Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Fridge freezer keeps tripping the electric - Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
  • 77 Answers
This is the defrost element that is located behind the panel in the freezer afraid to say it has gone open circuit and will trip the electrics everytime....you can buy the part and it can be a little tricky to fit but not impossible if you have a litle diy/electrical knowledge. The element is fitted around the evaporator and comes on within the normal defrost cycle. The element has 2 connections which are just plug in and will require no real electrical work just push fitting.
Hope this helps
Posted on Nov 06, 2010
5 Suggested Answers
  • 958 Answers
SOURCE: amrican fridge freezer keeps tripping
if the unit is tripping the electric breaker, then there is a short in the unit. if you know how to use a resistance meter, you can trace your unit.
short could be coming from the power cord itself, check for broken wire and maybe touching the ground or the body of the unit.
next check your compressor. this is the biggest load of your unit. if this is shorted to ground, then it will trip your electric.
be care full on plugging the unit if you are not sure that you found the shorted wire, it might trip again.
if all of those still does not correct your problem, check the mullion heaters. but the connections of these heaters are sometimes very hard to find to check. their are hidden and only technician can sometimes find them.
tnx 4 using fixya
drcool
Posted on Sep 01, 2008
breddi2
  • 126 Answers
SOURCE: Fridge freezer shorting out electrics
The cause of this situation could simply be an overloaded circuit. Homes are built with dedicated circuit for fridge only now because of this. If you notice power outage in other rooms or other appliances in kitchen then the circuit affected,I.E. other outlets affected need the load lightened. If it is a dedicated circuit then could be faulty breaker or possibly altered wiring could be cause.These have to be ruled out before you will know for sure. If it isn,t dedicated outlet for fridge only, just plugging in a light could overload loaded circuit.
Posted on Apr 21, 2009
  • 72 Answers
SOURCE: my fridge keeps trip the electrical panel
Have a company come out to service it if it is under warranty. First make sure that it is not a weak breaker, plug it into an outlet on another circuit.
Posted on Jun 22, 2009
  • 905 Answers
SOURCE: hi, my fridge freezer keeps
Try this:
Turn your thermostat as warm as it will go, you are trying to isolate the compressor and keep it from turning on. If your fridge has an "off" position, then turn it off. Reset breaker, plug refrigerator back into the outlet. If the fridge trips while "off", then you are likely looking at a damaged cord / wiring.
If the breaker doesn't trip, unplug the fridge, and move the thermostat to the warmest position possible. Plug fridge back in, If the breaker holds, then you are on right track. Slowly move the thermostat to a cooler setting. You want to just reach the point where the compressor tries to start. If breaker holds here, then you are in good shape so far. It indicates a problem with the defrost heater (if equipped), or the ice maker (if equipped). If the breaker trips as soon as the compressor tries to start, your compressor may be damaged (bad and expensive).
Posted on Aug 17, 2010
Samsung rsh1nhmh fridge freezer not turning on and tripping electrics.
sounds like electrical fault within your freezer any small fault will throw your contact breakers on your consumer box without blowing the fuse in the appliances plug
Aug 30, 2015 | Samsung Refrigerators
Find out why my freezer is shorting
Is your FREEZER is plugged into a wall socket which is protected by an EARTH LEAKAGE UNIT or RCD [Residual Current Device] ???
Most manufacturers advise NOT to have this type of appliance connected through an RCD as the start load required when the COMPRESSOR "kicks in" is quite large [especially in larger fridge/freezer units] AND will quite often TRIP your RCD. These appliances are better connected to a separate electrical circuit if at all possible and not protected by an RCD.
Sep 20, 2014 | Refrigerators
Fridge/freezer keeps tripping
Try to plug into different circuit, if it trips that breaker on the board then the appliance is probably at fault.
I must assume that you have not acquired something plugged into the same circuit as the fridge.
Sep 26, 2017 | Beko Refrigerators
Whirlpool fridge freiezer keeps tripping power
Does it run for a while than trip the power or does it trip it as soon as it is turned on?
Jan 30, 2013 | Refrigerators
Hotpoint FFM71 fridge freezer tripping
Replace the breaker. It may be out of tolerance.
Nov 26, 2012 | Hotpoint Refrigerators
Hi, my fridge freezer keeps making the electric trip out. help!!!
Try this:
Aug 17, 2010 | Refrigerators
Hello, my hotpoint FF187E fridge freezer keeps tripping my electric off, sometimes it will stay on for a couple of days other times it does this straight away, any idears would be appreciated, thanks...
you may have a burned wiring which when wet trips off you electricity. the location may be in front of your unit between the doors if you have a two door fridge. if you have a singole door unit it may be located on lower area of the fridge body which where the water flow down when you have excess water dripping infront of your fridge. those two location are most likely because the wiring installations from thermostat, heater, and ligth are there. ofcourse you have to check first the compressor and it's auxillaries
Jan 13, 2010 | Freezers
Fridge keeps tripping electricity
I assume by "earth leakage" you mean it is on a GFI circuit? Some older GFI outlets are sensitive to and do not work well with motors or other inductive loads like your refridgerator compressor. As for the compressor feeling hot, this is usually normal.
If this is a GFI outlet, try replacing it with new unit. If it is a GFI breaker, try replacing that.
Dec 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Whirlpool fridge freezer tripping the electric
PLEASE CALL PENINSULA ENGINEERING & SERVICES
9224699796 , BASED IN MUMBAI 24 HRS SERVICES 100 % JOB SATISFACTORY
Sep 03, 2008 | Freezers
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
675 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
