Question about GE Refrigerators
The inside fibre body for fresh food compartment (i.e. bottom compartment) has partially broken in our old GE make 330 liters capacity 3 doors refrigerator (Model no: TMQ 12 AN TRLG) . We need to replace it. Otherwise, the refrigerator is in good working condition. Kindly help us how to solve this problem and inform us about estimated expenditure towards repalcement of the broken fibre body. Regards. R B Shah Manager (ES) National Dairy Development Board Anand 388 001 (Gujarat), India (M) +919898666274
SOURCE: food in refrigerator freezing solid toward back of compartment
Been there, done that. You need to have a new computer board installed in the fridge near the top. Ours got hit by static lightning ang blew two of them in two years. When they go out, the defrost cycle fails and Ice builds up in the freezer in the back middle. Take the back vover off in the freezer and you'll see it packed with ice since the defroster is not getting the signal to defrost. order a new computer board, install it in the top of the fridge side, in the back, above all those controls on the back right side in a white case to hold the board. defrost the ice by using a hair dryer and letting all the water drain out and get it dry. Those PC boards do not like static at all
Posted on Jul 14, 2007
  • 52 Answers
SOURCE: GE top freezer refrigerator
The air flow vents must be blocked. The refrigerator cools from the freezer through those vents, it does not cool independently. They may be clogged in the case with ice. Turn the fridge off and leave doors open for a few hours to let it thaw and it will probably start working.
Posted on Mar 20, 2008
  • 310 Answers
SOURCE: GE fridge: Freezer working but fresh food side not cold
The problem is the refrigeration evaporator, located in the freezer section is blocked with frost and ice and not air can pass through it. Four different failed parts can cause this problem. The defrost timer, the defrost heater safety thermostat, the defrost heater, or the evaporator fan motor. Unless you are very good with a volt-ohm meter, it wiil be difficult to distinguish which one of these parts has failed. A qualifed refrigeration service tech or a good appliance service tech with a refrigeration certification can find this quickly.
Posted on Jan 13, 2009
tborn6
  • 700 Answers
SOURCE: GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Posted on Apr 03, 2009
  • 128 Answers
SOURCE: Regarding GE french door model pfs221sbss, need
I would call your GE service company and give them the model number and serial number of your frig. They can look up which board fits your frig.
I hope this helps.
Posted on Feb 03, 2010
Testimonial: "Will do. Thanks- BW"
GE Profile refrigerator TPX24SRY/TPX24PRY,inside freezer there is frost around walls and icing on ice cube box,the compressor cycles seems to long
Maybe a defrost component that has failed if doors are closing tightly and freezer compartment fan is running.
Sep 28, 2018 | GE Refrigerators
Door handle coming off
now you just need to buy another handle because the first one is not fixed well, it doen't cost a lot, but when you buy the handle you get free maintenance.
Mar 04, 2008 | GE GSS25JEMWW Side by Side
GE side by side. Top shelf in fridge warm. bottom drawers frozen. Freezer working fine. Seems to be blowing a lot of cold air out the vents by the floor. Top shelf in fridge is 55 degrees. Diffuser...
Hi, I'm Mark.
Check the position of the two controls at the top of the unit inside the fresh food compartment. SET BOTH controls to the 12 o'clock position. Wait about a hour, then check temperatures. Then wait another hour and check temperatures again. Record the values on a piece of paper. When you do check fridge temperatures, do so quickly as the compartments become warm just a few seconds after the doors are opened. Please let me know what happens to the fresh food readings.
Thanks, Best Regards,
Mark
Dec 29, 2010 | GE GSS25SGMBS Side by Side Refrigerator
I Have a side by side fridge freezer approx 3/1/2 years old the freezer is fine but the top half of the fridge isnt cold yet the bottom crisper etc is
Check to ensure that the freezer fan motor is operable (you may need to open the freezer door and activate a button inside the freezer door frame in order to make the fan operate). If the fan works, then you may have an issue with the damper assembly (located in the fresh food compartment at the top left side). It will either be a "manual" or "electronic" concept. Adjust the temperature settings for both the freezer and fresh food compartments at the "half-way mark". You should also have a vent or two at the bottom left side of the fresh food compartment (check to see how far they are openend or closed and adjust accordingly). If the aforementioned doesn't help, contact an appliance service company.
