridge. does the cartridge already contains a tape or you would have to buy that one too
The cartridge does always contain the tape. If the drive fails to detect a loaded tape after the cartridge is put in then there is a problem with the drive.
Jan 05, 2011 | OnStream DP30 ADR Tape Drive
Back up tape is not recognizing
1. Stop all the services of your Backup Appl.
2. Review you SCSI controller drivers for the last version
3. Run LTT firmware update.
4. Run an Assessment test with LTT***
***You can download LTT from www.hp.com/support/tapetools
May 29, 2010 | HP StorageWorks Ultrium 448 LTO 2 Tape...
Seagate drive doesn't recognize tape media.
please try to use cleaning cartridge. if tape drive is still in failure. perhaps the heads is bad.
Feb 23, 2009 | Seagate Travan TapeStor Travan Tape Drive
Lib-152E autoloader no longer recognized after firmware update.
Try taking the dives out, connecting each one to your SCSI card and updating the firmware - wait at least 10 minutes afet Tape Tools says you can now use it again! This last bit is very important! Then, after you have done the update to each drive, replace the drives and try again.
I had the same problem with a TSL-SA500C and it woked fr me.
Tim
Feb 20, 2009 | Sony AIT Library LIB 152E/A1 (LIB-152E/A1)...
Installed identical replacement STT320000A but won't recognize tape
The STT320000A is IBM version? some IBM version STT320000A will rewind the tape when inserted. But It can recognize the media after rewind. If can't, try to used the cleaning cartridge or change one new media. regards
Jul 20, 2008 | Seagate 20GB TRAVAN SCSI 5 1/4 TPE DRIVE...
Scsi tape drive not recognized on the library
Please check your firmware on the tape drive. Update with X-Talk software that can be downloaded from www.quantum.com.
Apr 28, 2008 | Computers & Internet
Tape drive replacement trouble
drivers are a simple solution..here's a link for printer drivers, which you can jump through to find tape drivers, with the dell model number.
Mar 10, 2008 | Quantum DLT VS80 DLT Tape Drive
Tape drive does not recognize or eject tape
Yeah the Ultrium 4 tape drives only r/w to ULT3 and ULT4 tapes.
We put a Ultrium 2 tape in our 4 drive and it seems to be locked permanently.
Oct 26, 2007 | HP C7438A (Refurbished) DAT Tape Drive
Service required led blinking
You will need to get a StorageTek engineer out onsite to have a look at the problem, the light will not dissapear until resetted by a engineer.
Jul 10, 2007 | Storagetek L80 DLT Tape Drive
Storagetek L80 DLT Tape Drive Logo
254 people viewed this question
Top Storagetek Computers & Internet Experts
David Payne
David Payne
Are you a Storagetek Computer and Internet Expert? Answer questions, earn points and help others
