Question about Kenmore Oasis HE 27082 Top Load Washer
Machine wil not start up:
When i plug the machine into a diffrent outlet the machine beeps,but when I push the botton it will not start up,could this be, in the ciruit board? because it seems to be getting power but,the bottons ae not working
    Sergeant:
    Champion:
  • 359 Answers
It could be a few things is there any clothes in there when you are trying this? an unbalanced load can cause this. is the machine level? your worst case could be the cicuit board with more info on your problem i can try to assist you further.
Posted on Jun 14, 2008
    President:
  • 2,712 Answers
You mean it works in one outlet, but not the other?
If that is the case, the issue is with the outlets and not the machine. If the issue is the same in both outlets, please post back in further detail.
    Genius:
  • 1,447 Answers
Chances are its on the contact point of the wires to the main board, check for wirings if its kinked or pinched. Best i got.
    Genius:
  • 1,142 Answers
Did you check the fuse
  • Maanita Chadha
    Maanita Chadha Jun 14, 2008
    Try a different wall power outlet to confirm if the wall socket is bad. then you can check the fuse in the machine as you have to open the unit to check that plus you would need a volt meter to verify if the fuse is blow or not.
Keep getting error message of nb even though we cleaned the water line filters. What can we do to fix this problem? We have to continually press the start button to continue the cycle.
If the screens are clean and it takes several times of starting it for the machine to start washing the only option left is to replace the inlet valves.
Jan 24, 2015 | Samsung WF337AA Front Load Washer
Problem with ac window unit panel and remote will not work,pushed all bottons to work and just wont.Could it be the mother load panel?
Sounds like a control computer board problem. Some times unplugging and leaving it for about 30 seconds and plugging it back in can recover from the fault.
Jun 29, 2014 | Crosley CAE15ESR 15,000 BTU Window Air...
DE PUSH POWER BUTTON POWER COMES ON GOES RIGHT BACK OFF, IF YOU HOLD POWER BOTTON IN AND TURN KNOB TO A CYCLE THEN PUSH START BOTTON ERROR dE COMES UP
Check the outlet first. If the outlet is ok, then you have a control board issue. Replace the control board. Good luck.
Jun 19, 2011 | LG WM2487H Front Load Washer
I just replaced the battery (cr2025) and the device does not go on, I also pressed the reset botton and nothing
Check that it is plugged in. If it is already plugged in, unplug for 2 minute and then plug in again.
Make sure other end of the cord is pushed into the fax machine tightly if it is a removable cord.
Also check that there is power to the plug you are using (make sure the outlet is not connected to a switch in the room). Check by plugging a lap or radio into the outlet to make sure you have power.
Sorry for the overly simple first guess but it happens a lot.
-Mark
Please rate me.
May 04, 2011 | Office Equipment & Supplies
Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
it sounds like your circuit board has a problem
Jun 14, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Defective power button?
Is there power in your wall outlet, try something else there. Next try the fuse in your washer plug, may have blown.
Dont forget to rate.......
Nov 12, 2007 | Fisher Paykel EcoSmart GWL15
Kenmore Oasis HE 27082 Top Load Washer Logo
Sal De
fordexpert
Robert Rankin
