Question about Fisher and Paykel Fisher & Paykel Washer
My Model GW712 won't spin or drain Top loader fisher & paykel
  • 1,557 Answers
Hi there the first thing ill tell you is that the washer needs to drain water before it can spin there are only a few factors that prohibit this operation a faulty lid switch secound a blown or blocked water pump being a fisher paykel they are famous for jammed water pumps as they decided when they built the sysyem to turn the water pump upside down this causes a lot of stress on the water pump see if you can lay the hose on the ground and get all the water out i belive the machine will then start to spin dry. in this case it is the water pump and have it replaced its a simple operation if you can order the part fromf/p you simply turn the washer on its side depress the white latch next to the pump turn the pump clockwise till ity release from machine disconnect power supply plug and fit new unit as per reverse
best of luck
sonic boom electronics australia
Posted on Nov 06, 2010
Washes then does not empty and spin
It has to drain first before it can spin. Put it on final spin & press start. If you can hear a humming noise that will be the drain pump trying to go. It will have a blockage.
Apr 02, 2016 | Fisher and Paykel Washing Machines
Fisher paykel gw712 will drain but wont spin???
I some top-load machines there is a rubber tube that attaches to the outer drum toward the bottom that narrows to smaller tube that goes to a pressure switch in the control panel. I have found collected lint washed up into this smaller tube, plugging it tight so the switch fails to indicate the tube has drained, Keith L.
Mar 02, 2012 | Fisher Washing Machines
My fisher & paykel washer will not move to rinse cycle
Fisher & Paykel GW712 AU 93200-A STOPS @ THE RINSE CYCLE & THE SPIN CYCLE?
Oct 12, 2011 | Fisher and Paykel IWL12 Top Load Washer
MY FISHER AND PAYEL GW 712 WASHING MEACHAINE IS NOT SPINNING AT ALL
I have a Fisher & Paykel GW712 and had same problem and fixed it today the drain pump motor had failed although it worked for 1 full cycle. when I tried to wash a second load the water would not completly clear from the machine I finally replaced the pump and now works correctly the pump is easy to install ensure machine is disconnected from power first
Mar 27, 2011 | Fisher and Paykel (IWL12)
Water will not drain out of our washing machine Fisher & Paykel GW712 AU 93200-A
Hi just read your posting.1st you need to drain some of the water by hand using a small bucket or pot ,enough so you can lean the machine back to look under the machine.If you have the old style of pump you will see a red or black fan under the machine front right.If you have this pump turn the fan a few times to loosen it.The fan should turn freely.Then put it back on its feet and select a spin cycle and push start.It should start to drain and then spin.Please reply on how you got on or if you have the new type of pump which has no fan.Looking forward to your reply.
Sep 21, 2010 | Fisher and Paykel IWL12 Top Load Washer
Fisher & Paykel washer GW712 won't spin
There is an issue with your drainage area. Best to remove the pump and check for the obstruction in the line or at the impellar.(If the water is not completely drained, the pressure switch wont send a low level to the timer to allow a spin).
Sep 14, 2009 | Fisher Washing Machines
I have a problem with white depost on black clothig after final spin in my new eco top loader
it is either he detergent or limescale got to espares and but the lime scale and gunge remover
Jul 29, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Loud noise when draining
You need to tilt this machine back and remove the drain pump from under the machine and check for anything stuck in there eg a hair clip or coin etc. If there's nothing stuck in there you may need to repalce the drain pump. Cheers
May 11, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
1,233 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