Feb 17, 2010 | Samsung RS2556 Side by Side Refrigerator
Coils keep freezing up its 4 years old
Iced-over evaporator coils, accompanied by a non-chilled fresh food compartment, happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side got warmer as well.
The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall between compartments which opens when the fresh food side needs cooling. If no air is moving in the freezer compartment, temps in the fresh food compartment climb.
I replaced the temp sensor in the fresh food side and solved the problem for a while.
I bough a pair of thermometers at a kitchen store and put one in the freezer compartment and one in the fresh food compartment so that I could occasionally check to see if it made sense for the compressor to be running (ie, was it really necessary to be trying to cool either compartment, or were they already cold enough).
About six months later I had the coil icing problem again. This time the fresh food side seemed cool enough (according to the thermometer as well as the fact that the flapper door would close, indicating that the computer knew to not try to additionally cool the fresh food side).
The thermometer indicated that the temp in the freezer compartment was cold enough, but the system computer continued to run the compressor. So I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Use a website like www.partselect.com to look up a parts diagram for your fridge and see if you can order just the temp sensors. Other websites (www.repairclinic.com and www.appliancepartsworldwide.com) may also be helpful. I have no affiliation with any of the sites I just mentioned - I'm just posting them as resources.
Jul 30, 2009 | GE GSS20IEP Side by Side Refrigerator
We have a ge side by side and the refrigerator is freesing stuff. the model number is GSS25X SNA BS
Is it all areas of the fresh food side that are freezing your items, or is it the drawer area?
There is a direct connection (on my GE side-by-side, at least) between the freezer compartment and the drawers in the fresh food compartment. The size of the connection is controlled with a wheel or a slider. This could contribute to freezing in that area of the fresh food compartment.
Otherwise, it could be the temp sensor(s) in the fresh food compartment. If the computer thinks the temp is too high in the fresh food compartment, it will continue to cool.
It could be a problem with the motorized door that connects the freezer compartment to the fresh food compartment, located at the top of the dividing wall between the compartment. That door should close when the temp in the fresh food compartment is cold enough. If that door mechanism has failed, is disconnected, or otherwise blocked in the open position, cold air from the freezer compartment will continue to circulate into the fresh food compartment.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrig not cooling
Either the fan that blows cold air from the freezer compartment to the fresh food compartment is burned out or the door/flap that seperates the compartments is stuck or the linkage connecting it to the fresh food temperature dial is stuck or broken.
The evaporator coils are in the freezer compartment and air is blown from the freezer compartment to cool the fresh food compartment. For some reason, air is not moving to fresh food compartment.
If the fan is running, it could be something as simple as Ice blocking to door between the freezer and fresh food compartment. I know modern refrigerators are self-defrosting, but that's only the evaporator coils, which are defrosted by a timer and a heater.
Ice can form on passageways inside the refrigerator, like the exit of the ice maker and in this case, on the door and 'tunnel' between the freezer and fresh food compartment. It's free, and doesn't take a lot of time, so try completely defrosting the unit before doing anything else.
BE SURE to keep the doors open, as odors can form as particles of food are allowed to defrost that may have been frozen in an ice pack for months or even years. Clean the interior of the refrigerator while you have everything out and reset the controls to normal settings.
If this doesn't help, there may be a mechanical problem with the air transfer control flap/door that will need to be fixed.
Hope this helps.
Jun 10, 2009 | Refrigerators
Reset Filter Indicator Light is on
Look for your model number from the sticker inside the fresh foods section of the refrigerator, usually on the liner near the door opening. Now, go to http://www.geappliances.com/service_and_support/literature/ to download a use and care manual for your model, as the reset procedure may vary by model. The filter is usually located at the very back right upper side of the fresh foods compartment, but again, it may vary by model.
Apr 11, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fresh food compartment not cold, light is lit when door closed
Engwah, is this the correct model number or does it start with PSS. The light should do just the opposite, off when the door is closed and on when the door is open. This could be part of the non cool problem. If this model has the mother board wich controls the refrigerator it is very possible that the defective fan motor has damaged the motherboard. This is very common in GE refrigerators. The technician will have to run some tests on the board to eliminate it...Catriver..post back.
Oct 28, 2006 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Brian Coughlan
