Question about Acer Aspire 5610-4648 Notebook
I have an Acer Aspire 4937 and it will not run on AC power. If I remove the battery it will not boot at all. The light on the button comes on briefly and then goes off again. When I run the laptop with battery and AC power the battery discharges and will not charge while the laptop is on. If I shut down and leave the AC power connected the battery then charges. What could be wrong here?
SOURCE: Battery not charging when Laptop powered on Acer Aspire 4520
replace the battery of lappy
Posted on Feb 09, 2009
micromend
  • 748 Answers
SOURCE: Acer Aspire 1640 power problem
Will the unit work without the battery? The new Lithium Ion batteries can be overcharged and then cause all kinds of strange problems. Take the battery to a reputable electronics shop or Batteries Plus and have them run a voltage and current test. The current test being the most revealing. If either of these is higher than the level printed on the battery, dispose of it. Also, check ACER's web site for battery problems. All the computer manufacturers have had battery problems.
Good Luck
Posted on Mar 19, 2009
vortash
  • 431 Answers
SOURCE: Wont boot up. A/C connected, battery fully charged. Just flashes green light for 1 second when you press power on button.
Hi I am Vortash sorry to say that power supply fault seems to be the most likely answer to this .. and to be honnest with laptops that was 50% of the problems I fixed .. they are also quite exspensive retail so I tend to search on Amazon or Ebay for them .
I have had this problem with a faulty hard drive also it was shorted out so the computer just shut down .. whatevetr it turns out to be this is one for a skilled engineer as replacing components on a 12 layer multiple circuit requires special soldering equipment and conditions and a fair amount of dexterity and skill good eyesight and the patience of a God lol . you could try another hard drive yourself that isn't to difficult if you can borrow or buy a cheap one .. and you can always get a caddy for it after and us it as a secondry drive on the usb if your own isn't faulty .. I hope this helps Vortash
Posted on May 17, 2009
  • 39 Answers
SOURCE: Repair D2D Recovery Acer 4937 MBR failed !!
choose to boot on the vista partition and imidiatly press F8 several times to get the vista boot menu.
choose "repair computer"
choose language,
choose user (and type in password if there is any)
see if there is a option called something like
ACER recovery /factory image / something similar (usually the bottom option)
if there is, click it and start recovery.
if there isnt i would contact acer and have them send me a new recoverysett. (4-6 weeks deliverytime)
Posted on May 29, 2009
tbirdfan1
  • 3051 Answers
SOURCE: My Acer Aspire 5720 laptop won't charge while it's running
Hello there:
try removing the battery from the computer and turning on the computer to see if the power cord works correctly if it does inspect the battery and clean the terminals on the battery and computer and put the battery back in while it is still on now you should see the battery show up on the taskbar if not right click anywhere on the desktop and go to properties and than go to than go to screensaver than look towards the bottom and you will see power click on it and you should see the options for the battery ok sorry this was so long but i needed to explain it in full
please dont forget to rate this
best regards mike
(usn retired)
Posted on Aug 04, 2009
Earlier today I was using my Acer Aspire with no problems. Now when I try to boot it up, the green power light comes on, the fan starts whirring but thats it. The screen stays black and it can sit there...
Thank you for choosing FixYa!
This can still be fixed by doing power drain.
>Take the battery out of the computer
>Unplug the ac adapter from the computer.
>Press and hold the power button for about 15secs.
>Let go of the power button.
>Put the battery and plug the ac adapter back into the computer.
>Turn the computer back on.
You should get the display to come up. For a more detailed instruction, please visit http://www.fixya.com/support/r6013536-computer_turns_but_no_display
Thank you for choosing FixYa! have a nice day!
Apr 03, 2011 | Acer Aspire One PC Notebook
My acer on one netbook wont boot up, the power light comes on but nothing else,
Try removing any external device first (ex. USB device) then draining the flea power:
1. Remove the battery and ac adapter
2. Press and hold the power button for at least 10sec.
3. Put back the battery and ac adapter
4. Turn on the computer
Hope this helps
Dec 12, 2009 | Acer Aspire One Netbook 8.9" Notebook
Wont turn on.. battery light just keeps falshing
Thanks for using FixYa.
You have a dead battery if your battery light just keeps on flashing and your laptop only works when plugged in to the A/C. Try to take out the battery and plug your laptop in to A/C. See if it works. You might be one of the unlucky ones who got a lemon battery. Several users have enountered the same exact problem. This is an Aspire one issue. Try to contact acer and see if they will send you a new battery right away. I hope this helps.
Thanks and have a nice day.
- HotRatchet
Nov 09, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire one power button comes on but screen doesn't come on.
1/ Take a close look at the display in bright light; can you see anything there? (If so then the CCFL (or its power supply) needs replacing on the display
2/ hook up an external monitor and see if that works (or at least if the light stays green on the monitor)
3/ Any boot beep? any "Windows sound"?
4/ try removing the battery and (using only external power) see if it starts.
4/ remove the battery AND the external supply, hold the power switch in at least 30 seconds. Hoojk it up again, try it.
JOAT
Oct 16, 2009 | Acer Aspire One PC Notebook
Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Aug 23, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5520 would not proceed to boot up
Tried replacing the memory. It worked for me. I tried removing battery, harddrive etc. Same thing: briefly power light on and fan on and then both off.
Jun 04, 2009 | Acer Aspire 5520-5908 Notebook
Pc will not come on. Runs Hot. Will not click off.
have you tried to remove the battery and disconnect the ac-power?
then reinsert the ac-power (without battery)
and try to boot.
if that doesnt work:
remove battery and ac.
turn computer upside down. under one of the lids there will be 1 or 2 memory modules (ram). take them out
insert ac
try to start the computer (yes, without the ram modules)
leave the computer on (with black screen) a couple of seconds.
remove the ac
insert the ram again.
insert ac
try to boot again.
May 29, 2009 | Acer Aspire One PC Notebook
Acer Aspire Computer Does not Turn on
The light you are seeing usually is a sign that the battery is discharged. Although you say the battery shows that it is fully charged, it is possible that the battery is fully discharged or defective. You should disconnect the battery from the pc and try powering on with the ac adapter. Although no way to per say "force reboot," removing all power sources (ac adapter and battery) should in essence reset the motherboard.
Mar 14, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 5050 Power ON problems
that maybe the only problem. lets hope so.
Jul 29, 2008 | Acer Aspire 5050-3242 Notebook
Acer Aspire 5610-4648 Notebook Logo
293 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
