Question about Microsoft Xbox 360 Console
Server connections time out
I start to play call of duty 4,then after of 1 or 2 minutes in the screens appears server connections time out and i cant play. I call my local connection (DSL) and we makes some test and the problem still.
Could sombody help me?
  • 106 Answers
Is there a router with other machines on the network? Do you have a router? Is it wireless and if so, secured? Does the dsl modem have enough air circulation (could be over heating) and last but not least, make sure there isn't much activity on your network (other pc's downloading etc..)
Posted on Jun 15, 2008
Call of Duty Black Ops II will not play online
Crowded servers lead to this issue, try connecting at a different time.
Nov 30, 2012 | Activision Call of Duty 4 Modern Warfare...
Just bought cod 4. Dont know how to connect to server to play on line.
Firstly, ensure the console is connected to the Network via an Ethernet cable or WiFi. You will then have to access the Playstation Network via the main menu and create a new profile, i.e. User Name, email address.
Once all complete, you can then tick the small box to `Automatically Log On Each Time You Connect To The Network`. This will save you having to type in your User Name etc each time you play online.
Good Luck!
Jun 10, 2010 | Activision Call of Duty 4 Modern Warfare...
Cant connect to some people online on call of duty and takes long time to find games
you have a slow internet connection, or you're using all of your bandwidth. try turning everything off and stopping all processes being access by your internet (including your computer- restart it) and this should reset your internet/bandwidth.
Oct 04, 2009 | Sony Playstation 3 (PS3) Console
Nat help
Hi jman92592,
Here are some options with that router. Some online games and videoconferencing applications are incompatible with NAT. The WGR614 router is programmed to recognize some of these applications and to work properly with them, but there are other applications that may not function well. In some cases, one local PC can run the application properly if that PC’s IP address is entered as the default in the PORTS Menu. If one local PC acts as a game or videoconferencing host, enter its IP address as the default
To set up an additional computer to play games like Half Life, KALI or Quake III:
1.Click the button of an unused port in the table.
2.Select the game again from the Service Name list.
3.Change the beginning port number in the Start Port box. For these games, use the supplied number in the default listing and add +1 for each additional computer. For example, if you've already configured one computer to play Hexen II (using port 26900), the second computer's port number would be 26901, and the third computer would be 26902.
4.Type the same port number in the End Port box that you typed in the Start Port box.
5.Type the IP address of the additional computer in the Server IP Address box.
6.Click Apply
The WAN Setup options let you configure a DMZ server, change the MTU size and enable the router to respond to a Ping on the WAN port.
Connect Automatically, as Required
  • Normally, this option should be Enabled, so that an Internet connection will be made automatically, whenever Internet-bound traffic is detected. In locations where Internet access is billed by the minute, if this causes high connection costs, you can disable this setting.
  • If disabled, you must connect manually, using the sub-screen accessed from the Router Status menu "Show WAN Status" screen.
•Disable SPI Firewall
  • Normally, this option should be Enabled, so that your local network will be protected by the Stateful Packet Inspection (SPI) firewall included in the WGR614. However, certain communications functions like VPN may require turning off the SPI feature.
Setting Up a Default DMZ Server
  • The default DMZ server feature is helpful when using some online games and videoconferencing applications that are incompatible with NAT. The router is programmed to recognize some of these applications and to work properly with them, but there are other applications that may not function well. In some cases, one local PC can run the application properly if that PC’s IP address is entered as the default DMZ server.
Note: DMZ servers pose a security risk. A computer designated as the default DMZ server loses much of the protection of the firewall, and is exposed to exploits from the Internet. If compromised, the DMZ server can be used to attack your network.
The WAN Setup menu, shown below lets you configure a Default DMZ Server.
  • To assign a computer or server to be a Default DMZ server, follow these steps:
1.Click WAN Setup link on the Advanced section of the main menu.
2.Type the IP address for that server. To remove the default DMZ server, replace the IP address numbers with all zeros.
3.Click Apply.
Good Luck and don't forget to leave a rating.
Thanks Mark
Apr 23, 2009 | NetGear WGR614 Wireless Router
Call of Duty 2 for windows not working. Help Please!!
This is simple.
If you try and connect to a server it cant just let you on.
It needs to donwload the maps, servers, players ect.
When it sais downloading then leave it and it will connect on its own.
When you get kicked from a server it is not because of a download, its different.
Don't panic when it kicks you, it happens to everyone.
If you are getting kicked from servers more than usuall, then i would reccomend to talk to a real gamer who is addicted to these games.
You may find them on sites such as google or yahoo answers, even youtube!
Hope this helps.
Apr 10, 2009 | Activision Call of Duty 2 for Windows
Wont connect to host on call of duty 4
cant connect to easports server always disconnect when loading
Apr 04, 2009 | Sony Playstation 3 (PS3) Console
Call Of Duty 4 freezing in Multiplayer online only
It's the Call of Duty 4 Servers from uploading the Map Pack. Their are alot of players That have downloaded it recently, and it is lagging their Servers. If you just wait a little bit, the problem should be fixed and all set to go.
Jul 11, 2008 | Microsoft Xbox 360 Console
Call of duty 4 connection
When this happens, you need to go to your dashboard because you arent even connected to xbox live. Then, log out and check your xbox live connection. One of the tests will fail and this will be your problem.
May 23, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
26 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
