Question about Gateway M305CRV Notebook
I have a Gateway Laptop, I cant find a model number, but the computer had a virus in which a so call tech removed, now the computer boots the the first screen , at that time you can press f2 and go into the bios setup or press f10 and to to the boot screen. both of the screen seem to function correctly. when you try to boot the hhd all you get is a black screen, if you press f10 and select to boot from the cd/dvd then I get the same result nothing but a black screen. I have tried 1. removed and reseated the ram 2. removed and reseated the hhd 3. removed and reseated the processor. I have tried replaced the hhd and swapped out the ram, no change. tried doing a hard reset the bios detects everything properly, the hhd spins and the cd/dvd spins no display on the screen after the bios splash all function in the bios seem to work fine, I have found a couple of post on the web of the same problem but no answers. I work on 10 to 15 laptops a week but i am stuck on this one
    Guru:
  • Gateway Master
  • 468 Answers
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Thank and regards,
Anil.B.R
Posted on Nov 06, 2010
How do you refresh an older model gateway laptop
To restore Gateways you hold down the ALT and the F10 keys, then it should show a boot sequence screen, choose HDD boot and press down ALT and F10 again then you will get the restore feature for gateway. If that doesn't work boot into windows and run the eRecovery program.
Feb 13, 2013 | Gateway Computers & Internet
I accidentally locked my laptop and cant get on.
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Dec 12, 2012 | Gateway Computers & Internet
Gateway m-6843 won't boot
before we jump into conclusion that the motherbaord has a problem. try using first the recovery cd provided by the manufacturer. boot your computer from the cd rom and install a clean copy of windows. if same thing happen then you need to send your laptop to the manufacturer for repair if unit is still under warranty. thanks
Mar 28, 2010 | Gateway M-6843 Notebook
My gateway laptop 4540gz cant find opp system
Operating system is the main program of the computer. It can b easily detected by your computer in boot up. So if the computer doesn't detect it, this are the steps you can try :
  1. First try to run system restore if you have one.
  2. If you don't have system restore disk, or back up disk, you can remove your hardisk from your laptop and try to connect it to other computer as an external hard drive. in that, you can copy important files and back up it in other computer if it is not also deleted.
  3. Then if you have back up your file or not, you must format your hard disk. return your hard disk to your laptop and format it.
If you don't know how to format just ask again here.
Feb 28, 2010 | Gateway 4540GZ Notebook
No i need the manual to restart my laptop which is gateway
Access the manufacturer's web-site: http://www.gateway.com
and select downloads/manuals for your specific Gateway computer.
Nov 05, 2009 | Gateway Computers & Internet
Laptop screen is black
this sounds like your video card and it controls visual functions..have you tried booting direct to the hard drive and bypass the CD? if this does not work looks like its tech time or if you are tech savy and know if your video graphics or GPU is integrated or is separate from the mother board you might be able to get and repair the part yourself...usually they give some indication of getting ready to die when functioning normal screen will fade to white and force you to reboot..this happens on separate GPU systems ...integrated can just wipe out and not reboot..reset your memory sticks as a last ditch effort...If you are uncertain you can look the specs up by googling your model # on any smart phone Good luck GOD BLESS
Oct 12, 2017 | Gateway MX6438 Notebook
Dont have recovery disks and have virus...actually just missing disk 2
If the popup you're getting is from something like "MS Antispyware 2009" or similar, that's the same trouble I've seen on several other computers. Download a removal tool called ComboFix. You can find information on how to use it and links to download it here. This is a handy tool even if the virus you have is different as it will fix a number of virus and trojan problems. ComboFix can be run in safe mode if your computer can't start all the way into Windows. Turn your computer on, and when you see the Gateway logo screen press the F8 key. This will give you a startup menu screen from which you can pick starting in safe mode. This prevents Windows from loading everything except the minimum stuff it needs to start. Run ComboFix and let it repair the troubles it finds.
May 25, 2009 | Gateway 835GM (835GH) PC Desktop
I have a virus trying to scan my computer at startup.
Have you tried to boot up in safe mode? you maybe able to do something from there. Like go to msconfig and the start up and take the check mark out of the program that is wacking you. Then run an antivirus program to detect and remove the nasty.
Toshiba's support phone number is:
Toll-free Technical Support in the United States
  • Computers: (800) 457-7777
Hope this helps,
May 06, 2009 | Toshiba Satellite A135-S4427 Notebook
I have a virus
sorry to hear about that. Have you still got the restore disks from when you purchased the computer? If not contact the supplier and ask them to send you some, it will put your computer back to its original state from when you purchased it.
Oct 26, 2008 | Gateway Computers & Internet
Gateway M305CRV Notebook Logo
111 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
